[GRASS-SVN] r53429 - in grass/trunk/temporal: t.create t.info t.list
svn_grass at osgeo.org
Tue Oct 16 08:03:45 PDT 2012
Author: huhabla
Date: 2012-10-16 08:03:44 -0700 (Tue, 16 Oct 2012)
New Revision: 53429
grass/trunk/temporal/t.create/t.create.html
grass/trunk/temporal/t.info/t.info.html
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.info/test.t.info.sh
grass/trunk/temporal/t.list/t.list.py
Added more documentation and corrected tests
Modified: grass/trunk/temporal/t.create/t.create.html
--- grass/trunk/temporal/t.create/t.create.html 2012-10-16 14:50:56 UTC (rev 53428)
+++ grass/trunk/temporal/t.create/t.create.html 2012-10-16 15:03:44 UTC (rev 53429)
@@ -25,7 +25,7 @@
We use <em>t.create</em> for the space time raster dataset creation
and <em>t.register</em> to register the raster maps
in the space time raster dataset.
-At the end we print extent and metadata informations about the
+At the end we report informations about the
space time raster dataset to stdout using <em>t.info</em>.
<div class="code"><pre>
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html 2012-10-16 14:50:56 UTC (rev 53428)
+++ grass/trunk/temporal/t.info/t.info.html 2012-10-16 15:03:44 UTC (rev 53429)
@@ -1,12 +1,132 @@
<h2>DESCRIPTION</h2>
-TBD.
+<em>t.info</em> reports informations about any dataset that is registered in the temporal database in
+human readable or shell script style. Datasets are raster, 3D raster and vector maps as well as their
+corresponding space time datasets (STRDS, STR3DS and STVDS). This module reports the informations that
+are stored in the temporal database. These are basic informations (id, name, mapset, creator,
+creation time, temporal type),
+the temporal and spatial extent and dataset type specific metadata.
+The user has to utilize <em>r.info, r3.info, v.info</em>
+to report detailed informations about raster, 3D raster and vector maps, since
+not all map specific informations and metadata are stored in the temporal database.
+<p>
+In addition informations about the chosen temporal database backend can be reported.
+<h2>EXAMPLE</h2>
+In this example we first report temporal database backend information using <em>t.info -s</em>.
+Then we create a single raster maps using <em>r.mapcalc</em> with random values
+that will be registered in a single space time
+raster dataset named <em>precipitation_daily</em> using a daily temporal granularity.
+We use <em>t.create</em> for the space time raster dataset creation
+and <em>t.register</em> to register the raster map
+in the space time raster dataset.
+At the end we report informations about the raster map and the
+space time raster dataset to stdout.
+<div class="code"><pre>
+t.info -s
+ +------------------- Temporal DBMI backend information ----------------------+
+ | DBMI Python interface:...... sqlite3
+ | DBMI init string:........... /1/soeren/grassdata/TestLL/PERMANENT/tgis.db
+ | SQL template path:.......... /home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/sql
+r.mapcalc --o expr="map1 = rand(0, 10)"
+t.create type=strds temporaltype=absolute \
+ output=precipitation_daily \
+ title="Daily precipitation" \
+ description="Test dataset with daily precipitation"
+t.register -i type=rast input=precipitation_daily \
+ maps=map1 start=20-08-2012 increment="1 days"
+t.info type=rast input=map1
+ +-------------------- Raster Dataset ----------------------------------------+
+ +-------------------- Basic information -------------------------------------+
+ | Id: ........................ map1 at PERMANENT
+ | Name: ...................... map1
+ | Mapset: .................... PERMANENT
+ | Creator: ................... soeren
+ | Creation time: ............. 2012-10-16 14:45:24.554908
+ | Temporal type: ............. absolute
+ +-------------------- Absolute time -----------------------------------------+
+ | Start time:................. 2012-08-20 00:00:00
+ | End time:................... 2012-08-21 00:00:00
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 0.0
+ | East:.. .................... 120.0
+ | West:....................... 0.0
+ | Top:........................ 0.0
+ | Bottom:..................... 0.0
+ +-------------------- Metadata information ----------------------------------+
+ | Datatype:................... CELL
+ | Number of columns:.......... 8
+ | Number of rows:............. 12
+ | Number of cells:............ 96
+ | North-South resolution:..... 10.0
+ | East-west resolution:....... 10.0
+ | Minimum value:.............. 0.0
+ | Maximum value:.............. 9.0
+ | STRDS register table ....... map_989e88525bae40db9c16d03d3574d656_strds_register
+ | Registered datasets ........ precipitation_daily at PERMANENT
+t.info type=strds input=precipitation_daily
+ +-------------------- Space Time Raster Dataset -----------------------------+
+ | Id: ........................ precipitation_daily at PERMANENT
+ | Name: ...................... precipitation_daily
+ | Creation time: ............. 2012-10-16 14:52:24.093147
+ | Semantic type:.............. mean
+ | Granularity:................ 1 days
+ | Temporal type of maps:...... interval
+ | Number of registered maps:.. 1
+ | Title:
+ | Daily precipitation
+ | Description:
+ | Test dataset with daily precipitation
+ | North-South resolution min:. 10.0
+ | North-South resolution max:. 10.0
+ | East-west resolution min:... 10.0
+ | East-west resolution max:... 10.0
+ | Minimum value min:.......... 0.0
+ | Minimum value max:.......... 0.0
+ | Maximum value min:.......... 9.0
+ | Maximum value max:.......... 9.0
+ | Raster register table:...... precipitation_daily_PERMANENT_raster_register
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="t.create.html">t.create</a>,
-<a href="t.info.html">t.info</a>
+<a href="t.register.html">t.register</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r3.info.html">r3.info</a>,
+<a href="v.info.html">v.info</a>
</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-10-16 14:50:56 UTC (rev 53428)
+++ grass/trunk/temporal/t.info/t.info.py 2012-10-16 15:03:44 UTC (rev 53429)
@@ -23,7 +23,7 @@
#%option
#% key: input
#% type: string
-#% description: Name of an existing space time or map dataset
+#% description: Name of an existing space time dataset or map
#% required: no
#% multiple: no
#%end
@@ -64,7 +64,7 @@
# Make sure the temporal database exists
tgis.create_temporal_database()
- if system:
+ if system and not shellstyle:
# 0123456789012345678901234567890
print " +------------------- Temporal DBMI backend information ----------------------+"
print " | DBMI Python interface:...... " + str(tgis.dbmi.__name__)
@@ -74,6 +74,11 @@
tgis.get_sql_template_path())
print " +----------------------------------------------------------------------------+"
return
+ elif system:
+ print "dbmi_python_interface=" + str(tgis.dbmi.__name__)
+ print "dbmi_init_string=" + str(tgis.get_temporal_dbmi_init_string())
+ print "sql_template_path=" + str(tgis.get_sql_template_path())
+ return
if not system and not name:
grass.fatal(_("Please specify %s=") % ("name"))
@@ -87,7 +92,7 @@
ds = tgis.dataset_factory(type, id)
if ds.is_in_db() == False:
- grass.fatal(_("Dataset <%s> not found") % (id))
+ grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
ds.select()
Modified: grass/trunk/temporal/t.info/test.t.info.sh
--- grass/trunk/temporal/t.info/test.t.info.sh 2012-10-16 14:50:56 UTC (rev 53428)
+++ grass/trunk/temporal/t.info/test.t.info.sh 2012-10-16 15:03:44 UTC (rev 53429)
@@ -15,6 +15,8 @@
v.random --o -z output=lidar_abs_2 n=20 zmin=0 zmax=100 column=height
# The first @test
+t.info -s
+t.info -sg
t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
@@ -25,11 +27,11 @@
t.create --o type=stvds temporaltype=absolute output=lidar_abs_ds1 title="A test" descr="A test"
t.create --o type=stvds temporaltype=absolute output=lidar_abs_ds2 title="A test" descr="A test"
-t.register type=rast -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register --o type=rast -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=strds input=precip_abs1
t.info -g type=strds input=precip_abs1
-t.register type=rast -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register --o type=rast -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=strds input=precip_abs2
t.info -g type=strds input=precip_abs2
t.info type=rast input=prec_1
@@ -38,11 +40,11 @@
t.info -g type=rast input=prec_2
-t.register type=rast3d -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register --o type=rast3d -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=str3ds input=precip_abs1
t.info -g type=str3ds input=precip_abs1
-t.register type=rast3d -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register --o type=rast3d -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=str3ds input=precip_abs2
t.info -g type=str3ds input=precip_abs2
t.info type=rast3 input=prec_1
@@ -50,11 +52,11 @@
t.info type=rast3 input=prec_2
t.info -g type=rast3 input=prec_2
-t.register type=vect --v -i input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
+t.register --o type=vect --v -i input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
t.info type=stvds input=lidar_abs_ds1
t.info -g type=stvds input=lidar_abs_ds1
-t.register type=vect --v -i input=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
+t.register --o type=vect --v -i input=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
t.info type=stvds input=lidar_abs_ds2
t.info -g type=stvds input=lidar_abs_ds2
t.info type=vect input=lidar_abs_1
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2012-10-16 14:50:56 UTC (rev 53428)
+++ grass/trunk/temporal/t.list/t.list.py 2012-10-16 15:03:44 UTC (rev 53429)
@@ -54,6 +54,8 @@
#%end
#%option G_OPT_T_TYPE
+#% multiple: yes
+#% answer: absolute,relative
#%end
#%option
@@ -93,58 +95,64 @@
dbif = tgis.SQLDatabaseInterfaceConnection()
dbif.connect()
+ first = True
+ for ttype in temporaltype.split(","):
+ # Create the sql selection statement
+ # Table name
+ if ttype == "absolute":
+ table = sp.get_type() + "_view_abs_time"
+ else:
+ table = sp.get_type() + "_view_rel_time"
+ if columns.find("all") == -1:
+ sql = "SELECT " + str(columns) + " FROM " + table
+ else:
+ sql = "SELECT * FROM " + table
+ if where:
+ sql += " WHERE " + where
+ if order:
+ sql += " ORDER BY " + order
+ dbif.cursor.execute(sql)
+ rows = dbif.cursor.fetchall()
+ # Print the query result to stout
+ if rows:
+ if separator is None or separator == "":
+ separator = "\t"
+ # Print the column names if requested
+ if colhead == True and first == True:
+ output = ""
+ count = 0
+ for key in rows[0].keys():
+ if count > 0:
+ output += separator + str(key)
+ else:
+ output += str(key)
+ count += 1
+ print output
+ first = False
+ for row in rows:
+ output = ""
+ count = 0
+ for col in row:
+ if count > 0:
+ output += separator + str(col)
+ else:
+ output += str(col)
+ count += 1
+ print output
- # Create the sql selection statement
- # Table name
- if temporaltype == "absolute":
- table = sp.get_type() + "_view_abs_time"
- else:
- table = sp.get_type() + "_view_rel_time"
- if columns.find("all") == -1:
- sql = "SELECT " + str(columns) + " FROM " + table
- else:
- sql = "SELECT * FROM " + table
- if where:
- sql += " WHERE " + where
- if order:
- sql += " ORDER BY " + order
- dbif.cursor.execute(sql)
- rows = dbif.cursor.fetchall()
dbif.close()
- # Print the query result to stout
- if rows:
- if separator is None or separator == "":
- separator = "\t"
- # Print the column names if requested
- if colhead == True:
- output = ""
- count = 0
- for key in rows[0].keys():
- if count > 0:
- output += separator + str(key)
- else:
- output += str(key)
- count += 1
- print output
- for row in rows:
- output = ""
- count = 0
- for col in row:
- if count > 0:
- output += separator + str(col)
- else:
- output += str(col)
- count += 1
- print output
if __name__ == "__main__":
options, flags = grass.parser()
main()
