[GRASS-SVN] r53458 - grass-addons/grass6/raster/r.sun.angle
svn_grass at osgeo.org
Wed Oct 17 14:46:27 PDT 2012
Author: neteler
Date: 2012-10-17 14:46:27 -0700 (Wed, 17 Oct 2012)
New Revision: 53458
grass-addons/grass6/raster/r.sun.angle/main.c
backport of r53440; msg standardization
Modified: grass-addons/grass6/raster/r.sun.angle/main.c
--- grass-addons/grass6/raster/r.sun.angle/main.c 2012-10-17 21:45:24 UTC (rev 53457)
+++ grass-addons/grass6/raster/r.sun.angle/main.c 2012-10-17 21:46:27 UTC (rev 53458)
@@ -36,7 +36,7 @@
struct Option *elev, *azimuth, *sunhours, *year,
*month, *day, *hour, *minutes, *seconds;
- struct Flag *gst_time, *solpos;
+ struct Flag *lst_time, *no_solpos;
} parm;
struct Cell_head window;
FCELL *elevbuf, *azimuthbuf, *sunhourbuf;
@@ -67,7 +67,7 @@
module = G_define_module();
module->keywords = _("raster");
- module->label = _("Calculates solar elevation and azimuth.");
+ module->label = _("Calculates solar elevation, solar azimuth, and sun hours.");
module->description = _("Solar elevation: the angle between the direction of the geometric center "
"of the sun's apparent disk and the (idealized) horizon. "
"Solar azimuth: the angle from due north in clockwise direction.");
@@ -102,7 +102,7 @@
parm.month->required = NO;
parm.month->label = _("Month");
parm.month->description = _("If not given, day is interpreted as day of the year");
- parm.month->options = "0-12";
+ parm.month->options = "1-12";
parm.month->guisection = _("Time");
parm.day = G_define_option();
@@ -110,13 +110,13 @@
parm.day->type = TYPE_INTEGER;
parm.day->required = YES;
parm.day->description = _("Day");
- parm.day->options = "0-365";
+ parm.day->options = "1-366";
parm.day->guisection = _("Time");
parm.hour = G_define_option();
parm.hour->key = "hour";
parm.hour->type = TYPE_INTEGER;
- parm.hour->required = YES;
+ parm.hour->required = NO;
parm.hour->description = _("Hour");
parm.hour->options = "0-24";
parm.hour->answer = "12";
@@ -125,7 +125,7 @@
parm.minutes = G_define_option();
parm.minutes->key = "minute";
parm.minutes->type = TYPE_INTEGER;
- parm.minutes->required = YES;
+ parm.minutes->required = NO;
parm.minutes->description = _("Minutes");
parm.minutes->options = "0-60";
parm.minutes->answer = "0";
@@ -134,19 +134,19 @@
parm.seconds = G_define_option();
parm.seconds->key = "second";
parm.seconds->type = TYPE_INTEGER;
- parm.seconds->required = YES;
+ parm.seconds->required = NO;
parm.seconds->description = _("Seconds");
parm.seconds->options = "0-60";
parm.seconds->answer = "0";
parm.seconds->guisection = _("Time");
- parm.gst_time = G_define_flag();
- parm.gst_time->key = 't';
- parm.gst_time->description = _("Time is Greenwich standard time, not local sidereal time");
+ parm.lst_time = G_define_flag();
+ parm.lst_time->key = 't';
+ parm.lst_time->description = _("Time is local sidereal time, not Greenwich standard time");
- parm.solpos = G_define_flag();
- parm.solpos->key = 's';
- parm.solpos->description = _("Use solpos algorithm of NREL");
+ parm.no_solpos = G_define_flag();
+ parm.no_solpos->key = 's';
+ parm.no_solpos->description = _("Do not use solpos algorithm of NREL");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -160,19 +160,20 @@
if (!elev_name && !azimuth_name && !sunhour_name)
G_fatal_error(_("No output requested, exiting."));
- sscanf(parm.year->answer, "%i", &year);
+ year = atoi(parm.year->answer);
if (parm.month->answer)
- sscanf(parm.month->answer, "%i", &month);
+ month = atoi(parm.month->answer);
else
month = -1;
- sscanf(parm.day->answer, "%i", &day);
- sscanf(parm.hour->answer, "%i", &hour);
- sscanf(parm.minutes->answer, "%i", &minutes);
- sscanf(parm.seconds->answer, "%i", &seconds);
- lst_time = (parm.gst_time->answer == 0);
- use_solpos = parm.solpos->answer;
+ day = atoi(parm.day->answer);
+ hour = atoi(parm.hour->answer);
+ minutes = atoi(parm.minutes->answer);
+ seconds = atoi(parm.seconds->answer);
+ lst_time = (parm.lst_time->answer != 0);
+ use_solpos = (parm.no_solpos->answer == 0);
/* init variables */
ha = 180;
ha_cos = 0;
@@ -195,7 +196,7 @@
G_message(_("Time will be interpreted as Greenwich standard time."));
if (sunhour_name)
- G_fatal_error(_("Sunshine hours require solpos"));
+ G_fatal_error(_("Sunshine hours require NREL solpos."));
if ((G_projection() != PROJECTION_LL)) {
@@ -206,13 +207,13 @@
/* read current projection info */
if ((in_proj_info = G_get_projinfo()) == NULL)
- G_fatal_error(_("Can't get projection info of current location"));
+ G_fatal_error(_("Cannot get projection info of current location"));
if ((in_unit_info = G_get_projunits()) == NULL)
- G_fatal_error(_("Can't get projection units of current location"));
+ G_fatal_error(_("Cannot get projection units of current location"));
if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
- G_fatal_error(_("Can't get projection key values of current location"));
+ G_fatal_error(_("Cannot get projection key values of current location"));
G_free_key_value(in_proj_info);
G_free_key_value(in_unit_info);
