[GRASS-SVN] r53360 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Thu Oct 11 04:13:13 PDT 2012
Author: martinl
Date: 2012-10-11 04:13:13 -0700 (Thu, 11 Oct 2012)
New Revision: 53360
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: menu for extensions
(merge r53358 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-10-11 11:08:51 UTC (rev 53359)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-10-11 11:13:13 UTC (rev 53360)
@@ -870,8 +870,11 @@
</items>
</menu>
<separator />
+ <menu>
+ <label>Addons extensions</label>
+ <items>
<menuitem>
- <label>Install extension from add-ons</label>
+ <label>Install extension from addons</label>
<help>Installs new extension from GRASS AddOns SVN repository.</help>
<keywords>general,extensions</keywords>
<handler>OnInstallExtension</handler>
@@ -885,12 +888,14 @@
<command>g.extension.rebuild.all.py</command>
</menuitem>
<menuitem>
- <label>Remove extension</label>
+ <label>Uninstall extension</label>
<help>Removes installed GRASS AddOns extension.</help>
<handler>OnUninstallExtension</handler>
<command>g.extension</command>
</menuitem>
+ </items>
+ </menu>
<separator />
<menuitem>
<label>Preferences</label>
