[GRASS-SVN] r53439 - grass/trunk/raster/r.out.ppm
Wed Oct 17 06:16:03 PDT 2012
Author: annakrat
Date: 2012-10-17 06:16:00 -0700 (Wed, 17 Oct 2012)
New Revision: 53439
   grass/trunk/raster/r.out.ppm/main.c
r.out.ppm: added flag to suppress printing header of ppm file - needed by animation tool for loading raw image data
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c	2012-10-17 12:46:50 UTC (rev 53438)
+++ grass/trunk/raster/r.out.ppm/main.c	2012-10-17 13:16:00 UTC (rev 53439)
@@ -34,7 +34,7 @@
     struct GModule *module;
     struct Option *rast, *ppm_file;
-    struct Flag *gscale;
+    struct Flag *gscale, *header;
     char *map, *p, ofile[1000];
     unsigned char *set, *ored, *ogrn, *oblu;
     CELL *cell_buf;
@@ -66,6 +66,10 @@
     gscale->key = 'g';
     gscale->description = _("Output greyscale instead of color");
+    header = G_define_flag();
+    header->key = 'h';
+    header->description = _("Suppress printing of PPM header");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -116,31 +120,32 @@
     /* write header info */
+    if (!header->answer) {
+	if (!gscale->answer)
+	    fprintf(fp, "P6\n");
+	/* Magic number meaning rawbits, 24bit color to ppm format */
+	else
+	    fprintf(fp, "P5\n");
+	/* Magic number meaning rawbits, 8bit greyscale to ppm format */
-    if (!gscale->answer)
-	fprintf(fp, "P6\n");
-    /* Magic number meaning rawbits, 24bit color to ppm format */
-    else
-	fprintf(fp, "P5\n");
-    /* Magic number meaning rawbits, 8bit greyscale to ppm format */
+	if (!do_stdout) {
+	    fprintf(fp, "# CREATOR: %s from GRASS raster map \"%s\"\n",
+	            G_program_name(), rast->answer);
+	    fprintf(fp, "# east-west resolution: %f\n", w.ew_res);
+	    fprintf(fp, "# north-south resolution: %f\n", w.ns_res);
+	    fprintf(fp, "# South edge: %f\n", w.south);
+	    fprintf(fp, "# West edge: %f\n", w.west);
+	    /* comments */
-    if (!do_stdout) {
-	fprintf(fp, "# CREATOR: %s from GRASS raster map \"%s\"\n",
-		G_program_name(), rast->answer);
-	fprintf(fp, "# east-west resolution: %f\n", w.ew_res);
-	fprintf(fp, "# north-south resolution: %f\n", w.ns_res);
-	fprintf(fp, "# South edge: %f\n", w.south);
-	fprintf(fp, "# West edge: %f\n", w.west);
-	/* comments */
+	fprintf(fp, "%d %d\n", w.cols, w.rows);
+	/* width & height */
+	fprintf(fp, "255\n");
+	/* max intensity val */
-    fprintf(fp, "%d %d\n", w.cols, w.rows);
-    /* width & height */
-    fprintf(fp, "255\n");
-    /* max intensity val */
     G_important_message(_("Converting..."));
