[GRASS-SVN] r53324 - grass/branches/develbranch_6
Fri Oct 5 19:56:00 PDT 2012
Author: neteler
Date: 2012-10-05 19:56:00 -0700 (Fri, 05 Oct 2012)
New Revision: 53324
   grass/branches/develbranch_6/aclocal.m4
   grass/branches/develbranch_6/configure
fix for NetBSD (fixes trac #1757)
Modified: grass/branches/develbranch_6/aclocal.m4
--- grass/branches/develbranch_6/aclocal.m4	2012-10-06 02:55:42 UTC (rev 53323)
+++ grass/branches/develbranch_6/aclocal.m4	2012-10-06 02:56:00 UTC (rev 53324)
@@ -1005,7 +1005,7 @@
 	    SHLIB_SUFFIX=".so"
 	    LDFLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
 	    CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
-	    LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
+	    LD_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 	    if test "${GRASS_THREADS}" = "1" ; then
 		# The -pthread needs to go in the CFLAGS, not LIBS
 		LIBS=`echo $LIBS | sed s/-pthread//`
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2012-10-06 02:55:42 UTC (rev 53323)
+++ grass/branches/develbranch_6/configure	2012-10-06 02:56:00 UTC (rev 53324)
@@ -2363,7 +2363,7 @@
 	    SHLIB_SUFFIX=".so"
