[GRASS-SVN] r53454 - grass/branches/releasebranch_6_4/general/g.proj
svn_grass at osgeo.org
Wed Oct 17 13:20:37 PDT 2012
Author: neteler
Date: 2012-10-17 13:20:36 -0700 (Wed, 17 Oct 2012)
New Revision: 53454
Added:
grass/branches/releasebranch_6_4/general/g.proj/create.c
backport with GRASS 6 adaptations of datum handling patches by Paul Kelly: r53297, r53305, r53310 from trunk
Added: grass/branches/releasebranch_6_4/general/g.proj/create.c
--- grass/branches/releasebranch_6_4/general/g.proj/create.c (rev 0)
+++ grass/branches/releasebranch_6_4/general/g.proj/create.c 2012-10-17 20:20:36 UTC (rev 53454)
@@ -0,0 +1,68 @@
+#include <errno.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+void create_location(char *location)
+ int ret;
+ ret = G__make_location(location, &cellhd, projinfo, projunits, NULL);
+ if (ret == 0)
+ G_message(_("Location <%s> created"), location);
+ else if (ret == -1)
+ G_fatal_error(_("Unable to create location <%s>: %s"),
+ location, strerror(errno));
+ else if (ret == -2)
+ G_fatal_error(_("Unable to create projection files: %s"),
+ strerror(errno));
+ else
+ /* Shouldn't happen */
+ G_fatal_error(_("Unspecified error while creating new location"));
+ G_message(_("You can switch to the new location by\n`%s=%s`"),
+ "g.mapset mapset=PERMANENT location", location);
+void modify_projinfo()
+ const char *mapset = G_mapset();
+ struct Cell_head old_cellhd;
+ if (strcmp(mapset, "PERMANENT") != 0)
+ G_fatal_error(_("You must select the PERMANENT mapset before updating the "
+ "current location's projection (current mapset is <%s>)."),
+ mapset);
+ /* Read projection information from current location first */
+ G_get_default_window(&old_cellhd);
+ char path[GPATH_MAX];
+ int stat;
+ /* Write out the PROJ_INFO, and PROJ_UNITS if available. */
+ if (projinfo != NULL) {
+ G__file_name(path, "", "PROJ_INFO", "PERMANENT");
+ G_write_key_value_file(path, projinfo, &stat);
+ if (projunits != NULL) {
+ G__file_name(path, "", "PROJ_UNITS", "PERMANENT");
+ G_write_key_value_file(path, projunits, &stat);
+ if ((old_cellhd.zone != cellhd.zone) ||
+ (old_cellhd.proj != cellhd.proj)) {
+ /* Recreate the default, and current window files if projection
+ * number or zone have changed */
+ G__put_window(&cellhd, "", "DEFAULT_WIND");
+ G__put_window(&cellhd, "", "WIND");
+ G_message(_("Default region was updated to the new projection, but if you have "
+ "multiple mapsets `g.region -d` should be run in each to update the "
+ "region from the default"));
+ G_important_message(_("Projection information updated"));
