[GRASS-SVN] r53386 - grass/trunk/imagery/i.pca
svn_grass at osgeo.org
Sat Oct 13 04:56:05 PDT 2012
Author: mmetz
Date: 2012-10-13 04:56:04 -0700 (Sat, 13 Oct 2012)
New Revision: 53386
grass/trunk/imagery/i.pca/i.pca.html
grass/trunk/imagery/i.pca/main.c
grass/trunk/imagery/i.pca/support.c
i.pca: add filtering option to remove noise
Modified: grass/trunk/imagery/i.pca/i.pca.html
--- grass/trunk/imagery/i.pca/i.pca.html 2012-10-13 11:40:49 UTC (rev 53385)
+++ grass/trunk/imagery/i.pca/i.pca.html 2012-10-13 11:56:04 UTC (rev 53386)
@@ -38,6 +38,14 @@
maps are normalized for each map separately with <em>(x - mean) / stddev</em>.
Normalizing is highly recommended when the input raster maps have different
units, e.g. represent different environmental parameters.
+<dt><b>-f</b> <em>output will be filtered input bands</em>
+<dd>This option, together with the <em>percent</em> option, can be used
+to remove noise from input bands. Input bands will be recalculated from
+a subset of the principal components. The subset is selected by using
+only the most important (highest eigenvalue) principal components which
+explain together <em>percent</em> percent variance observed in the
+input bands.
</dl>
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2012-10-13 11:40:49 UTC (rev 53385)
+++ grass/trunk/imagery/i.pca/main.c 2012-10-13 11:56:04 UTC (rev 53386)
@@ -37,7 +37,7 @@
static int set_output_scale(struct Option *, int *, int *, int *);
static int calc_mu_cov(int *, double **, double *, double *, int);
static int write_pca(double **, double *, double *, int *, char *, int,
- int, int, int);
+ int, int, int, int);
#ifdef PCA_DEBUG
static int dump_eigen(int, double **, double *);
@@ -48,6 +48,8 @@
int i; /* Loop control variables */
int bands; /* Number of image bands */
+ int pcbands; /* Number of pc scores to use for filtering */
+ int pcperc; /* cumulative percent to use for filtering */
double *mu; /* Mean vector for image bands */
double *stddev; /* Stddev vector for image bands */
double **covar; /* Covariance Matrix */
@@ -57,8 +59,8 @@
int scale, scale_max, scale_min;
struct GModule *module;
- struct Option *opt_in, *opt_out, *opt_scale;
- struct Flag *flag_norm;
+ struct Option *opt_in, *opt_out, *opt_scale, *opt_filt;
+ struct Flag *flag_norm, *flag_filt;
/* initialize GIS engine */
G_gisinit(argv[0]);
@@ -95,10 +97,27 @@
_("For no rescaling use 0,0");
opt_scale->guisection = _("Rescale");
+ opt_filt = G_define_option();
+ opt_filt->key = "percent";
+ opt_filt->type = TYPE_INTEGER;
+ opt_filt->required = NO;
+ opt_filt->options = "50-99";
+ opt_filt->answer = "99";
+ opt_filt->label =
+ _("Cumulative percent importance for filtering");
+ opt_filt->guisection = _("Filter");
flag_norm = G_define_flag();
flag_norm->key = 'n';
- flag_norm->description = (_("Normalize (center and scale) input maps"));
+ flag_norm->label = (_("Normalize (center and scale) input maps"));
+ flag_norm->description = (_("Default: center only"));
+ flag_filt = G_define_flag();
+ flag_filt->key = 'f';
+ flag_filt->label = (_("Output will be filtered input bands"));
+ flag_filt->description = (_("Applies inverse PCA after PCA"));
+ flag_filt->guisection = _("Filter");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -117,6 +136,16 @@
/* get scale parameters */
set_output_scale(opt_scale, &scale, &scale_min, &scale_max);
+ /* filter threshold */
+ pcperc = -1;
+ if (flag_filt->answer) {
+ pcperc = atoi(opt_filt->answer);
+ if (pcperc < 0)
+ G_fatal_error(_("'%s' must be positive"), opt_filt->key);
+ if (pcperc > 99)
+ G_fatal_error(_("'%s' must be < 100"), opt_filt->key);
/* allocate memory */
covar = G_alloc_matrix(bands, bands);
mu = G_alloc_vector(bands);
@@ -157,9 +186,34 @@
G_debug(1, "Transposing eigen matrix...");
G_math_d_A_T(eigmat, bands);
+ pcbands = 0;
+ double eigval_total = 0.0;
+ double eigval_perc = 0.0;
+ for (i = 0; i < bands; i++) {
+ eigval_total += eigval[i];
+ eigval_perc += eigval[i] * 100. / eigval_total;
+ pcbands++;
+ if (eigval_perc > pcperc)
+ break;
+ /* filtering has an effect only if at least one PC is removed */
+ if (pcbands == bands)
+ pcbands--;
+ if (pcbands < 2)
+ G_fatal_error(_("Not enough principal components left for filtering"));
+ G_message(_("Using %d of %d principal components for filtering"), pcbands, bands);
+ scale = 0;
/* write output images */
write_pca(eigmat, mu, stddev, inp_fd, opt_out->answer, bands,
- scale, scale_min, scale_max);
+ scale, scale_min, scale_max, pcbands);
/* write colors and history to output */
@@ -170,7 +224,7 @@
/* write colors and history to file */
write_support(bands, outname, eigmat, eigval);
- /* close output file */
+ /* close input files */
Rast_unopen(inp_fd[i]);
@@ -328,7 +382,7 @@
static int
write_pca(double **eigmat, double *mu, double *stddev,
int *inp_fd, char *out_basename, int bands,
- int scale, int scale_min, int scale_max)
+ int scale, int scale_min, int scale_max, int fbands)
int i, j;
void **outbuf = (void **) G_malloc(bands * sizeof(void *));
@@ -345,10 +399,14 @@
int outcell_mapsiz = Rast_cell_size(outmap_type);
int *out_fd = (int *) G_malloc(bands * sizeof(int));
DCELL **inbuf = (DCELL **) G_malloc(bands * sizeof(DCELL *));
+ DCELL *pcs = NULL;
/* 2 passes for rescale. 1 pass for no rescale */
int PASSES = (scale) ? 2 : 1;
+ if (fbands)
+ pcs = (DCELL *) G_malloc(fbands * sizeof(DCELL));
/* allocate memory for row buffers */
char name[GNAME_MAX];
@@ -400,18 +458,47 @@
continue;
+ if (fbands) {
+ /* calculate all PC scores */
+ for (i = 0; i < fbands; i++) {
+ DCELL dval = 0.;
+ for (j = 0; j < bands; j++) {
+ /* corresp. cell of j-th band */
+ if (stddev)
+ dval += eigmat[i][j] *
+ ((inbuf[j][col] - mu[j]) / stddev[j]);
+ else
+ dval += eigmat[i][j] * (inbuf[j][col] - mu[j]);
+ pcs[i] = dval;
DCELL dval = 0.;
- for (j = 0; j < bands; j++) {
- /* corresp. cell of j-th band */
+ if (fbands) {
+ for (j = 0; j < fbands; j++) {
+ /* corresp. PC score of j-th band */
+ dval += eigmat[j][i] * pcs[j];
if (stddev)
- dval += eigmat[i][j] *
- ((inbuf[j][col] - mu[j]) / stddev[j]);
+ dval = dval * stddev[i] + mu[i];
else
- dval += eigmat[i][j] * (inbuf[j][col] - mu[j]);
+ dval += mu[i];
+ else {
+ if (stddev)
+ else
/* the cell entry is complete */
Modified: grass/trunk/imagery/i.pca/support.c
--- grass/trunk/imagery/i.pca/support.c 2012-10-13 11:40:49 UTC (rev 53385)
+++ grass/trunk/imagery/i.pca/support.c 2012-10-13 11:56:04 UTC (rev 53386)
@@ -60,7 +60,7 @@
strcat(tmpeigen, ") ");
- sprintf(tmpa, "[%5.2f%%]", eigval[i] * 100/eigval_total);
+ sprintf(tmpa, "[%5.2f%%]", eigval[i] * 100 / eigval_total);
strcat(tmpeigen, tmpa);
Rast_append_history(&hist, tmpeigen);
