[GRASS-SVN] r53484 - grass-addons/grass7/gui/wxpython/wx.animation/animation
svn_grass at osgeo.org
Fri Oct 19 00:46:59 PDT 2012
Author: annakrat
Date: 2012-10-19 00:46:59 -0700 (Fri, 19 Oct 2012)
New Revision: 53484
grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py
grass-addons/grass7/gui/wxpython/wx.animation/animation/dialogs.py
grass-addons/grass7/gui/wxpython/wx.animation/animation/mapwindow.py
grass-addons/grass7/gui/wxpython/wx.animation/animation/nviztask.py
wx.animation: set temp region for m.nviz.image
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py 2012-10-19 06:16:51 UTC (rev 53483)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py 2012-10-19 07:46:59 UTC (rev 53484)
@@ -369,9 +369,11 @@
def _load3DData(self, animationData):
prov = self.bitmapProviders[animationData.windowIndex]
- prov.SetData(datasource = animationData.GetNvizCommands(),
+ nviz = animationData.GetNvizCommands()
+ prov.SetData(datasource = nviz['commands'],
dataNames = animationData.mapData, dataType = 'nviz',
- suffix = animationData.nvizParameter)
+ suffix = animationData.nvizParameter,
+ nvizRegion = nviz['region'])
self.bitmapProviders[animationData.windowIndex].Load()
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/dialogs.py 2012-10-19 06:16:51 UTC (rev 53483)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/dialogs.py 2012-10-19 07:46:59 UTC (rev 53484)
@@ -774,8 +774,9 @@
return []
cmds = self.nvizTask.GetCommandSeries(series = self.mapData, paramName = self.nvizParameter)
+ region = self.nvizTask.GetRegion()
- return cmds
+ return {'commands': cmds, 'region': region}
def __repr__(self):
return "%s(%r)" % (self.__class__, self.__dict__)
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/mapwindow.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/mapwindow.py 2012-10-19 06:16:51 UTC (rev 53483)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/mapwindow.py 2012-10-19 07:46:59 UTC (rev 53484)
@@ -195,27 +195,32 @@
self.datasource = None
self.dataNames = None
self.dataType = None
+ self.region = None
self.bitmapPool = bitmapPool
self.frame = frame
self.size = wx.Size()
self.loadSize = wx.Size()
self.suffix = ''
+ self.nvizRegion = None
def GetDataNames(self):
return self.dataNames
- def SetData(self, datasource, dataNames = None, dataType = 'rast', suffix = ''):
+ def SetData(self, datasource, dataNames = None, dataType = 'rast',
+ suffix = '', nvizRegion = None):
"""!Sets data.
@param datasource data to load (raster maps, m.nviz.image commands)
@param dataNames data labels (keys)
@param dataType 'rast', 'nviz'
+ @param nvizRegion region which must be set for m.nviz.image
self.datasource = datasource
self.dataType = dataType
self.suffix = suffix
- # add postfix _nviz, _image if needed
+ self.nvizRegion = nvizRegion
if dataNames:
self.dataNames = dataNames
else:
@@ -229,7 +234,8 @@
@param dataId name of bitmap
- dataId += self.suffix
+ if dataId:
+ dataId += self.suffix
try:
bitmap = self.bitmapPool[dataId]
except KeyError:
@@ -290,7 +296,7 @@
self._loadRasters(rasters = self.datasource, names = self.dataNames,
size = size, scale = scale, force = force, updateFunction = updateFunction)
elif self.dataType == 'nviz':
- self._load3D(commands = self.datasource, names = self.dataNames,
+ self._load3D(commands = self.datasource, region = self.nvizRegion, names = self.dataNames,
if progress:
progress.Destroy()
@@ -383,10 +389,11 @@
os.environ.pop('GRASS_REGION')
- def _load3D(self, commands, names, force, updateFunction):
+ def _load3D(self, commands, region, names, force, updateFunction):
"""!Load 3D view images using m.nviz.image.
@param commands
+ @param region
@param names names used as keys for bitmaps
@param force load everything even though it is already there
@param updateFunction function called for updating progress dialog
@@ -397,6 +404,8 @@
format = 'ppm'
tempFile = grass.tempfile(False)
tempFileFormat = tempFile + '.' + format
+ os.environ['GRASS_REGION'] = grass.region_env(**region)
# create no data bitmap
if None not in self.bitmapPool or force:
self.bitmapPool[None] = self._createNoDataBitmap(ncols, nrows)
@@ -424,6 +433,7 @@
if not keepGoing:
break
grass.try_remove(tempFileFormat)
+ os.environ.pop('GRASS_REGION')
class BitmapPool():
"""!Class storing bitmaps (emulates dictionary)"""
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/nviztask.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/nviztask.py 2012-10-19 06:16:51 UTC (rev 53483)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/nviztask.py 2012-10-19 07:46:59 UTC (rev 53484)
@@ -29,11 +29,13 @@
from core.gcmd import RunCommand, GException
from core.utils import GetLayerNameFromCmd, CmdToTuple
from grass.script import task as gtask
+from grass.script import core as grass
class NvizTask:
def __init__(self):
self.task = None
self.filename = None
+ self.region = {}
def Load(self, filename):
self.task = gtask.grassTask("m.nviz.image")
@@ -51,12 +53,17 @@
if not gxwXml.nviz_state:
raise GException(_("No 3d view information in workspace file <%s>.") % self.filename)
- # self.task.set_param('output', "/home/anna/testy/nviz/out.ppm")
+ self._getExtent(gxwXml)
self._processState(gxwXml.nviz_state)
self._processLayers(gxwXml.layers)
+ def _getExtent(self, root):
+ for display in root.displays:
+ if display['viewMode'] == '3d':
+ self.region['w'], self.region['s'],\
+ self.region['e'], self.region['n'] = display['extent']
def _processLayers(self, layers):
for layer in layers:
if not layer['checked']:
@@ -185,8 +192,11 @@
cmd = self.task.get_cmd(ignoreErrors = False, ignoreRequired = False, ignoreDefault = True)
return CmdToTuple(cmd)
+ def GetRegion(self):
+ return self.region
def test():
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
