[GRASS-SVN] r53456 - in grass/branches/develbranch_6: gui/wxpython/location_wizard lib/python
Wed Oct 17 13:27:15 PDT 2012
Author: neteler
Date: 2012-10-17 13:27:14 -0700 (Wed, 17 Oct 2012)
New Revision: 53456
   grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
   grass/branches/develbranch_6/lib/python/core.py
backport of r53316 and r53317 (from trunk); fixes trac #1748 and #1452
Modified: grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
--- grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py	2012-10-17 20:25:53 UTC (rev 53455)
+++ grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py	2012-10-17 20:27:14 UTC (rev 53456)
@@ -892,8 +892,10 @@
 #                proj4string = self.parent.CreateProj4String() + ' +datum=%s' % self.datum
                 ret = RunCommand('g.proj',
                                  read = True,
-                                 proj4 = '%s +datum=%s' % (proj, self.datum),
+                                 proj4 = '%s' % proj,
+                                 datum = '%s' % self.datum,
                                  datumtrans = '-1')
+#                wx.Messagebox('here')
                 if ret != '':
                     dtrans = ''
                     # open a dialog to select datum transform number
@@ -1617,6 +1619,7 @@
         location = self.parent.startpage.location
         epsgcode = self.parent.epsgpage.epsgcode
+        datum = self.parent.datumpage.datum
         dtrans = self.parent.datumtrans
         global coordsys
@@ -1625,6 +1628,7 @@
                 ret, projlabel, err = RunCommand('g.proj',
                                                  flags = 'jf',
                                                  proj4 = proj4string,
+                                                 datum = datum,
                                                  datumtrans = dtrans,
                                                  location = location,
                                                  getErrorMsg = True,
@@ -1640,6 +1644,8 @@
             finishButton = wx.FindWindowById(wx.ID_FORWARD)
             if ret == 0:
+                if datum != '':
+                    projlabel = projlabel + ' ' + 'datum=%s' % datum
                 self.lproj4string.SetLabel(projlabel.replace(' ', os.linesep))
                 finishButton.Enable(True)
             else:
@@ -1966,7 +1972,8 @@
                 grass.create_location(dbase = self.startpage.grassdatabase,
                                       location = self.startpage.location,
                                       proj4 = self.CreateProj4String(),
-                                      datum = self.datumtrans,
+                                      datum = self.datumpage.datum,
+                                      datumtrans = self.datumtrans,
                                       desc = self.startpage.locTitle)
             elif coordsys == 'custom':
@@ -1980,7 +1987,8 @@
                                       epsg = self.epsgpage.epsgcode,
             elif coordsys == "file":
                 if not self.filepage.georeffile or \
@@ -2013,7 +2021,7 @@
         projdesc = self.projpage.projdesc
         proj4params = self.paramspage.p4projparams
-        datum = self.datumpage.datum
+#        datum = self.datumpage.datum
         if self.datumpage.datumdesc:
             datumdesc = self.datumpage.datumdesc +' - ' + self.datumpage.ellipse
         else:
@@ -2038,9 +2046,7 @@
                 item = ' +' + item
             proj4string = '%s %s' % (proj4string, item)
-        # set datum and transform parameters if relevant
-        if datum != '':
-            proj4string = '%s +datum=%s' % (proj4string, datum)
+        # set datum transform parameters if relevant
         if datumparams:
             for item in datumparams:
                 proj4string = '%s +%s' % (proj4string,item)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2012-10-17 20:25:53 UTC (rev 53455)
+++ grass/branches/develbranch_6/lib/python/core.py	2012-10-17 20:27:14 UTC (rev 53456)
@@ -1052,18 +1052,19 @@
 def create_location(dbase, location,
                     epsg = None, proj4 = None, filename = None, wkt = None,
-                    datum = None, desc = None):
+                    datum = None, datumtrans = None, desc = None):
     """!Create new location
     Raise ScriptError on error.
     @param dbase path to GRASS database
     @param location location name to create
-    @param epgs if given create new location based on EPSG code
+    @param epsg if given create new location based on EPSG code
     @param proj4 if given create new location based on Proj4 definition
     @param filename if given create new location based on georeferenced file
     @param wkt if given create new location based on WKT definition (path to PRJ file)
-    @param datum datum transformation parameters (used for epsg and proj4)
+    @param datum GRASS format datum code
+    @param datumtrans datum transformation parameters (used for epsg and proj4)
     @param desc description of the location (creates MYNAME file)
     gisdbase = None
@@ -1077,11 +1078,12 @@
     kwargs = dict()
     if datum:
         kwargs['datum'] = datum
+    if datumtrans:
+        kwargs['datumtrans'] = datumtrans
     if epsg:
         ps = pipe_command('g.proj',
                           quiet = True,
-                          flags = 'c',
                           epsg = epsg,
                           stderr = PIPE,
@@ -1089,7 +1091,6 @@
     elif proj4:
                           quiet = True,
-                          flags = 'c',
                           proj4 = proj4,
                           stderr = PIPE,
@@ -1097,14 +1098,12 @@
     elif filename:
                           quiet = True,
-                          flags = 'c',
                           georef = filename,
                           stderr = PIPE)
     elif wkt:
                           quiet = True,
-                          flags = 'c',
                           wkt = wkt,
                           stderr = PIPE)
