[GRASS-SVN] r53352 - grass-addons/grass6/raster/mcda/r.mcda.roughset
svn_grass at osgeo.org
Wed Oct 10 08:37:14 PDT 2012
Author: gianluca
Date: 2012-10-10 08:37:13 -0700 (Wed, 10 Oct 2012)
New Revision: 53352
grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py
handle null values
Modified: grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py
--- grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py 2012-10-10 12:59:22 UTC (rev 53351)
+++ grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py 2012-10-10 15:37:13 UTC (rev 53352)
@@ -1,14 +1,14 @@
#!/usr/bin/env python
-# MODULE: r.mcda.roughset
-# AUTHOR: Gianluca Massei - Antonio Boggia
-# PURPOSE: Generate a MCDA map from several criteria maps using Dominance Rough Set Approach - DRSA
-# (DOMLEM algorithm proposed by (S. Greco, B. Matarazzo, R. Slowinski)
+# MODULE: r.mcda.roughset
+# AUTHOR: Gianluca Massei - Antonio Boggia
+# PURPOSE: Generate a MCDA map from several criteria maps using Dominance Rough Set Approach - DRSA
+# (DOMLEM algorithm proposed by (S. Greco, B. Matarazzo, R. Slowinski)
# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
-# Development Team. This program is free software under the
-# GNU General PublicLicense (>=v2). Read the file COPYING
-# that comes with GRASS for details.
+# Development Team. This program is free software under the
+# GNU General PublicLicense (>=v2). Read the file COPYING
+# that comes with GRASS for details.
@@ -61,6 +61,11 @@
#% key: l
#% description: do not remove single rules in vector format
#%end
+#%flag
+#% key: n
+#% description: compute null value as zero
+#% answer:true
+#%end
import sys
import copy
@@ -71,521 +76,525 @@
def BuildFileISF(attributes, preferences, decision, outputMap, outputTxt):
- outputTxt=outputTxt+".isf"
- outf = file(outputTxt,"w")
- outf.write("**ATTRIBUTES\n")
- for i in range(len(attributes)):
- outf.write("+ %s: (continuous)\n" % attributes[i])
- outf.write("+ %s: [" % decision)
- value=[]
- value=grass.read_command("r.describe", flags = "1n", map = decision)
- v=value.split()
+ outputTxt=outputTxt+".isf"
+ outf = file(outputTxt,"w")
+ outf.write("**ATTRIBUTES\n")
+ for i in range(len(attributes)):
+ outf.write("+ %s: (continuous)\n" % attributes[i])
+ outf.write("+ %s: [" % decision)
+ value=[]
+ value=grass.read_command("r.describe", flags = "1n", map = decision)
+ v=value.split()
- for i in range(len(v)-1):
- outf.write("%s, " % str(v[i]))
- outf.write("%s]\n" % str(v[len(v)-1]))
- outf.write("decision: %s\n" % decision)
+ for i in range(len(v)-1):
+ outf.write("%s, " % str(v[i]))
+ outf.write("%s]\n" % str(v[len(v)-1]))
+ outf.write("decision: %s\n" % decision)
- outf.write("\n**PREFERENCES\n")
- if(preferences[i]==""):
- preferences[i]="none"
- outf.write("%s: %s\n" % (attributes[i], preferences[i]))
- outf.write("%s: gain\n" % decision)
- outf.write("\n**EXAMPLES\n")
- examples=[]
- MATRIX=[]
- grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
- rast="rast",
- decision=decision,
- attribute=attributes[i])
- tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
- example=tmp.split()
- examples.append(example)
- tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
+ outf.write("\n**PREFERENCES\n")
+ if(preferences[i]==""):
+ preferences[i]="none"
+ outf.write("%s: %s\n" % (attributes[i], preferences[i]))
+ outf.write("%s: gain\n" % decision)
+ if flags['n']:
+ print "%s - convert null to 0" % str(attributes[i])
+ grass.run_command("r.null", map=attributes[i], null=0)
+ outf.write("\n**EXAMPLES\n")
+ examples=[]
+ MATRIX=[]
- MATRIX=map(list,zip(*examples))
- MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
- MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
- for r in range(len(MATRIX)):
- for c in range(len(MATRIX[0])):
- outf.write("%s " % (MATRIX[r][c]))
-# outf.write("%s " % round(float(MATRIX[r][c]), 2))
- outf.write("\n")
- outf.write("**END")
- outf.close()
- return outputTxt
+ grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
+ rast="rast",
+ decision=decision,
+ attribute=attributes[i])
+ tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
+ example=tmp.split()
+ examples.append(example)
+ tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
+ MATRIX=map(list,zip(*examples))
+ MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
+ MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
+ for r in range(len(MATRIX)):
+ for c in range(len(MATRIX[0])):
+ outf.write("%s " % (MATRIX[r][c]))
+# outf.write("%s " % round(float(MATRIX[r][c]), 2))
+ outf.write("\n")
+ outf.write("**END")
+ outf.close()
+ return outputTxt
def collect_attributes (data):
- "Collects the values of header files isf, puts them in an array of dictionaries"
- header=[]
- attribute=dict()
- j=0
- start=(data.index(['**ATTRIBUTES'])+1)
- end=(data.index(['**PREFERENCES'])-1)
- for r in range(start, end):
- attribute={'name':data[r][1].strip('+:')}
- header.append(attribute)
- decision=data[end-1][1]
- end=(data.index(['**EXAMPLES']))
- start=(data.index(['**PREFERENCES'])+1)
- for r in header:
- r['preference']=data[start+j][1]
- j=j+1
- return header
+ "Collects the values of header files isf, puts them in an array of dictionaries"
+ header=[]
+ attribute=dict()
+ j=0
+ start=(data.index(['**ATTRIBUTES'])+1)
+ end=(data.index(['**PREFERENCES'])-1)
+ for r in range(start, end):
+ attribute={'name':data[r][1].strip('+:')}
+ header.append(attribute)
+ decision=data[end-1][1]
+ end=(data.index(['**EXAMPLES']))
+ start=(data.index(['**PREFERENCES'])+1)
+ for r in header:
+ r['preference']=data[start+j][1]
+ j=j+1
+ return header
def collect_examples (data):
- "Collect examples values and put them in a matrix (list of lists) "
- matrix=[]
- data=[r for r in data if not '?' in r] #filter objects with " ?"
-# data=[data.remove(r) for r in data if data.count(r)>1]
- start=(data.index(['**EXAMPLES'])+1)
- end=data.index(['**END'])
- for i in range(start, end):
- data[i]=(map(float, data[i]))
- matrix.append(data[i])
- i=1
- for r in matrix:
- r.insert(0, str(i))
- i=i+1
-## matrix=[list(i) for i in set(tuple(j) for j in matrix)] #remove duplicate example
- return matrix
+ "Collect examples values and put them in a matrix (list of lists) "
+ matrix=[]
+ data=[r for r in data if not '?' in r] #filter objects with " ?"
+# data=[data.remove(r) for r in data if data.count(r)>1]
+ start=(data.index(['**EXAMPLES'])+1)
+ end=data.index(['**END'])
+ for i in range(start, end):
+ data[i]=(map(float, data[i]))
+ matrix.append(data[i])
+ i=1
+ for r in matrix:
+ r.insert(0, str(i))
+ i=i+1
+## matrix=[list(i) for i in set(tuple(j) for j in matrix)] #remove duplicate example
+ return matrix
def FileToInfoSystem(isf):
- "Read *.isf file and copy it's values in Infosystem dictionary"
- data=[]
- try:
- infile=open(isf,"r")
- rows=infile.readlines()
- for line in rows:
- line=(line.split())
- if (len(line)>0 ):
- data.append(line)
- infile.close()
- infosystem={'attributes':collect_attributes(data),'examples':collect_examples(data)}
- except TypeError:
- print "\n\n Computing error or input file %s is not readeable. Exiting gracefully" % isf
- sys.exit(0)
- return infosystem
+ "Read *.isf file and copy it's values in Infosystem dictionary"
+ data=[]
+ try:
+ infile=open(isf,"r")
+ rows=infile.readlines()
+ for line in rows:
+ line=(line.split())
+ if (len(line)>0 ):
+ data.append(line)
+ infile.close()
+ infosystem={'attributes':collect_attributes(data),'examples':collect_examples(data)}
+ except TypeError:
+ print "\n\n Computing error or input file %s is not readeable. Exiting gracefully" % isf
+ sys.exit(0)
+ return infosystem
def UnionOfClasses (infosystem):
- "Find upward and downward union for all classes and put it in a dictionary"
- DecisionClass=[]
- AllClasses=[]
- matrix=infosystem['examples']
- for r in matrix:
- DecisionClass.append(int(r[-1]))
- DecisionClass=list(set(DecisionClass))
- for c in range(len(DecisionClass)):
- tmplist=[r for r in matrix if int(r[-1])==DecisionClass[c]]
- AllClasses.append(tmplist)
- return AllClasses
+ "Find upward and downward union for all classes and put it in a dictionary"
+ DecisionClass=[]
+ AllClasses=[]
+ matrix=infosystem['examples']
+ for r in matrix:
+ DecisionClass.append(int(r[-1]))
+ DecisionClass=list(set(DecisionClass))
+ for c in range(len(DecisionClass)):
+ tmplist=[r for r in matrix if int(r[-1])==DecisionClass[c]]
+ AllClasses.append(tmplist)
+ return AllClasses
def DownwardUnionsOfClasses (infosystem):
- "For each decision class, downward union corresponding to a decision class\
- is composed of this class and all worse classes (<=)"
+ "For each decision class, downward union corresponding to a decision class\
+ is composed of this class and all worse classes (<=)"
- DownwardUnionClass=[]
- DecisionClass=[]
- for r in matrix:
- for c in DecisionClass:
- tmplist=[r for r in matrix if int(r[-1])<=c]
- DownwardUnionClass.append(tmplist)
- #label=[row[0] for row in tmplist]
- return DownwardUnionClass
+ DownwardUnionClass=[]
+ DecisionClass=[]
+ for r in matrix:
+ for c in DecisionClass:
+ tmplist=[r for r in matrix if int(r[-1])<=c]
+ DownwardUnionClass.append(tmplist)
+ #label=[row[0] for row in tmplist]
+ return DownwardUnionClass
def UpwardUnionsOfClasses (infosystem):
- "For each decision class, upward union corresponding to a decision class \
- is composed of this class and all better classes.(>=)"
+ "For each decision class, upward union corresponding to a decision class \
+ is composed of this class and all better classes.(>=)"
- UpwardUnionClass=[]
- DecisionClass=[]
- for r in matrix:
- tmplist=[r for r in matrix if int(r[-1])>=c]
- UpwardUnionClass.append(tmplist)
- return UpwardUnionClass
+ UpwardUnionClass=[]
+ DecisionClass=[]
+ for r in matrix:
+ tmplist=[r for r in matrix if int(r[-1])>=c]
+ UpwardUnionClass.append(tmplist)
+ return UpwardUnionClass
def is_better (r1,r2, preference):
- "Check if r1 is better than r2"
- return all((( x >=y and p=='gain') or (x<=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
+ "Check if r1 is better than r2"
+ return all((( x >=y and p=='gain') or (x<=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
def is_worst (r1,r2, preference):
- "Check if r1 is worst than r2"
- return all((( x <=y and p=='gain') or (x>=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
+ "Check if r1 is worst than r2"
+ return all((( x <=y and p=='gain') or (x>=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
def DominatingSet (infosystem):
- "Find P-dominating set"
- preference=[s['preference'] for s in infosystem['attributes'] ]
- Dominating=[]
- for row in matrix:
- examples=[r for r in matrix if is_better(r[1:-1], row[1:-1], preference) ]
- Dominating.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
-## for dom in Dominating:
-## print dom['dominance'] ,' dominating ', dom['object']
- return Dominating
+ "Find P-dominating set"
+ preference=[s['preference'] for s in infosystem['attributes'] ]
+ Dominating=[]
+ for row in matrix:
+ examples=[r for r in matrix if is_better(r[1:-1], row[1:-1], preference) ]
+ Dominating.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
+## for dom in Dominating:
+## print dom['dominance'] ,' dominating ', dom['object']
+ return Dominating
def DominatedSet (infosystem):
- "Find P-Dominated set"
- Dominated=[]
- examples=[r for r in matrix if is_worst(r[1:-1], row[1:-1], preference[:-1]) ]
- Dominated.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
-## for dom in Dominated:
-## print dom['dominance'] ,' is dominated by ', dom['object']
- return Dominated
+ "Find P-Dominated set"
+ Dominated=[]
+ examples=[r for r in matrix if is_worst(r[1:-1], row[1:-1], preference[:-1]) ]
+ Dominated.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
+## for dom in Dominated:
+## print dom['dominance'] ,' is dominated by ', dom['object']
+ return Dominated
def LowerApproximation (UnionClasses, Dom):
- "Find Lower approximation and return a dictionaries list"
- c=1
- LowApprox=[]
- single=dict()
- for union in UnionClasses:
- tmp=[]
- UClass=set([row[0] for row in union] )
- for d in Dom:
- if (UClass.issuperset(set(d['dominance']))): #if Union class is a superse of dominating/dominated set, =>single Loer approx.
- tmp.append(d['object'])
- single={'class':c, 'objects':tmp} #dictionary for lower approximation --
- LowApprox.append(single) #insert all Lower approximation in a list
- c+=1
- return LowApprox
+ "Find Lower approximation and return a dictionaries list"
+ c=1
+ LowApprox=[]
+ single=dict()
+ for union in UnionClasses:
+ tmp=[]
+ UClass=set([row[0] for row in union] )
+ for d in Dom:
+ if (UClass.issuperset(set(d['dominance']))): #if Union class is a superse of dominating/dominated set, =>single Loer approx.
+ tmp.append(d['object'])
+ single={'class':c, 'objects':tmp} #dictionary for lower approximation --
+ LowApprox.append(single) #insert all Lower approximation in a list
+ c+=1
+ return LowApprox
def UpperApproximation (UnionClasses, Dom):
- "Find Upper approximation and return a dictionaries list"
- c=1
- UppApprox=[]
- single=dict()
- UnClass=[row[0] for row in union] #single union class
- s=[]
- for d in Dom:
- if len(set(d['dominance']) & set(UnClass)) >0:
- s.append(d['object'])
-# print set(s)
- single={'class':c,'objects':list(set(s))}
- UppApprox.append(single)
- c+=1
+ "Find Upper approximation and return a dictionaries list"
+ c=1
+ UppApprox=[]
+ single=dict()
+ UnClass=[row[0] for row in union] #single union class
+ s=[]
+ for d in Dom:
+ if len(set(d['dominance']) & set(UnClass)) >0:
+ s.append(d['object'])
+# print set(s)
+ single={'class':c,'objects':list(set(s))}
+ UppApprox.append(single)
+ c+=1
- return UppApprox
+ return UppApprox
def Boundaries (UppApprox, LowApprox):
- "Find Boundaries like doubtful regions"
- Boundary=[]
- single=dict()
+ "Find Boundaries like doubtful regions"
+ Boundary=[]
+ single=dict()
- for i in range(len(UppApprox)):
- single={'class':i, 'objects':list (set(UppApprox[i]['objects'])-set(LowApprox[i]['objects']) )}
- Boundary.append(single)
- return Boundary
+ for i in range(len(UppApprox)):
+ single={'class':i, 'objects':list (set(UppApprox[i]['objects'])-set(LowApprox[i]['objects']) )}
+ Boundary.append(single)
+ return Boundary
def AccuracyOfApproximation(UppApprox, LowApprox):
- "Define the accuracy of approximation of Upward and downward approximation class"
- return len(LowApprox)/len(UppApprox)
+ "Define the accuracy of approximation of Upward and downward approximation class"
+ return len(LowApprox)/len(UppApprox)
def QualityOfQpproximation(DownwardBoundary, infosystem):
- "Defines the quality of approximation of the partition Cl or, briefly, the quality of sorting"
- UnionBoundary=set()
- U=set([i[0] for i in infosystem['examples']])
- for b in DownwardBoundary:
- UnionBoundary=set(UnionBoundary) | set(b['objects'])
- return float(len(U-UnionBoundary)) / float(len(U))
+ "Defines the quality of approximation of the partition Cl or, briefly, the quality of sorting"
+ UnionBoundary=set()
+ U=set([i[0] for i in infosystem['examples']])
+ for b in DownwardBoundary:
+ UnionBoundary=set(UnionBoundary) | set(b['objects'])
+ return float(len(U-UnionBoundary)) / float(len(U))
def FindObjectCovered (rules, selected):
- "Find objects covered by a single rule and return\
- all related examples covered"
- obj=[]
- examples=[]
- for rule in rules:
- examples.append(rule['objectsCovered'])
+ "Find objects covered by a single rule and return\
+ all related examples covered"
+ obj=[]
+ examples=[]
+ for rule in rules:
+ examples.append(rule['objectsCovered'])
- if len(examples)>0:
- examples = reduce(set.intersection,map(set,examples)) #functional approach: intersect all lists if example is not empty
- examples = list(set(examples) & set([r[0] for r in selected]))
- return examples #all examples covered from a single rule
+ if len(examples)>0:
+ examples = reduce(set.intersection,map(set,examples)) #functional approach: intersect all lists if example is not empty
+ examples = list(set(examples) & set([r[0] for r in selected]))
+ return examples #all examples covered from a single rule
def Evaluate (elem,rules,G,selected,infosystem):
- "Calcolate first and second evaluate index, according with original DOMLEM Algorithm"
- tmpRules=copy.deepcopy(rules)
- tmpElem=copy.deepcopy(elem)
- tmpRules.append(tmpElem)
- Object=[]
- Object=FindObjectCovered(tmpRules,selected)
- if(float(len(Object)))>0:
- firstEvaluate=float(len(set(G) & set(Object))) / float(len(Object))
- secondEvaluate=float(len(set(G) & set(Object)))
- else:
- firstEvaluate=0
- secondEvaluate=0
- return firstEvaluate,secondEvaluate
+ "Calcolate first and second evaluate index, according with original DOMLEM Algorithm"
+ tmpRules=copy.deepcopy(rules)
+ tmpElem=copy.deepcopy(elem)
+ tmpRules.append(tmpElem)
+ Object=[]
+ Object=FindObjectCovered(tmpRules,selected)
+ if(float(len(Object)))>0:
+ firstEvaluate=float(len(set(G) & set(Object))) / float(len(Object))
+ secondEvaluate=float(len(set(G) & set(Object)))
+ else:
+ firstEvaluate=0
+ secondEvaluate=0
+ return firstEvaluate,secondEvaluate
def FindBestCondition (best, elem, rules, selected, G, infosystem):
- "Choose the best condition"
+ "Choose the best condition"
- firstElem,secondElem=Evaluate(elem,rules,G,selected,infosystem)
- firstBest,secondBest=Evaluate(best,rules,G,selected,infosystem)
- if (firstElem>firstBest) or (firstElem==firstBest and secondElem>=secondBest):
- best=copy.deepcopy(elem)
- else:
- best=best
+ firstElem,secondElem=Evaluate(elem,rules,G,selected,infosystem)
+ firstBest,secondBest=Evaluate(best,rules,G,selected,infosystem)
+ if (firstElem>firstBest) or (firstElem==firstBest and secondElem>=secondBest):
+ best=copy.deepcopy(elem)
+ else:
+ best=best
- return best
+ return best
def Type_one_rule (c, e, preference, matrix):
- elem={'criterion':c,'condition':e, 'sign':preference[c-1],'class':'', \
- 'objectsCovered':[r[0] for r in matrix if (((r[c] >= e ) and (preference[c-1] == 'gain')) \
- or ((r[c] <= e ) and (preference[c-1] == 'cost' )))],'label':''}
- return elem
+ elem={'criterion':c,'condition':e, 'sign':preference[c-1],'class':'', \
+ 'objectsCovered':[r[0] for r in matrix if (((r[c] >= e ) and (preference[c-1] == 'gain')) \
+ or ((r[c] <= e ) and (preference[c-1] == 'cost' )))],'label':''}
+ return elem
def Type_three_rule (c, e, preference, matrix):
- 'objectsCovered':[r[0] for r in matrix if (((r[c] <= e ) and (preference[c-1] == 'gain')) \
- or ((r[c] >= e ) and (preference[c-1] == 'cost' )))],'label':''}
- return elem
+ 'objectsCovered':[r[0] for r in matrix if (((r[c] <= e ) and (preference[c-1] == 'gain')) \
+ or ((r[c] >= e ) and (preference[c-1] == 'cost' )))],'label':''}
+ return elem
def Find_rules (B, infosystem, type_rule):
- "Search rule from a family of lower approximation of upward unions \
- of decision classes"
- start=time()
- matrix=copy.deepcopy(infosystem['examples'])
- criteria_num=len(infosystem['attributes'])
- criteria=[r[1:-1] for r in matrix]
- preference=[s['preference'] for s in infosystem['attributes'] ] #extract preference label
- num_rules=0 #total rules number for each lower approximation
- G=copy.deepcopy(B) #a set of objects from the given approximation
- E=[] #a set of rules covering set B (is a list of dictionary)
- all_obj_cov_by_rules=[] #all objects covered by all rules in E
- selected=copy.deepcopy(matrix) #storage reduct matrix by single elementary condition
- while (len(G)!=0 ):
- rules=[] #starting comples (single rule built from elementary conditions )
- S=copy.deepcopy(G) #set of objects currently covered by rule
- control=0
- while (len(rules)==0 or set(obj_cov_by_rules).issubset(B)==False):
- obj_cov_by_rules=[] #set covered by rules
- best={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''} #best candidate for elementary condition - start as empty
- for c in range(1, criteria_num):
- Cond=[r[c] for r in selected if r[0] in S] #for each positive object from S create an elementary condition
- for e in Cond:
- if type_rule=='one':
- elem= Type_one_rule (c, e, preference, matrix)
- elif type_rule=='three':
- elem= Type_three_rule (c, e, preference, matrix)
- else:
- elem={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''}
- best=FindBestCondition(best, elem, rules, selected, G, infosystem)
- if best not in rules:
- rules.append(best) #add the best condition to the complex
+ "Search rule from a family of lower approximation of upward unions \
+ of decision classes"
+ start=time()
+ matrix=copy.deepcopy(infosystem['examples'])
+ criteria_num=len(infosystem['attributes'])
+ criteria=[r[1:-1] for r in matrix]
+ preference=[s['preference'] for s in infosystem['attributes'] ] #extract preference label
+ num_rules=0 #total rules number for each lower approximation
+ G=copy.deepcopy(B) #a set of objects from the given approximation
+ E=[] #a set of rules covering set B (is a list of dictionary)
+ all_obj_cov_by_rules=[] #all objects covered by all rules in E
+ selected=copy.deepcopy(matrix) #storage reduct matrix by single elementary condition
+ while (len(G)!=0 ):
+ rules=[] #starting comples (single rule built from elementary conditions )
+ S=copy.deepcopy(G) #set of objects currently covered by rule
+ control=0
+ while (len(rules)==0 or set(obj_cov_by_rules).issubset(B)==False):
+ obj_cov_by_rules=[] #set covered by rules
+ best={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''} #best candidate for elementary condition - start as empty
+ for c in range(1, criteria_num):
+ Cond=[r[c] for r in selected if r[0] in S] #for each positive object from S create an elementary condition
+ for e in Cond:
+ if type_rule=='one':
+ elem= Type_one_rule (c, e, preference, matrix)
+ elif type_rule=='three':
+ elem= Type_three_rule (c, e, preference, matrix)
+ else:
+ elem={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''}
+ best=FindBestCondition(best, elem, rules, selected, G, infosystem)
+ if best not in rules:
+ rules.append(best) #add the best condition to the complex
- for r in rules:
- obj_cov_by_rules.append(r['objectsCovered'])
- obj_cov_by_rules=list((reduce(set.intersection,map(set,obj_cov_by_rules)))) #reduce():Apply function of two arguments cumulatively to the items of iterable, from left to right, so as to reduce the iterable to a single value.
+ for r in rules:
+ obj_cov_by_rules.append(r['objectsCovered'])
+ obj_cov_by_rules=list((reduce(set.intersection,map(set,obj_cov_by_rules)))) #reduce():Apply function of two arguments cumulatively to the items of iterable, from left to right, so as to reduce the iterable to a single value.
- S=list(set(S) & set(best['objectsCovered'] ))
- control+=1
+ S=list(set(S) & set(best['objectsCovered'] ))
+ control+=1
-# rules=CheckMinimalCondition (rules,B,matrix)
- if rules not in E:
- E.append(rules) #add the induced rule
- num_rules+=1
- all_obj_cov_by_rules=list(set(all_obj_cov_by_rules) | set(obj_cov_by_rules))
- G=list(set(B)-set(all_obj_cov_by_rules)) #remove example coverred by all finded rule -- this operation is a set difference
- selected=[o for o in selected if not o[0] in all_obj_cov_by_rules] #reduct matrix, remove object coverred by all finded rule
- num_rules+=1
- return E
+# rules=CheckMinimalCondition (rules,B,matrix)
+ if rules not in E:
+ E.append(rules) #add the induced rule
+ num_rules+=1
+ all_obj_cov_by_rules=list(set(all_obj_cov_by_rules) | set(obj_cov_by_rules))
+ G=list(set(B)-set(all_obj_cov_by_rules)) #remove example coverred by all finded rule -- this operation is a set difference
+ selected=[o for o in selected if not o[0] in all_obj_cov_by_rules] #reduct matrix, remove object coverred by all finded rule
+ num_rules+=1
+ return E
def Domlem(Lu,Ld, infosystem):
- "DOMLEM algoritm \
- (An algorithm for induction of decision rules consistent with the dominance\
- principle - Greco S., Matarazzo, B., Slowinski R., Stefanowski J.)"
- attributes=infosystem['attributes']
- RULES=[]
+ "DOMLEM algoritm \
+ (An algorithm for induction of decision rules consistent with the dominance\
+ principle - Greco S., Matarazzo, B., Slowinski R., Stefanowski J.)"
+ attributes=infosystem['attributes']
+ RULES=[]
## *** AT LEAST {>= Class} - Type 1 rules *** "
- for a in Lu[1:]:
- B=a['objects']
- E=Find_rules (B, infosystem, 'one')
- for e in E:
- for i in e:
- i['class']=a['class']
- i['label']=attributes[i['criterion']-1]['name']
- i['type']='at_last'
- if (attributes[i['criterion']-1]['preference']=='gain'):
- i['sign']='>='
- else:
- i['sign']='<='
- RULES.append(e)
+ for a in Lu[1:]:
+ B=a['objects']
+ E=Find_rules (B, infosystem, 'one')
+ for e in E:
+ for i in e:
+ i['class']=a['class']
+ i['label']=attributes[i['criterion']-1]['name']
+ i['type']='at_last'
+ if (attributes[i['criterion']-1]['preference']=='gain'):
+ i['sign']='>='
+ else:
+ i['sign']='<='
+ RULES.append(e)
-## *** AT MOST {<= Class} - Type 3 rules ***"
- for b in Ld[:-1]:
- B=b['objects']
- E=Find_rules(B, infosystem, 'three')
- for e in E:
- for i in e:
- i['class']=b['class']
- i['type']='at_most'
- i['sign']='<='
- else:
- i['sign']='>='
- RULES.append(e)
+## *** AT MOST {<= Class} - Type 3 rules ***"
+ for b in Ld[:-1]:
+ B=b['objects']
+ E=Find_rules(B, infosystem, 'three')
+ for e in E:
+ for i in e:
+ i['class']=b['class']
+ i['type']='at_most'
+ i['sign']='<='
+ else:
+ i['sign']='>='
+ RULES.append(e)
- return RULES
+ return RULES
def Print_rules(RULES, outputTxt):
- "Print rls output file"
+ "Print rls output file"
- i=1
- outfile=open(outputTxt+".rls","w")
- outfile.write('[RULES]\n')
- for R in RULES:
- outfile.write("%d: " % i, )
- #"&".join(e)
- for e in R:
- outfile.write("( %s %s %.3f )" % (e['label'], e['sign'],e['condition'] ))
- outfile.write("=> ( class %s , %s )\n" % ( e['type'], e['class'] ))
- i+=1
- outfile.close()
- return 0
+ i=1
+ outfile=open(outputTxt+".rls","w")
+ outfile.write('[RULES]\n')
+ for R in RULES:
+ outfile.write("%d: " % i, )
+ #"&".join(e)
+ for e in R:
+ outfile.write("( %s %s %.3f )" % (e['label'], e['sign'],e['condition'] ))
+ outfile.write("=> ( class %s , %s )\n" % ( e['type'], e['class'] ))
+ i+=1
+ outfile.close()
+ return 0
def Parser_mapcalc(RULES, outputMap):
- "Parser to build a formula to be included in mapcalc command"
- i=1
- category=[]
- maps=[]
- stringa=[]
- out=outputMap
+ "Parser to build a formula to be included in mapcalc command"
+ i=1
+ category=[]
+ maps=[]
+ stringa=[]
+ for R in RULES:
+ formula="if("
+ for e in R[:-1]: #build a mapcalc formula
+ formula+= "(%s %s %.4f ) && " % (e['label'], e['sign'] , e['condition'] )
+ formula+= "(%s %s %.4f ),%d,null())" % (R[-1]['label'],R[-1]['sign'], R[-1]['condition'] ,i )
+ mappa="r%d_%s_%d" % ( i, R[0]['type'], R[0]['class'] ) #build map name for mapcalc output
+ category.append({'id':i, 'type': R[0]['type'], 'class':R[0]['class']}) #extract category name
+ maps.append(mappa) #extract maps name
+ grass.mapcalc(mappa +"=" +formula)
+ i+=1
+ mapstring=",".join(maps)
+ print mapstring
+ for m in maps:
+ print "mappa:", m
+ grass.run_command("r.to.vect", overwrite='True', flags='s', input=m, output=m, feature='area')
+ grass.run_command("v.db.addcol", map=m, columns='rule varchar(25)')
+ grass.run_command("v.db.update", map=m, column='rule', value=m)
+ grass.run_command("v.db.update", map=m, column='label', value=" ".join(m.split('_')[1:]))
+ if len(maps)>1:
+ grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
+ else:
+ grass.run_command("g.copy",vect=(mapstring,outputMap))
+ grass.run_command("g.remove", rast=mapstring)
+ if not flags['l']:
+ grass.run_command("g.remove", vect=mapstring)
- for R in RULES:
- formula="if("
- for e in R[:-1]: #build a mapcalc formula
- formula+= "(%s %s %.4f ) && " % (e['label'], e['sign'] , e['condition'] )
- formula+= "(%s %s %.4f ),%d,null())" % (R[-1]['label'],R[-1]['sign'], R[-1]['condition'] ,i )
- mappa="r%d_%s_%d" % ( i, R[0]['type'], R[0]['class'] ) #build map name for mapcalc output
- category.append({'id':i, 'type': R[0]['type'], 'class':R[0]['class']}) #extract category name
- maps.append(mappa) #extract maps name
- grass.mapcalc(mappa +"=" +formula)
- i+=1
- mapstring=",".join(maps)
- for m in maps:
- print "mappa:", m
- grass.run_command("r.to.vect", overwrite='True', flags='s', input=m, output=m, feature='area')
- grass.run_command("v.db.addcol", map=m, columns='rule varchar(25)')
- grass.run_command("v.db.update", map=m, column='rule', value=m)
- grass.run_command("v.db.update", map=m, column='label', value=" ".join(m.split('_')[1:]))
- grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
- grass.run_command("g.remove", rast=mapstring)
- if not flags['l']:
- grass.run_command("g.remove", vect=mapstring)
- return 0
+ return 0
def main():
- "main function for DOMLEM algorithm"
+ "main function for DOMLEM algorithm"
- try:
- start=time()
- attributes = options['criteria'].split(',')
- preferences=options['preferences'].split(',')
- decision=options['decision']
- outputMap= options['outputMap']
- outputTxt= options['outputTxt']
- out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
- infosystem=FileToInfoSystem(out)
- UnionOfClasses(infosystem)
- DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
- UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
- Dominating=DominatingSet(infosystem)
- Dominated=DominatedSet(infosystem)
- ## upward union class
- print "elaborate upward union"
- Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
- Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
- UpwardBoundary=Boundaries(Uu, Lu)
- ## downward union class
- print "elaborate downward union"
- Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of downward union for type 3 rules
- Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of downward union
- DownwardBoundary=Boundaries(Ud, Ld)
- QualityOfQpproximation(DownwardBoundary, infosystem)
- print "RULES extraction (*)"
- RULES=Domlem(Lu,Ld, infosystem)
- Parser_mapcalc(RULES, outputMap)
- Print_rules(RULES, outputTxt)
- end=time()
- print "Time computing-> %.4f s" % (end-start)
- return 0
- except:
- print "ERROR in main function!"
- sys.exit()
+ try:
+ start=time()
+ attributes = options['criteria'].split(',')
+ preferences=options['preferences'].split(',')
+ decision=options['decision']
+ outputMap= options['outputMap']
+ outputTxt= options['outputTxt']
+ out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
+ infosystem=FileToInfoSystem(out)
+ UnionOfClasses(infosystem)
+ DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
+ UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
+ Dominating=DominatingSet(infosystem)
+ Dominated=DominatedSet(infosystem)
+ ## upward union class
+ print "elaborate upward union"
+ Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
+ Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
+ UpwardBoundary=Boundaries(Uu, Lu)
+ ## downward union class
+ print "elaborate downward union"
+ Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of downward union for type 3 rules
+ Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of downward union
+ DownwardBoundary=Boundaries(Ud, Ld)
+ QualityOfQpproximation(DownwardBoundary, infosystem)
+ print "RULES extraction (*)"
+ RULES=Domlem(Lu,Ld, infosystem)
+ Parser_mapcalc(RULES, outputMap)
+ Print_rules(RULES, outputTxt)
+ end=time()
+ print "Time computing-> %.4f s" % (end-start)
+ return 0
+ except:
+ print "ERROR! Rules does not generated!"
+ sys.exit()
if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+ options, flags = grass.parser()
+ sys.exit(main())
