[GRASS-SVN] r53474 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Oct 18 10:08:51 PDT 2012
Author: martinl
Date: 2012-10-18 10:08:51 -0700 (Thu, 18 Oct 2012)
New Revision: 53474
grass/trunk/scripts/g.extension/g.extension.py
g.extension: don't fail when desc or keyw is not defined
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2012-10-18 16:55:33 UTC (rev 53473)
+++ grass/trunk/scripts/g.extension/g.extension.py 2012-10-18 17:08:51 UTC (rev 53474)
@@ -268,6 +268,21 @@
return tlist
+def get_optional_params(mnode):
+ try:
+ desc = mnode.find('description').text
+ except AttributeError:
+ desc = ''
+ if desc is None:
+ desc = ''
+ try:
+ keyw = mnode.find('keywords').text
+ keyw = ''
+ if keyw is None:
+ keyw = ''
+ return desc, keyw
def list_available_modules(url, mlist = None):
# try to download XML metadata file first
@@ -285,13 +300,8 @@
if mlist and name not in mlist:
continue
if flags['c'] or flags['g']:
- desc = mnode.find('description').text
- if not desc:
- desc = ''
- keyw = mnode.find('keywords').text
- if not keyw:
- keyw = ''
+ desc, keyw = get_optional_params(mnode)
if flags['g']:
print 'name=' + name
print 'description=' + desc
@@ -577,14 +587,9 @@
if path[0] == 'scripts':
path[-1] += '.py'
fList.append(os.path.sep.join(path))
- if not desc:
- desc = ''
- if not keyw:
- keyw = ''
data[name] = {
'desc' : desc,
'keyw' : keyw,
