[GRASS-SVN] r53335 - in grass-addons/grass6/raster: . r.rdfilter
svn_grass at osgeo.org
Mon Oct 8 06:23:01 PDT 2012
Author: jradinger
Date: 2012-10-08 06:23:00 -0700 (Mon, 08 Oct 2012)
New Revision: 53335
Added:
grass-addons/grass6/raster/r.rdfilter/
grass-addons/grass6/raster/r.rdfilter/Makefile
grass-addons/grass6/raster/r.rdfilter/description.html
grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py
Added: grass-addons/grass6/raster/r.rdfilter/Makefile
--- grass-addons/grass6/raster/r.rdfilter/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.rdfilter/Makefile 2012-10-08 13:23:00 UTC (rev 53335)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.rdfilter.py
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass6/raster/r.rdfilter/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass6/raster/r.rdfilter/description.html
--- grass-addons/grass6/raster/r.rdfilter/description.html (rev 0)
+++ grass-addons/grass6/raster/r.rdfilter/description.html 2012-10-08 13:23:00 UTC (rev 53335)
@@ -0,0 +1,52 @@
+<h2>DESCRIPTION</h2>
+<em>r.rdfilter</em> creates a new raster map using a focal filter.
+Thus each cell category value depends on the values around that cell.
+Instead of a moving window (e.g. <i>r.neighbors</i>) a "real distance filter"
+based on <i>cost</i> is applied.
+<p>
+The user can select the distance around
+each cell which is considered for the new value as well as the statistical
+value (mean,median,min,max).
+<h2>NOTES</h2>
+A r.cost-approach is used to generate buffers for the user supplied distance
+for each raster cell ("filter window"). A statistical focal value is assign
+to each cell in a looped process. Since this module involves a loop over all raster
+cells and the computational expensive process r.cost, <em>r.rdfilter</em> can take
+a long time, especially for larger raster input maps.
+<h2>EXAMPLES</h2>
+Create a raster map of dominant geological material of a stream in
+a given distance up and downstream
+<div class="code"><pre>
+# Extract a stream from spearfish dataset for sample application
+r.watershed -f elevation="elevation.10m at PERMANENT" accumulation="accum"
+r.mapcalc "accum_abs = abs(accum)"
+r.stream.extract elevation="elevation.10m at PERMANENT" threshold=200 stream_rast="stream" direction="dirs"
+r.stream.basins dir="dirs" coors="602140,4927950" basins="basins"
+r.mapcalc "sample_stream = basins && stream"
+# Extract geological information for sample stream course
+r.mapcalc "geology_sample_stream = if(sample_stream,geology at PERMANENT,null())"
+# Calculate median geological material ("median category value") for
+# 1500 m up- and downstream of each stream cell
+r.rdfilter.py input=geology_sample_stream stat=median distance=1500
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.neighbors.html">r.neighbors</a><br>
+</em>
+<h2>AUTHOR</h2>
+Johannes Radinger<br>
+<i>Leibniz-Institute of Freshwater Ecology and Inland Fisheries (IGB)<br>
+Berlin, Germany</i>
+<br>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/raster/r.rdfilter/description.html
Added: grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py
--- grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py (rev 0)
+++ grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py 2012-10-08 13:23:00 UTC (rev 53335)
@@ -0,0 +1,185 @@
+#!/usr/bin/env python
+# MODULE: Applying a focal filter based on real distance (cost map)
+# AUTHOR(S): Johannes Radinger <johannesradinger at gmail.com>
+# COPYRIGHT: (C) 2012 Johannes Radinger
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Calculating focal raster based on a r.cost distance of a raster cell
+#% keywords: raster, focal
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: input raster
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: output raster
+#% required: no
+#%end
+#%option
+#% key: stat
+#% type: string
+#% multiple:no
+#% options:mean,min,max,sum,median,range
+#% description: Desired focal statistic for output raster
+#% required: yes
+#%end
+#%option
+#% key: distance
+#% type: double
+#% required: yes
+#% multiple: no
+#% description: Distance for filter/buffer
+#%End
+import sys
+import os
+import atexit
+import grass.script as grass
+tmp_map_rast = None
+tmp_map_vect = None
+def cleanup():
+ if (tmp_map_rast or tmp_map_vect):
+ grass.run_command("g.remove",
+ rast = tmp_map_rast,
+ vect = tmp_map_vect,
+ quiet = True)
+def main():
+ #defining temporary maps
+ tmp_map_rast = ["tmp"+str(os.getpid()),"distance_mask"+str(os.getpid()),"masked_map"+str(os.getpid())]
+ tmp_map_vect = ["point_tmp"+str(os.getpid())]
+ # check if db is connected if not create a connection!
+ if grass.read_command("db.connect", flags="p").split()[1].split(":")[1]:
+ grass.message("DB is set")
+ else:
+ grass.run_command("db.connect",driver = "sqlite",database = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db")
+ # Getting resolution of raster map
+ res = int(grass.read_command("g.region", flags = "m").strip().split('\n')[4].split('=')[1])
+ # Defining variables
+ input_map = options['input']
+ distance = options['distance']
+ if options['output']:
+ output_map = str(options['output'])
+ else:
+ output_map = "d"+str(distance)+"_"+str(input_map)
+ # creating temporary map
+ grass.mapcalc("$tmp = if($raster>=0,$res,null())",
+ tmp = "tmp"+str(os.getpid()),
+ res = res,
+ raster = input_map)
+ # make points from raster
+ grass.run_command("r.to.vect",
+ overwrite = True,
+ input = "tmp"+str(os.getpid()),
+ output = "point_tmp"+str(os.getpid()),
+ feature = "point")
+ # Get coordinates for each point
+ grass.run_command("v.db.addcol",
+ map = "point_tmp"+str(os.getpid()),
+ columns = "X DOUBLE, Y DOUBLE, univar DOUBLE")
+ grass.run_command("v.to.db",
+ type = "point",
+ option = "coor",
+ columns = "X,Y")
+ # Get "list" of coordinates
+ pointcoords = grass.read_command("v.db.select",
+ flags = "c",
+ fs ="|",
+ columns = "cat,X,Y")
+ for line in pointcoords.split():
+ cat,X,Y = line.split('|')
+ #creating coordinates
+ coors = str(X)+","+str(Y)
+ # creating "focal distance mask" (using r.cost with a specified distance as input)
+ grass.run_command("r.cost",
+ flags = 'n',
+ overwrite = True,
+ max_cost = distance,
+ output = "distance_mask"+str(os.getpid()),
+ coordinate = coors)
+ # creating "masked map" based on input
+ grass.mapcalc("$masked_map= if(!isnull($distance_mask),$input_map,null())",
+ masked_map = "masked_map"+str(os.getpid()),
+ input_map = input_map,
+ distance_mask = "distance_mask"+str(os.getpid()))
+ # Getting focal statistics (e.g. mean) for masked_map
+ univar = grass.read_command("r.univar", map = "masked_map"+str(os.getpid()), flags = 'e')
+ d = {'min': 6, 'max': 7, 'mean': 9, 'sum': 14, 'median':16, 'range':8}
+ stat = float(univar.split('\n')[d[str(options['stat'])]].split(':')[1])
+ #update point map with new stat value
+ grass.write_command("db.execute", stdin = 'UPDATE point_tmp%s SET univar=%s WHERE cat = %d' % (str(os.getpid()),str(stat),int(cat)))
+ # Remove temp maps of loop
+ grass.run_command("g.remove",rast = ["masked_map"+str(os.getpid()),"distance_mask"+str(os.getpid())])
+ # End of loop
+ # Create new raster from the temporary point vector with the newly generated values
+ grass.run_command("v.to.rast",
+ input = "point_tmp"+str(os.getpid()),
+ output = output_map,
+ use = "attr",
+ column= "univar")
+ grass.run_command("g.remove", vect = "point_tmp"+str(os.getpid()))
+ grass.run_command("g.remove", rast = "tmp"+str(os.getpid()))
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
Property changes on: grass-addons/grass6/raster/r.rdfilter/r.rdfilter.py
