[GRASS-SVN] r53377 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Oct 13 00:43:07 PDT 2012
Author: mmetz
Date: 2012-10-13 00:43:06 -0700 (Sat, 13 Oct 2012)
New Revision: 53377
grass/trunk/lib/vector/Vlib/net.c
Vlib: fix node costs for new topology
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2012-10-12 16:23:22 UTC (rev 53376)
+++ grass/trunk/lib/vector/Vlib/net.c 2012-10-13 07:43:06 UTC (rev 53377)
@@ -335,6 +335,12 @@
/* Set node attributes */
G_debug(2, "Register nodes");
if (ncol != NULL) {
+ double x, y, z;
+ struct bound_box box;
+ struct boxlist *List;
+ List = Vect_new_boxlist(0);
G_debug(2, "Set nodes' costs");
if (nfield < 1)
G_fatal_error("Node field < 1");
@@ -372,12 +378,19 @@
/* TODO: what happens if we set attributes of not existing node (skipped lines,
* nodes without lines) */
- nlines = Vect_get_node_n_lines(Map, i);
- G_debug(2, " node = %d nlines = %d", i, nlines);
+ /* select points at node */
+ Vect_get_node_coor(Map, i, &x, &y, &z);
+ box.E = box.W = x;
+ box.N = box.S = y;
+ box.T = box.B = z;
+ Vect_select_lines_by_box(Map, &box, GV_POINT, List);
+ G_debug(2, " node = %d nlines = %d", i, List->n_values);
cfound = 0;
dcost = 0;
- for (j = 0; j < nlines; j++) {
- line = Vect_get_node_line(Map, i, j);
+ for (j = 0; j < List->n_values; j++) {
+ line = List->id[i];
G_debug(2, " line (%d) = %d", j, line);
type = Vect_read_line(Map, NULL, Cats, line);
if (!(type & GV_POINT))
@@ -420,6 +433,8 @@
db_close_database_shutdown_driver(driver);
db_CatValArray_free(&fvarr);
+ Vect_destroy_boxlist(List);
G_message(_("Flattening the graph..."));
