[GRASS-SVN] r53337 - grass-addons/grass6/imagery/i.landsat.toar
svn_grass at osgeo.org
Mon Oct 8 12:55:13 PDT 2012
Author: neteler
Date: 2012-10-08 12:55:12 -0700 (Mon, 08 Oct 2012)
New Revision: 53337
grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c
grass-addons/grass6/imagery/i.landsat.toar/main.c
fix comment style; reorder method parameter; strcasecmp() -> G_strcasecmp()
Modified: grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c
--- grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c 2012-10-08 13:46:43 UTC (rev 53336)
+++ grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c 2012-10-08 19:55:12 UTC (rev 53337)
@@ -96,7 +96,7 @@
lsat->sun_elev = atof(value);
- // Fill data with the sensor_XXX functions
+ /* Fill data with the sensor_XXX functions */
switch(lsat->number)
case 1:
@@ -184,7 +184,7 @@
get_mtldata(mtldata, "SUN_ELEVATION", value);
case 1:
@@ -226,7 +226,7 @@
break;
- // Update the information from metadata file
+ /* Update the information from metadata file */
for (i = 0; i < lsat->bands; i++) {
snprintf(name, MAX_STR, "LMAX_BAND%d", lsat->band[i].code);
get_mtldata(mtldata, name, value);
@@ -247,5 +247,3 @@
return;
Modified: grass-addons/grass6/imagery/i.landsat.toar/main.c
--- grass-addons/grass6/imagery/i.landsat.toar/main.c 2012-10-08 13:46:43 UTC (rev 53336)
+++ grass-addons/grass6/imagery/i.landsat.toar/main.c 2012-10-08 19:55:12 UTC (rev 53337)
@@ -10,7 +10,7 @@
* PURPOSE: Calculate TOA Radiance or Reflectance and Kinetic Temperature
* for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
- * COPYRIGHT: (C) 2012 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2012 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -85,16 +85,6 @@
metfn->description = _("Name of Landsat metadata file (.met or MTL.txt)");
metfn->guisection = _("Metadata");
- metho = G_define_option();
- metho->key = "method";
- metho->type = TYPE_STRING;
- metho->required = NO;
- metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
- metho->label = _("Atmospheric correction method");
- metho->description = _("Atmospheric correction method");
- metho->answer = "uncorrected";
- metho->guisection = _("Metadata");
sensor = G_define_option();
sensor->key = "sensor";
sensor->type = TYPE_STRING;
@@ -113,6 +103,16 @@
sensor->required = NO;
sensor->guisection = _("Metadata");
+ metho = G_define_option();
+ metho->key = "method";
+ metho->type = TYPE_STRING;
+ metho->required = NO;
+ metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
+ metho->label = _("Atmospheric correction method");
+ metho->description = _("Atmospheric correction method");
+ metho->answer = "uncorrected";
+ metho->guisection = _("Metadata");
adate = G_define_option();
adate->key = "date";
adate->type = TYPE_STRING;
@@ -172,7 +172,6 @@
atmo->answer = "0.0";
atmo->guisection = _("Settings");
/* define the different flags */
frad = G_define_flag();
frad->key = 'r';
@@ -282,17 +281,17 @@
* ------------ PREPARATION --------------
- if (strcasecmp(metho->answer, "corrected") == 0)
+ if (G_strcasecmp(metho->answer, "corrected") == 0)
method = CORRECTED;
- else if (strcasecmp(metho->answer, "dos1") == 0)
+ else if (G_strcasecmp(metho->answer, "dos1") == 0)
method = DOS1;
- else if (strcasecmp(metho->answer, "dos2") == 0)
+ else if (G_strcasecmp(metho->answer, "dos2") == 0)
method = DOS2;
- else if (strcasecmp(metho->answer, "dos2b") == 0)
+ else if (G_strcasecmp(metho->answer, "dos2b") == 0)
method = DOS2b;
- else if (strcasecmp(metho->answer, "dos3") == 0)
+ else if (G_strcasecmp(metho->answer, "dos3") == 0)
method = DOS3;
- else if (strcasecmp(metho->answer, "dos4") == 0)
+ else if (G_strcasecmp(metho->answer, "dos4") == 0)
method = DOS4;
else
method = UNCORRECTED;
