[GRASS-SVN] r53481 - in grass/branches/develbranch_6: gui/wxpython/core gui/wxpython/lmgr gui/wxpython/modules lib/init
Thu Oct 18 17:18:07 PDT 2012
Author: martinl
Date: 2012-10-18 17:18:07 -0700 (Thu, 18 Oct 2012)
New Revision: 53481
   grass/branches/develbranch_6/gui/wxpython/core/utils.py
   grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
   grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
   grass/branches/develbranch_6/lib/init/init.sh
wxGUI: eliminate gis env ADDON_PATH, see #1696
Modified: grass/branches/develbranch_6/gui/wxpython/core/utils.py
--- grass/branches/develbranch_6/gui/wxpython/core/utils.py	2012-10-18 19:33:23 UTC (rev 53480)
+++ grass/branches/develbranch_6/gui/wxpython/core/utils.py	2012-10-19 00:18:07 UTC (rev 53481)
@@ -777,6 +777,79 @@
     # keep location of settings files rc and wx in sync with
     # lib/init/init.sh and init.bat
     if sys.platform == 'win32':
-        return os.path.join(os.getenv('APPDATA'), 'grass%d' % version)
+        return os.path.join(os.getenv('APPDATA'), 'GRASS%d' % version)
     return os.path.join(os.getenv('HOME'), '.grass%d' % version)
+def StoreEnvVariable(key, value, envFile = None):
+    """!Store environmental variable
+    @param key env key
+    @param value env value
+    @param envFile path to the environmental file (None for default location)
+    windows = sys.platform == 'win32'
+    if not envFile:
+        if not windows:
+            envFile = os.path.join(os.getenv('HOME'), '.grass.bashrc')
+        else:
+            envFile = os.path.join(os.getenv('APPDATA'), 'GRASS%d' % version, 'env.bat')
+    # read env file
+    environ = dict()
+    if os.path.exists(envFile):
+        try:
+            fd = open(envFile)
+        except IOError, e:
+            sys.stderr.write(_("Unable to open file '%s'") % envFile)
+            return
+        for line in fd.readlines():
+            try:
+                key, value = line.split(' ', 1).strip().split('=', 1)
+            except:
+                sys.stderr.write(_("%s: unable to parse '%s'") % (envFile, line))
+                continue
+            if key in environ:
+                sys.stderr.write(_("Duplicated key: %s") % key)
+            environ[key] = value
+        fd.close()
+    # update environmental variables
+    # write update env file
+    try:
+        fd = open(envFile, 'w')
+        sys.stderr.write(_("Unable to create file '%s'") % envFile)
+        return
+    if windows:
+        expCmd = 'set'
+    else:
+        expCmd = 'export'
+    for key, value in environ.iteritems():
+        fd.write('%s %s=%s\n' % (expCmd, key, value))
+    fd.close()
+def SetAddOnPath(addonPath = None):
+    """!Set default AddOn path
+    @addonPath path to addons (None for default)
+    gVersion = grass.version()['version'].split('.', 1)[0]
+    # update env file
+    if not addonPath:
+        if sys.platform != 'win32':
+            addonPath = os.path.join(os.path.join(os.getenv('HOME'),
+                                                  '.grass%s' % gVersion,
+                                                  'addons'))
+        else:
+            addonPath = os.path.join(os.path.join(os.getenv('APPDATA'),
+                                                  'GRASS%s' % gVersion,
+                                                  'addons'))
+    StoreEnvVariable('GRASS_ADDON_PATH', addonPath)
+    os.environ['GRASS_ADDON_PATH'] = addonPath
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py	2012-10-18 19:33:23 UTC (rev 53480)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py	2012-10-19 00:18:07 UTC (rev 53481)
@@ -41,6 +41,7 @@
 from core.gcmd             import RunCommand, GError, GMessage
 from core.settings         import UserSettings
+from core.utils            import SetAddOnPath
 from gui_core.preferences  import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
 from lmgr.layertree        import LayerTree, LMIcons
 from lmgr.menudata         import ManagerData
@@ -681,8 +682,7 @@
                                    caption = _("Update Addons path?"),
                                    style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
             if dlg.ShowModal() == wx.ID_YES:
-                os.environ['GRASS_ADDON_PATH'] = os.pathsep.join(addonPath)
-                RunCommand('g.gisenv', set = 'ADDON_PATH=%s' % os.environ['GRASS_ADDON_PATH'])
+                SetAddOnPath(os.pathsep.join(addonPath))
         self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
         self.goutput.RunCmd([filename], switchPage = True)
Modified: grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
--- grass/branches/develbranch_6/gui/wxpython/modules/extensions.py	2012-10-18 19:33:23 UTC (rev 53480)
+++ grass/branches/develbranch_6/gui/wxpython/modules/extensions.py	2012-10-19 00:18:07 UTC (rev 53481)
@@ -33,6 +33,7 @@
 from core             import globalvar
 from core.gcmd        import GError, RunCommand
 from gui_core.forms   import GUI
 from gui_core.widgets import ItemTree
 from gui_core.ghelp   import SearchModuleWindow
@@ -221,6 +222,9 @@
     def OnDone(self, cmd, returncode):
         if returncode == 0:
+            if not os.getenv('GRASS_ADDON_PATH'):
+                SetAddOnPath()
             globalvar.UpdateGRASSAddOnCommands()
             log = self.parent.GetLogWindow()
             log.GetPrompt().SetFilter(None)
Modified: grass/branches/develbranch_6/lib/init/init.sh
--- grass/branches/develbranch_6/lib/init/init.sh	2012-10-18 19:33:23 UTC (rev 53480)
+++ grass/branches/develbranch_6/lib/init/init.sh	2012-10-19 00:18:07 UTC (rev 53481)
@@ -736,15 +736,6 @@
     exit 1
 fi
-# check gisenv's ADDON_PATH
-ADDON_PATH=`g.gisenv ADDON_PATH`
-if [ -n "$ADDON_PATH" ] ; then
-    GRASS_ADDON_PATH="$GRASS_ADDON_PATH:$ADDON_PATH"
-    export GRASS_ADDON_PATH
-    PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
-    export PATH
-fi
 LOCATION="${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}"
 # Check for concurrent use
