[GRASS-SVN] r53375 - grass/trunk/scripts/g.extension
Fri Oct 12 07:41:56 PDT 2012
Author: lucadelu
Date: 2012-10-12 07:41:55 -0700 (Fri, 12 Oct 2012)
New Revision: 53375
   grass/trunk/scripts/g.extension/g.extension.py
fix hardcoded url for modules.xml; clean code using spyder
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2012-10-12 12:54:26 UTC (rev 53374)
+++ grass/trunk/scripts/g.extension/g.extension.py	2012-10-12 14:41:55 UTC (rev 53375)
@@ -111,10 +111,8 @@
 import re
 import atexit
 import shutil
-import glob
 import zipfile
 import tempfile
-import shutil
 from urllib2 import urlopen, HTTPError
@@ -133,7 +131,7 @@
     for prog in ('svn', 'make', 'gcc'):
         if not grass.find_program(prog, ['--help']):
             grass.fatal(_("'%s' required. Please install '%s' first.") % (prog, prog))
 # expand prefix to class name
 def expand_module_class_name(c):
     name = { 'd'   : 'display',
@@ -149,7 +147,7 @@
              'v'   : 'vector',
              'wx'  : 'gui/wxpython'
     return name.get(c, c)
 # list installed extensions
@@ -159,6 +157,7 @@
     return get_installed_modules(force)
 def get_installed_toolboxes(force = False):
     fXML = os.path.join(options['prefix'], 'toolboxes.xml')
     if not os.path.exists(fXML):
@@ -173,13 +172,14 @@
         write_xml_toolboxes(fXML)
         return []
     fo.close()
     ret = list()
     for tnode in tree.findall('toolbox'):
         ret.append(tnode.get('code'))
     return ret
 def get_installed_modules(force = False):
     fXML = os.path.join(options['prefix'], 'modules.xml')
@@ -188,7 +188,7 @@
         else:
             grass.warning(_("No metadata file available"))
         return []
     # read XML file
     fo = open(fXML, 'r')
     try:
@@ -198,18 +198,18 @@
         write_xml_modules(fXML)
         return []
     fo.close()
     ret = list()
     for tnode in tree.findall('task'):
         ret.append(tnode.get('name').strip())
     return ret
 # list extensions (read XML file from grass.osgeo.org/addons)
-def list_available_extensions():
+def list_available_extensions(url):
     if flags['t']:
         grass.message(_("List of available extensions (toolboxes):"))
-        tlist = list_available_toolboxes()
+        tlist = list_available_toolboxes(url)
         for toolbox_code, toolbox_data in tlist.iteritems():
             if flags['g']:
                 print 'toolbox_name=' + toolbox_data['name']
@@ -217,18 +217,18 @@
             else:
                 print '%s (%s)' % (toolbox_data['name'], toolbox_code)
             if flags['c'] or flags['g']:
-                list_available_modules(toolbox_data['modules'])
+                list_available_modules(url, toolbox_data['modules'])
             else:
                 if toolbox_data['modules']:
                     print os.linesep.join(map(lambda x: '* ' + x, toolbox_data['modules']))
     else:
         grass.message(_("List of available extensions (modules):"))
-        list_available_modules()
-def list_available_toolboxes():
+        list_available_modules(url)
+def list_available_toolboxes(url):
     tdict = dict()
-    url = "http://grass.osgeo.org/addons/grass%s/toolboxes.xml" % version[0]
+    url = url + "toolboxes.xml"
     try:
         f = urlopen(url)
         tree = etree.fromstring(f.read())
@@ -238,37 +238,40 @@
             tdict[tnode.get('code')] = { 'name' : tnode.get('name'),
                                          'correlate' : clist,
                                          'modules' : mlist }
             for cnode in tnode.findall('correlate'):
                 clist.append(cnode.get('name'))
             for mnode in tnode.findall('task'):
                 mlist.append(mnode.get('name'))
     except HTTPError:
         grass.fatal(_("Unable to fetch metadata file"))
     return tdict
-def get_toolbox_modules(name):
+def get_toolbox_modules(url, name):
     tlist = list()
     try:
         f = urlopen(url)
             if name == tnode.get('code'):
-                  tlist.append(mnode.get('name'))
+                    tlist.append(mnode.get('name'))
                 break
     except HTTPError:
     return tlist
-def list_available_modules(mlist = None):
+def list_available_modules(url, mlist = None):
     # try to download XML metadata file first
-    url = "http://grass.osgeo.org/addons/grass%s/modules.xml" % version[0]
+    url = url + "modules.xml"
     grass.debug("url=%s" % url, 1)
     try:
         f = urlopen(url)
@@ -276,7 +279,7 @@
         except:
             grass.fatal(_("Unable to parse '%s'") % url)
         for mnode in tree.findall('task'):
             name = mnode.get('name').strip()
             if mlist and name not in mlist:
@@ -288,7 +291,7 @@
                 keyw = mnode.find('keywords').text
                 if not keyw:
                     keyw = ''
             if flags['g']:
                 print 'name=' + name
                 print 'description=' + desc
@@ -311,14 +314,13 @@
         grass.warning(_("Flag 'c' ignored, metadata file not available"))
     if flags['g']:
         grass.warning(_("Flag 'g' ignored, metadata file not available"))
     prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
               'p', 'r', 'r3', 's', 'v']
-    nprefix = len(prefix)
     for d in prefix:
         modclass = expand_module_class_name(d)
         grass.verbose(_("Checking for '%s' modules...") % modclass)
         url = '%s/%s' % (options['svnurl'], modclass)
         grass.debug("url = %s" % url, debug = 2)
         try:
@@ -326,7 +328,7 @@
         except HTTPError:
             grass.debug(_("Unable to fetch '%s'") % url, debug = 1)
             continue
         for line in f.readlines():
             # list extensions
             sline = pattern.search(line)
@@ -335,7 +337,7 @@
             name = sline.group(2).rstrip('/')
             if name.split('.', 1)[0] == d:
                 print name
     # get_wxgui_extensions()
 # list wxGUI extensions
@@ -344,14 +346,14 @@
     grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
     pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
     grass.verbose(_("Checking for '%s' modules...") % 'gui/wxpython')
     url = '%s/%s' % (options['svnurl'], 'gui/wxpython')
     f = urlopen(url)
     if not f:
         grass.warning(_("Unable to fetch '%s'") % url)
         return
         # list extensions
@@ -360,9 +362,10 @@
         if name not in ('..', 'Makefile'):
             mlist.append(name)
     return mlist
 def cleanup():
     if remove_tmpdir:
         grass.try_rmdir(tmpdir)
@@ -394,16 +397,17 @@
                 for fnode in bnode.findall('file'):
                     fo.write('%s<file>%s</file>\n' % \
                                  (' ' * indent, os.path.join(options['prefix'], fnode.text)))
-                indent -= 4
+                indent -= 4
                 fo.write('%s</binary>\n' % (' ' * indent))
             fo.write('%s<libgis revision="%s" />\n' % \
                          (' ' * indent, libgisRev))
             indent -= 4
             fo.write('%s</task>\n' % (' ' * indent))
     fo.write('</addons>\n')
     fo.close()
 def write_xml_toolboxes(name, tree = None):
     fo = open(name, 'w')
     fo.write('<?xml version="1.0" encoding="UTF-8"?>\n')
@@ -423,28 +427,28 @@
                          (' ' * indent, mnode.get('name')))
             indent -= 4
             fo.write('%s</toolbox>\n' % (' ' * indent))
     fo.close()
 # install extension - toolbox or module
-def install_extension():
+def install_extension(url):
     gisbase = os.getenv('GISBASE')
     if not gisbase:
         grass.fatal(_('$GISBASE not defined'))
     if options['extension'] in get_installed_extensions(force = True):
         grass.warning(_("Extension <%s> already installed. Re-installing...") % options['extension'])
     if flags['t']:
         grass.message(_("Installing toolbox <%s>...") % options['extension'])
-        mlist = get_toolbox_modules(options['extension'])
+        mlist = get_toolbox_modules(url, options['extension'])
     else:
         mlist = [options['extension']]
     if not mlist:
         grass.warning(_("Nothing to install"))
         return
     ret = 0
     for module in mlist:
         if sys.platform == "win32":
@@ -456,10 +460,10 @@
         if not flags['d']:
             grass.verbose(_("Updating manual page for <%s>...") % module)
             update_manual_page(module)
     if flags['d']:
         return
     if ret != 0:
         grass.warning(_('Installation failed, sorry. Please check above error messages.'))
     else:
@@ -472,9 +476,10 @@
                         'GRASS_ADDON_BASE environment variable (see "g.manual variables")'))
 # update local meta-file when installing new extension (toolbox / modules)
-def install_toolbox_xml(name):
+def install_toolbox_xml(url, name):
     # read metadata from remote server (toolboxes)
     data = dict()
     try:
         f = urlopen(url)
@@ -483,11 +488,11 @@
             clist = list()
                 clist.append(cnode.get('code'))
             mlist = list()
             code = tnode.get('code')
             data[code] = {
@@ -496,31 +501,31 @@
     except HTTPError:
         grass.error(_("Unable to read metadata file from the remote server"))
     if not data:
         grass.warning(_("No metadata available"))
         return
     if name not in data:
         grass.warning(_("No metadata available for <%s>") % name)
         return
     # create an empty file if not exists
     # read XML file
     tree = etree.fromstring(fo.read())
     fo.close()
     # update tree
     tnode = None
     for node in tree.findall('toolbox'):
         if node.get('code') == name:
             tnode = node
             break
     tdata = data[name]
     if tnode is not None:
         # update existing node
@@ -532,23 +537,25 @@
         # create new node for task
         tnode = etree.Element('toolbox', attrib = { 'name' : tdata['name'], 'code' : name })
         tree.append(tnode)
     for cname in tdata['correlate']:
         cnode = etree.Element('correlate', attrib = { 'code' : cname })
         tnode.append(cnode)
     for tname in tdata['modules']:
         mnode = etree.Element('task', attrib = { 'name' : tname })
         tnode.append(mnode)
     write_xml_toolboxes(fXML, tree)
-def install_extension_xml(mlist):
+def install_extension_xml(url, mlist):
     if len(mlist) > 1:
-        install_toolbox_xml(options['extension'])
+        install_toolbox_xml(url, options['extension'])
     # read metadata from remote server (modules)
     data = {}
     try:
         f = urlopen(url)
@@ -557,7 +564,7 @@
             if name not in mlist:
                 continue
             fList = list()
             bnode = mnode.find('binary')
             windows = sys.platform == 'win32'
@@ -570,23 +577,23 @@
                         if path[0] == 'scripts':
                             path[-1] += '.py'
                     fList.append(os.path.sep.join(path))
             desc = mnode.find('description').text
             if not desc:
                 desc = ''
             if not keyw:
                 keyw = ''
             data[name] = {
                 'desc'  : desc,
                 'keyw'  : keyw,
                 'files' : fList,
     except HTTPError:
     if not data:
         return
@@ -595,12 +602,12 @@
     # read XML file
     fo.close()
     # update tree
     for name in mlist:
         tnode = None
@@ -608,11 +615,11 @@
             if node.get('name') == name:
                 tnode = node
                 break
             grass.warning(_("No metadata found for <%s>") % name)
             continue
         ndata = data[name]
@@ -647,23 +654,23 @@
                 bnode.append(fnode)
             tnode.append(bnode)
             tree.append(tnode)
     write_xml_modules(fXML, tree)
 # install extension on MS Windows
 def install_extension_win(name):
     ### TODO: do not use hardcoded url - http://wingrass.fsv.cvut.cz/grassXX/addonsX.X.X
     grass.message(_("Downloading precompiled GRASS Addons <%s>...") % options['extension'])
     url = "http://wingrass.fsv.cvut.cz/grass%s%s/addons" % (version[0], version[1])
     try:
         f = urlopen(url + '/' + name + '.zip')
         # create addons dir if not exists
         if not os.path.exists(options['prefix']):
             os.mkdir(options['prefix'])
         # download data
         fo = tempfile.TemporaryFile()
         fo.write(f.read())
@@ -677,11 +684,11 @@
                 outfile = open(os.path.join(options['prefix'], name), 'wb')
                 outfile.write(zfobj.read(name))
                 outfile.close()
         fo.close()
     except HTTPError:
         grass.fatal(_("GRASS Addons <%s> not found") % name)
     return 0
 # install extension on other plaforms
@@ -692,19 +699,19 @@
     url = options['svnurl'] + '/' + moduleclass + '/' + name
     if classchar == 'wx' and not flags['s']:
         grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
     grass.message(_("Fetching <%s> from GRASS-Addons SVN (be patient)...") % name)
     os.chdir(tmpdir)
     if grass.verbosity() <= 2:
         outdev = open(os.devnull, 'w')
     else:
         outdev = sys.stdout
     if grass.call(['svn', 'checkout',
                    url], stdout = outdev) != 0:
     dirs = { 'bin'     : os.path.join(tmpdir, name, 'bin'),
              'docs'    : os.path.join(tmpdir, name, 'docs'),
              'html'    : os.path.join(tmpdir, name, 'docs', 'html'),
@@ -713,7 +720,7 @@
              'scripts' : os.path.join(tmpdir, name, 'scripts'),
              'etc'     : os.path.join(tmpdir, name, 'etc'),
     if classchar != 'wx':
         makeCmd = ['make',
                    'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
@@ -722,56 +729,56 @@
                    'RESTDIR=%s' % dirs['rest'],
                    'MANDIR=%s' % dirs['man'],
                    'SCRIPTDIR=%s' % dirs['scripts'],
-                   'ETC=%s' % os.path.join(dirs['etc'],name)
+                   'ETC=%s' % os.path.join(dirs['etc'], name)
     else:
         makeCmd = ['make',
     installCmd = ['make',
                   'MODULE_TOPDIR=%s' % gisbase,
                   'ARCH_DISTDIR=%s' % os.path.join(tmpdir, name),
                   'INST_DIR=%s' % options['prefix'],
                   'install'
     if flags['d']:
         grass.message(_("To compile run:"))
         sys.stderr.write(' '.join(makeCmd) + '\n')
         grass.message(_("To install run:"))
         sys.stderr.write(' '.join(installCmd) + '\n')
         return 0
     os.chdir(os.path.join(tmpdir, name))
     grass.message(_("Compiling..."))
     if 0 != grass.call(makeCmd,
                        stdout = outdev):
         grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
     if flags['i'] or classchar == 'wx':
         return 0
     grass.message(_("Installing..."))
     return grass.call(installCmd,
                       stdout = outdev)
 # remove existing extension - toolbox or module
 def remove_extension(force = False):
     if flags['t']:
     else:
     if force:
         grass.verbose(_("List of removed files:"))
     else:
         grass.info(_("Files to be removed (use flag 'f' to force removal):"))
     remove_modules(mlist, force)
     if force:
         grass.message(_("Updating metadata file..."))
         remove_extension_xml(mlist)
@@ -779,26 +786,26 @@
     else:
         grass.warning(_("Extension <%s> not removed.\n"
                         "Re-run '%s' with 'f' flag to force removal") % (options['extension'], 'g.extension'))
 # remove existing extension(s) (reading XML file)
 def remove_modules(mlist, force = False):
     # try to read XML metadata file first
     installed = get_installed_modules()
     if os.path.exists(fXML):
         f = open(fXML, 'r')
         f.close()
     else:
         tree = None
     for name in mlist:
         if name not in installed:
             # try even if module does not seem to be available,
             # as the user may be trying to get rid of left over cruft
             grass.warning(_("Extension <%s> not found") % name)
         if tree is not None:
             flist = []
             for task in tree.findall('task'):
@@ -807,7 +814,7 @@
                     for f in task.find('binary').findall('file'):
                         flist.append(f.text)
                     break
             if flist:
                 removed = False
                 err = list()
@@ -823,7 +830,7 @@
                         err.append((_("Unable to remove file '%s'") % fpath))
                 if force and not removed:
                     grass.fatal(_("Extension <%s> not found") % name)
                 if err:
                     for e in err:
                         grass.error(e)
@@ -831,7 +838,7 @@
                 remove_extension_std(name, force)
         else:
 # remove exising extension (using standard files layout)
 def remove_extension_std(name, force = False):
     for fpath in [os.path.join(options['prefix'], 'bin', name),
@@ -851,19 +858,19 @@
         return
     # read XML file
     fo.close()
         if node.get('code') != name:
             continue
         tree.remove(node)
 def remove_extension_xml(modules):
     if len(modules) > 1:
         # update also toolboxes metadata
@@ -872,20 +879,20 @@
         return
     # read XML file
     fo.close()
     for name in modules:
         for node in tree.findall('task'):
             if node.get('name') != name:
                 continue
             tree.remove(node)
 # check links in CSS
 def check_style_files(fil):
     dist_file   = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
@@ -895,19 +902,19 @@
         return
     try:
-        shutil.copyfile(dist_file,addons_file)
+        shutil.copyfile(dist_file, addons_file)
     except OSError, e:
         grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
 def create_dir(path):
     if os.path.isdir(path):
         return
     try:
         os.makedirs(path)
     except OSError, e:
         grass.fatal(_("Unable to create '%s': %s") % (path, e))
     grass.debug("'%s' created" % path)
 def check_dirs():
@@ -924,7 +931,7 @@
 def update_manual_page(module):
     if module.split('.', 1)[0] == 'wx':
         return # skip for GUI modules
     # read original html file
     htmlfile = os.path.join(options['prefix'], 'docs', 'html', module + '.html')
     try:
@@ -945,17 +952,17 @@
         if match.group(1).replace('.html', '') in addons:
             continue
         pos.append(match.start(1))
     if not pos:
         return # no match
     # replace file URIs
     prefix = 'file://' + '/'.join([os.getenv('GISBASE'), 'docs', 'html'])
     ohtml = shtml[:pos[0]]
     for i in range(1, len(pos)):
         ohtml += prefix + '/' + shtml[pos[i-1]:pos[i]]
     ohtml += prefix + '/' + shtml[pos[-1]:]
     # write updated html file
     try:
         f = open(htmlfile, 'w')
@@ -964,27 +971,33 @@
         grass.fatal(_("Unable for write manual page: %s") % e)
     else:
         f.close()
 def main():
     # check dependecies
     if sys.platform != "win32":
         check_progs()
     # define path
     if flags['s']:
         options['prefix'] = os.environ['GISBASE']
     if options['prefix'] == '$GRASS_ADDON_BASE':
         if not os.getenv('GRASS_ADDON_BASE'):
-            major_version = int(grass.version()['version'].split('.', 1)[0])
             grass.warning(_("GRASS_ADDON_BASE is not defined, "
                             "installing to ~/.grass%s/addons") % version[0])
             options['prefix'] = os.path.join(os.environ['HOME'], '.grass%s' % version[0], 'addons')
         else:
             options['prefix'] = os.environ['GRASS_ADDON_BASE']
+    if options['svnurl'] == 'http://svn.osgeo.org/grass/grass-addons/grass7':
+        xmlurl = "http://grass.osgeo.org/addons/grass%s" % version[0]
+    else:
+        xmlurl = options['svnurl']
+    if not xmlurl.endswith('/'):
+        xmlurl = xmlurl + "/"
     # list available extensions
     if flags['l'] or flags['c'] or flags['g']:
-        list_available_extensions()
+        list_available_extensions(xmlurl)
         return 0
     elif flags['a']:
         elist = get_installed_extensions()
@@ -1004,20 +1017,20 @@
     else:
         if not options['extension']:
             grass.fatal(_('You need to define an extension name or use -l/c/g/a'))
     if flags['d']:
         if options['operation'] != 'add':
             grass.warning(_("Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."))
         else:
             global remove_tmpdir
             remove_tmpdir = False
     if options['operation'] == 'add':
         check_dirs()
-        install_extension()
+        install_extension(xmlurl)
     else: # remove
         remove_extension(flags['f'])
     return 0
 if __name__ == "__main__":
