[GRASS-SVN] r53368 - in grass/trunk/gui/wxpython: . gui_core lmgr
svn_grass at osgeo.org
Thu Oct 11 13:30:12 PDT 2012
Author: martinl
Date: 2012-10-11 13:30:12 -0700 (Thu, 11 Oct 2012)
New Revision: 53368
grass/trunk/gui/wxpython/gui_core/ghelp.py
grass/trunk/gui/wxpython/gui_core/menu.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI: move MenuTree and MenuTreeWindow from gui_core.ghelp to gui_core.menu
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-10-11 20:24:06 UTC (rev 53367)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-10-11 20:30:12 UTC (rev 53368)
@@ -5,8 +5,6 @@
Classes:
- ghelp::SearchModuleWindow
- - ghelp::MenuTreeWindow
- - ghelp::MenuTree
- ghelp::AboutWindow
- ghelp::HelpFrame
- ghelp::HelpWindow
@@ -39,9 +37,8 @@
from core import globalvar
from core import utils
-from lmgr.menudata import ManagerData
from core.gcmd import GError, DecodeString
-from gui_core.widgets import FormListbook, StaticWrapText, ItemTree, ScrolledPanel
+from gui_core.widgets import FormListbook, StaticWrapText, ScrolledPanel
from core.debug import Debug
from core.settings import UserSettings
@@ -193,202 +190,7 @@
if self.showTip:
self.searchTip.SetLabel('')
-class MenuTreeWindow(wx.Panel):
- """!Show menu tree"""
- def __init__(self, parent, id = wx.ID_ANY, **kwargs):
- self.parent = parent # LayerManager
- wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
- self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = " %s " % _("Menu tree (double-click to run command)"))
- # tree
- self.tree = MenuTree(parent = self, data = ManagerData())
- self.tree.Load()
- # search widget
- self.search = SearchModuleWindow(parent = self, showChoice = False)
- # buttons
- self.btnRun = wx.Button(self, id = wx.ID_OK, label = _("&Run"))
- self.btnRun.SetToolTipString(_("Run selected command"))
- self.btnRun.Enable(False)
- # bindings
- self.btnRun.Bind(wx.EVT_BUTTON, self.OnRun)
- self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
- self.tree.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnItemSelected)
- self.search.Bind(wx.EVT_TEXT_ENTER, self.OnShowItem)
- self.search.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
- self._layout()
- self.search.SetFocus()
- def _layout(self):
- """!Do dialog layout"""
- sizer = wx.BoxSizer(wx.VERTICAL)
- # body
- dataSizer = wx.StaticBoxSizer(self.dataBox, wx.HORIZONTAL)
- dataSizer.Add(item = self.tree, proportion =1,
- flag = wx.EXPAND)
- # buttons
- btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(item = self.btnRun, proportion = 0)
- sizer.Add(item = dataSizer, proportion = 1,
- flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = self.search, proportion = 0,
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALIGN_RIGHT | wx.BOTTOM | wx.RIGHT, border = 5)
- sizer.Fit(self)
- sizer.SetSizeHints(self)
- self.SetSizer(sizer)
- self.Fit()
- self.SetAutoLayout(True)
- self.Layout()
- def OnCloseWindow(self, event):
- """!Close window"""
- self.Destroy()
- def OnRun(self, event):
- """!Run selected command"""
- if not self.tree.GetSelected():
- return # should not happen
- data = self.tree.GetPyData(self.tree.GetSelected())
- if not data:
- return
- handler = 'self.parent.' + data['handler'].lstrip('self.')
- if data['handler'] == 'self.OnXTerm':
- wx.MessageBox(parent = self,
- message = _('You must run this command from the menu or command line',
- 'This command require an XTerm'),
- caption = _('Message'), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
- elif data['command']:
- eval(handler)(event = None, cmd = data['command'].split())
- else:
- eval(handler)(None)
- def OnShowItem(self, event):
- """!Show selected item"""
- self.tree.OnShowItem(event)
- if self.tree.GetSelected():
- self.btnRun.Enable()
- else:
- def OnItemActivated(self, event):
- """!Item activated (double-click)"""
- item = event.GetItem()
- if not item or not item.IsOk():
- return
- data = self.tree.GetPyData(item)
- if not data or 'command' not in data:
- return
- self.tree.itemSelected = item
- self.OnRun(None)
- def OnItemSelected(self, event):
- """!Item selected"""
- return
- return
- if data['command']:
- label = data['command'] + ' -- ' + data['description']
- else:
- label = data['description']
- self.parent.SetStatusText(label, 0)
- def OnUpdateStatusBar(self, event):
- """!Update statusbar text"""
- element = self.search.GetSelection()
- self.tree.SearchItems(element = element,
- value = event.GetString())
- nItems = len(self.tree.itemsMarked)
- if event.GetString():
- self.parent.SetStatusText(_("%d modules match") % nItems, 0)
- else:
- self.parent.SetStatusText("", 0)
- event.Skip()
-class MenuTree(ItemTree):
- """!Menu tree class"""
- def __init__(self, parent, data, **kwargs):
- self.menudata = data
- super(MenuTree, self).__init__(parent, **kwargs)
- self.menustyle = UserSettings.Get(group = 'appearance', key = 'menustyle', subkey = 'selection')
- def Load(self, data = None):
- """!Load menu data tree
- @param data menu data (None to use self.menudata)
- if not data:
- data = self.menudata
- self.itemsMarked = [] # list of marked items
- for eachMenuData in data.GetMenu():
- for label, items in eachMenuData:
- item = self.AppendItem(parentId = self.root,
- text = label.replace('&', ''))
- self.__AppendItems(item, items)
- def __AppendItems(self, item, data):
- """!Append items into tree (used by Load()
- @param item tree item (parent)
- @parent data menu data"""
- for eachItem in data:
- if len(eachItem) == 2:
- if eachItem[0]:
- itemSub = self.AppendItem(parentId = item,
- text = eachItem[0])
- self.__AppendItems(itemSub, eachItem[1])
- else:
- if eachItem[0]:
- label = eachItem[0]
- if eachItem[3]:
- if self.menustyle == 1:
- label += ' [' + eachItem[3] + ']'
- elif self.menustyle == 2:
- label = '[' + eachItem[3] + ']'
- itemNew = self.AppendItem(parentId = item,
- text = label)
- data = { 'item' : eachItem[0],
- 'description' : eachItem[1],
- 'handler' : eachItem[2],
- 'command' : eachItem[3],
- 'keywords' : eachItem[4] }
- self.SetPyData(itemNew, data)
class AboutWindow(wx.Frame):
"""!Create custom About Window
Modified: grass/trunk/gui/wxpython/gui_core/menu.py
--- grass/trunk/gui/wxpython/gui_core/menu.py 2012-10-11 20:24:06 UTC (rev 53367)
+++ grass/trunk/gui/wxpython/gui_core/menu.py 2012-10-11 20:30:12 UTC (rev 53368)
@@ -5,8 +5,10 @@
Classes:
- menu::Menu
+ - menu::MenuTreeWindow
+ - menu::MenuTree
-(C) 2010 by the GRASS Development Team
+(C) 2010-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -20,10 +22,13 @@
import wx
-from core import globalvar
-from core import utils
-from core.gcmd import EncodeString
-from core.settings import UserSettings
+from core import globalvar
+from core import utils
+from core.gcmd import EncodeString
+from core.settings import UserSettings
+from gui_core.widgets import ItemTree
+from lmgr.menudata import ManagerData
+from gui_core.ghelp import SearchModuleWindow
class Menu(wx.MenuBar):
def __init__(self, parent, data):
@@ -33,7 +38,7 @@
self.menucmd = dict()
- self.menustyle = UserSettings.Get(group='appearance', key='menustyle', subkey='selection')
+ self.menustyle = UserSettings.Get(group = 'appearance', key = 'menustyle', subkey = 'selection')
for eachMenuData in self.menudata.GetMenu():
for eachHeading in eachMenuData:
@@ -118,3 +123,199 @@
# but in this case just call Skip so the default is done
event.Skip()
+class MenuTreeWindow(wx.Panel):
+ """!Show menu tree"""
+ def __init__(self, parent, id = wx.ID_ANY, **kwargs):
+ self.parent = parent # LayerManager
+ wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
+ self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("Menu tree (double-click to run command)"))
+ # tree
+ self.tree = MenuTree(parent = self, data = ManagerData())
+ self.tree.Load()
+ # search widget
+ self.search = SearchModuleWindow(parent = self, showChoice = False)
+ # buttons
+ self.btnRun = wx.Button(self, id = wx.ID_OK, label = _("&Run"))
+ self.btnRun.SetToolTipString(_("Run selected command"))
+ self.btnRun.Enable(False)
+ # bindings
+ self.btnRun.Bind(wx.EVT_BUTTON, self.OnRun)
+ self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
+ self.tree.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnItemSelected)
+ self.search.Bind(wx.EVT_TEXT_ENTER, self.OnShowItem)
+ self.search.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
+ self._layout()
+ self.search.SetFocus()
+ def _layout(self):
+ """!Do dialog layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # body
+ dataSizer = wx.StaticBoxSizer(self.dataBox, wx.HORIZONTAL)
+ dataSizer.Add(item = self.tree, proportion =1,
+ flag = wx.EXPAND)
+ # buttons
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(item = self.btnRun, proportion = 0)
+ sizer.Add(item = dataSizer, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ sizer.Add(item = self.search, proportion = 0,
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.BOTTOM | wx.RIGHT, border = 5)
+ sizer.Fit(self)
+ sizer.SetSizeHints(self)
+ self.SetSizer(sizer)
+ self.Fit()
+ self.SetAutoLayout(True)
+ self.Layout()
+ def OnCloseWindow(self, event):
+ """!Close window"""
+ self.Destroy()
+ def OnRun(self, event):
+ """!Run selected command"""
+ if not self.tree.GetSelected():
+ return # should not happen
+ data = self.tree.GetPyData(self.tree.GetSelected())
+ if not data:
+ return
+ handler = 'self.parent.' + data['handler'].lstrip('self.')
+ if data['handler'] == 'self.OnXTerm':
+ wx.MessageBox(parent = self,
+ message = _('You must run this command from the menu or command line',
+ 'This command require an XTerm'),
+ caption = _('Message'), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ elif data['command']:
+ eval(handler)(event = None, cmd = data['command'].split())
+ else:
+ eval(handler)(None)
+ def OnShowItem(self, event):
+ """!Show selected item"""
+ self.tree.OnShowItem(event)
+ if self.tree.GetSelected():
+ self.btnRun.Enable()
+ else:
+ def OnItemActivated(self, event):
+ """!Item activated (double-click)"""
+ item = event.GetItem()
+ if not item or not item.IsOk():
+ return
+ data = self.tree.GetPyData(item)
+ if not data or 'command' not in data:
+ return
+ self.tree.itemSelected = item
+ self.OnRun(None)
+ def OnItemSelected(self, event):
+ """!Item selected"""
+ return
+ return
+ if data['command']:
+ label = data['command'] + ' -- ' + data['description']
+ else:
+ label = data['description']
+ self.parent.SetStatusText(label, 0)
+ def OnUpdateStatusBar(self, event):
+ """!Update statusbar text"""
+ element = self.search.GetSelection()
+ self.tree.SearchItems(element = element,
+ value = event.GetString())
+ nItems = len(self.tree.itemsMarked)
+ if event.GetString():
+ self.parent.SetStatusText(_("%d modules match") % nItems, 0)
+ else:
+ self.parent.SetStatusText("", 0)
+ event.Skip()
+class MenuTree(ItemTree):
+ """!Menu tree class"""
+ def __init__(self, parent, data, **kwargs):
+ self.menudata = data
+ super(MenuTree, self).__init__(parent, **kwargs)
+ def Load(self, data = None):
+ """!Load menu data tree
+ @param data menu data (None to use self.menudata)
+ if not data:
+ data = self.menudata
+ self.itemsMarked = [] # list of marked items
+ for eachMenuData in data.GetMenu():
+ for label, items in eachMenuData:
+ item = self.AppendItem(parentId = self.root,
+ text = label.replace('&', ''))
+ self.__AppendItems(item, items)
+ def __AppendItems(self, item, data):
+ """!Append items into tree (used by Load()
+ @param item tree item (parent)
+ @parent data menu data"""
+ for eachItem in data:
+ if len(eachItem) == 2:
+ if eachItem[0]:
+ itemSub = self.AppendItem(parentId = item,
+ text = eachItem[0])
+ self.__AppendItems(itemSub, eachItem[1])
+ else:
+ if eachItem[0]:
+ label = eachItem[0]
+ if eachItem[3]:
+ if self.menustyle == 1:
+ label += ' [' + eachItem[3] + ']'
+ elif self.menustyle == 2:
+ label = '[' + eachItem[3] + ']'
+ itemNew = self.AppendItem(parentId = item,
+ text = label)
+ data = { 'item' : eachItem[0],
+ 'description' : eachItem[1],
+ 'handler' : eachItem[2],
+ 'command' : eachItem[3],
+ 'keywords' : eachItem[4] }
+ self.SetPyData(itemNew, data)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-10-11 20:24:06 UTC (rev 53367)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-10-11 20:30:12 UTC (rev 53368)
@@ -53,12 +53,12 @@
from gui_core.dialogs import EVT_APPLY_MAP_LAYERS
from gui_core.dialogs import LocationDialog, MapsetDialog, CreateNewVector, GroupDialog
from modules.colorrules import RasterColorTable, VectorColorTable
-from gui_core.menu import Menu
+from gui_core.menu import Menu, MenuTreeWindow
from gmodeler.model import Model
from gmodeler.frame import ModelFrame
from psmap.frame import PsMapFrame
-from gui_core.ghelp import MenuTreeWindow, AboutWindow
+from gui_core.ghelp import AboutWindow
from modules.extensions import InstallExtensionWindow, UninstallExtensionWindow
from lmgr.toolbars import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar
from lmgr.toolbars import LMMiscToolbar, LMVectorToolbar, LMNvizToolbar
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2012-10-11 20:24:06 UTC (rev 53367)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2012-10-11 20:30:12 UTC (rev 53368)
@@ -112,8 +112,6 @@
- forms::GrassGUIApp
- gui_core::ghelp
- - ghelp::MenuTree
- ghelp::HelpFrame
- ghelp::HelpWindow
@@ -151,6 +149,8 @@
- mapwindow::MapWindow
- gui_core::menu
- menu::Menu
+ - menu::MenuTree
- gui_core::preferences
- preferences::PreferencesBaseDialog
- preferences::PreferencesDialog
