[GRASS-SVN] r53468 - in grass/branches/develbranch_6/gui/wxpython: core gui_core modules
svn_grass at osgeo.org
Thu Oct 18 08:41:03 PDT 2012
Author: martinl
Date: 2012-10-18 08:41:03 -0700 (Thu, 18 Oct 2012)
New Revision: 53468
grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
wxGUI: update prompt when new addon is installed
Modified: grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-18 15:02:00 UTC (rev 53467)
+++ grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-18 15:41:03 UTC (rev 53468)
@@ -25,6 +25,8 @@
ETCIMGDIR = os.path.join(ETCDIR, "gui", "images")
ETCSYMBOLDIR = os.path.join(ETCDIR, "gui", "images", "symbols")
+from core.debug import Debug
sys.path.append(os.path.join(ETCDIR, "python"))
import grass.script as grass
@@ -145,24 +147,45 @@
if script[-len(pattern):] != pattern: # ignore wrappers
cmd.append(script)
+ return set(cmd), scripts
+def UpdateGRASSAddOnCommands():
+ """!Update list of available GRASS AddOns commands to use when
+ parsing string from the command line
+ global grassCmd, grassScripts
# scan addons (path)
- if os.getenv('GRASS_ADDON_PATH'):
- for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
- if not os.path.exists(path) or not os.path.isdir(path):
+ if not os.getenv('GRASS_ADDON_PATH'):
+ return
+ nCmd = 0
+ for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
+ if not os.path.exists(path) or not os.path.isdir(path):
+ continue
+ for fname in os.listdir(path):
+ if fname in ['docs', 'modules.xml']:
continue
- for fname in os.listdir(path):
- if scripts: # win32
- name, ext = os.path.splitext(fname)
- cmd.append(name)
- if ext in scripts.keys():
- scripts[ext].append(name)
- else:
- cmd.append(fname)
- return set(cmd), scripts
+ if grassScripts: # win32
+ name, ext = os.path.splitext(fname)
+ if name not in grassCmd:
+ grassCmd.add(name)
+ nCmd += 1
+ if ext in grassScripts.keys() and \
+ name not in grassScripts[ext]:
+ grassScripts[ext].append(name)
+ nCmd += 1
+ else:
+ if fname not in grassCmd:
+ grassCmd.add(fname)
+ nCmd += 1
+ Debug.msg(1, "Number of new AddOn commands: %d", nCmd)
"""@brief Collected GRASS-relared binaries/scripts"""
grassCmd, grassScripts = GetGRASSCommands()
+Debug.msg(1, "Number of GRASS commands: %d", len(grassCmd))
+UpdateGRASSAddOnCommands()
"""@Toolbar icon size"""
toolbarSize = (24, 24)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-10-18 15:02:00 UTC (rev 53467)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-10-18 15:41:03 UTC (rev 53468)
@@ -985,7 +985,11 @@
def ResetFocus(self):
"""!Reset focus"""
self.cmdPrompt.SetFocus()
+ def GetPrompt(self):
+ """!Get prompt"""
+ return self.cmdPrompt
class GMStdout:
"""!GMConsole standard output
Modified: grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
--- grass/branches/develbranch_6/gui/wxpython/modules/extensions.py 2012-10-18 15:02:00 UTC (rev 53467)
+++ grass/branches/develbranch_6/gui/wxpython/modules/extensions.py 2012-10-18 15:41:03 UTC (rev 53468)
@@ -220,15 +220,11 @@
log.RunCmd(self._getCmd(), onDone = self.OnDone)
def OnDone(self, cmd, returncode):
- item = self.tree.GetSelected()
- if not item or not item.IsOk() or \
- returncode != 0 or \
- not os.getenv('GRASS_ADDON_PATH'):
- return
- name = self.tree.GetItemText(item)
- globalvar.grassCmd.add(name)
+ if returncode == 0:
+ globalvar.UpdateGRASSAddOnCommands()
+ log = self.parent.GetLogWindow()
+ log.GetPrompt().SetFilter(None)
def OnItemSelected(self, event):
"""!Item selected"""
item = event.GetItem()
