[GRASS-SVN] r53494 - in grass/branches/releasebranch_6_4: gui/wxpython/core gui/wxpython/lmgr gui/wxpython/modules lib/init
Fri Oct 19 04:29:25 PDT 2012
Author: martinl
Date: 2012-10-19 04:29:24 -0700 (Fri, 19 Oct 2012)
New Revision: 53494
   grass/branches/releasebranch_6_4/gui/wxpython/core/globalvar.py
   grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
   grass/branches/releasebranch_6_4/gui/wxpython/lmgr/frame.py
   grass/branches/releasebranch_6_4/gui/wxpython/modules/extensions.py
   grass/branches/releasebranch_6_4/lib/init/init.bat
   grass/branches/releasebranch_6_4/lib/init/init.sh
eliminate gis env ADDON_PATH, see #1696
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/globalvar.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/globalvar.py	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/globalvar.py	2012-10-19 11:29:24 UTC (rev 53494)
@@ -25,6 +25,8 @@
 ETCIMGDIR = os.path.join(ETCDIR, "gui", "images")
 ETCSYMBOLDIR = os.path.join(ETCDIR, "gui", "images", "symbols")
+from core.debug import Debug
 sys.path.append(os.path.join(ETCDIR, "python"))
 import grass.script as grass
@@ -145,24 +147,47 @@
             if script[-len(pattern):] != pattern: # ignore wrappers
                 cmd.append(script)
+    return set(cmd), scripts
+def UpdateGRASSAddOnCommands():
+    """!Update list of available GRASS AddOns commands to use when
+    parsing string from the command line
+    global grassCmd, grassScripts
     # scan addons (path)
-    if os.getenv('GRASS_ADDON_PATH'):
-        for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
-            if not os.path.exists(path) or not os.path.isdir(path):
+    if not os.getenv('GRASS_ADDON_PATH'):
+        return
+    nCmd = 0
+    for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
+        if not os.path.exists(path) or not os.path.isdir(path):
+            continue
+        for fname in os.listdir(path):
+            if fname in ['docs', 'modules.xml']:
                 continue
-            for fname in os.listdir(path):
-                if scripts: # win32
-                    name, ext = os.path.splitext(fname)
-                    cmd.append(name)
-                    if ext in scripts.keys():
-                        scripts[ext].append(name)
-                else:
-                    cmd.append(fname)
-    return set(cmd), scripts
+            if grassScripts: # win32
+                name, ext = os.path.splitext(fname)
+                if ext not in ['.exe', '.bat']:
+                    continue
+                if name not in grassCmd:
+                    grassCmd.add(name)
+                    nCmd += 1
+                if ext == '.bat' and \
+                        ext in grassScripts.keys() and \
+                        name not in grassScripts[ext]:
+                    grassScripts[ext].append(name)
+            else:
+                if fname not in grassCmd:
+                    grassCmd.add(fname)
+                    nCmd += 1
+    Debug.msg(1, "Number of new AddOn commands: %d", nCmd)
 """@brief Collected GRASS-relared binaries/scripts"""
 grassCmd, grassScripts = GetGRASSCommands()
+Debug.msg(1, "Number of GRASS commands: %d", len(grassCmd))
+UpdateGRASSAddOnCommands()
 """@Toolbar icon size"""
 toolbarSize = (24, 24)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2012-10-19 11:29:24 UTC (rev 53494)
@@ -777,6 +777,80 @@
     # keep location of settings files rc and wx in sync with
     # lib/init/init.sh and init.bat
     if sys.platform == 'win32':
-        return os.path.join(os.getenv('APPDATA'), 'grass%d' % version)
+        return os.path.join(os.getenv('APPDATA'), 'GRASS%d' % version)
     return os.path.join(os.getenv('HOME'), '.grass%d' % version)
+def StoreEnvVariable(key, value, envFile = None):
+    """!Store environmental variable
+    @param key env key
+    @param value env value
+    @param envFile path to the environmental file (None for default location)
+    windows = sys.platform == 'win32'
+    if not envFile:
+        if not windows:
+            envFile = os.path.join(os.getenv('HOME'), '.grass.bashrc')
+        else:
+            gVersion = grass.version()['version'].split('.', 1)[0]
+            envFile = os.path.join(os.getenv('APPDATA'), 'GRASS%s' % gVersion, 'env.bat')
+    # read env file
+    environ = dict()
+    if os.path.exists(envFile):
+        try:
+            fd = open(envFile)
+        except IOError, e:
+            sys.stderr.write(_("Unable to open file '%s'") % envFile)
+            return
+        for line in fd.readlines():
+            try:
+                key, value = line.split(' ', 1).strip().split('=', 1)
+            except:
+                sys.stderr.write(_("%s: unable to parse '%s'") % (envFile, line))
+                continue
+            if key in environ:
+                sys.stderr.write(_("Duplicated key: %s") % key)
+            environ[key] = value
+        fd.close()
+    # update environmental variables
+    # write update env file
+    try:
+        fd = open(envFile, 'w')
+        sys.stderr.write(_("Unable to create file '%s'") % envFile)
+        return
+    if windows:
+        expCmd = 'set'
+    else:
+        expCmd = 'export'
+    for key, value in environ.iteritems():
+        fd.write('%s %s=%s\n' % (expCmd, key, value))
+    fd.close()
+def SetAddOnPath(addonPath = None):
+    """!Set default AddOn path
+    @addonPath path to addons (None for default)
+    # update env file
+    if not addonPath:
+        if sys.platform != 'win32':
+            addonPath = os.path.join(os.path.join(os.getenv('HOME'),
+                                                  '.grass%s' % gVersion,
+                                                  'addons'))
+        else:
+            addonPath = os.path.join(os.path.join(os.getenv('APPDATA'),
+                                                  'GRASS%s' % gVersion,
+                                                  'addons'))
+    StoreEnvVariable('GRASS_ADDON_PATH', addonPath)
+    os.environ['GRASS_ADDON_PATH'] = addonPath
Modified: grass/branches/releasebranch_6_4/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_6_4/gui/wxpython/lmgr/frame.py	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/gui/wxpython/lmgr/frame.py	2012-10-19 11:29:24 UTC (rev 53494)
@@ -41,6 +41,7 @@
 from core.gcmd             import RunCommand, GError, GMessage
 from core.settings         import UserSettings
+from core.utils            import SetAddOnPath
 from gui_core.preferences  import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
 from lmgr.layertree        import LayerTree, LMIcons
 from lmgr.menudata         import ManagerData
@@ -648,8 +649,7 @@
                                    caption = _("Update Addons path?"),
                                    style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
             if dlg.ShowModal() == wx.ID_YES:
-                os.environ['GRASS_ADDON_PATH'] = os.pathsep.join(addonPath)
-                RunCommand('g.gisenv', set = 'ADDON_PATH=%s' % os.environ['GRASS_ADDON_PATH'])
+                SetAddOnPath(os.pathsep.join(addonPath))
         self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
         self.goutput.RunCmd([filename], switchPage = True)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/modules/extensions.py
--- grass/branches/releasebranch_6_4/gui/wxpython/modules/extensions.py	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/gui/wxpython/modules/extensions.py	2012-10-19 11:29:24 UTC (rev 53494)
@@ -33,6 +33,7 @@
 from core             import globalvar
 from core.gcmd        import GError, RunCommand
 from gui_core.forms   import GUI
 from gui_core.widgets import ItemTree
 from gui_core.ghelp   import SearchModuleWindow
@@ -220,15 +221,14 @@
         log.RunCmd(self._getCmd(), onDone = self.OnDone)
     def OnDone(self, cmd, returncode):
-        item = self.tree.GetSelected()
-        if not item or not item.IsOk() or \
-                returncode != 0 or \
-                not os.getenv('GRASS_ADDON_PATH'):
-            return
-        name = self.tree.GetItemText(item)
-        globalvar.grassCmd.add(name)
+        if returncode == 0:
+                SetAddOnPath()
+            globalvar.UpdateGRASSAddOnCommands()
+            log = self.parent.GetLogWindow()
+            log.GetPrompt().SetFilter(None)
     def OnItemSelected(self, event):
         """!Item selected"""
         item = event.GetItem()
Modified: grass/branches/releasebranch_6_4/lib/init/init.bat
--- grass/branches/releasebranch_6_4/lib/init/init.bat	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/lib/init/init.bat	2012-10-19 11:29:24 UTC (rev 53494)
@@ -25,6 +25,10 @@
 set SAVEPATH=%PATH%
 rem DON'T include scripts directory in PATH - .bat files in bin directory
 rem are used to run scripts on Windows
+if exist "%APPDATA%\GRASS6\env.bat" (
+   	call %APPDATA%\GRASS6\env.bat
 if "%GRASS_ADDON_PATH%"=="" set GRASS_ADDON_PATH=%APPDATA%\GRASS6\addons
 PATH=%GISBASE%\bin;%GISBASE%\lib;%GRASS_ADDON_PATH%;%PATH%
Modified: grass/branches/releasebranch_6_4/lib/init/init.sh
--- grass/branches/releasebranch_6_4/lib/init/init.sh	2012-10-19 11:18:33 UTC (rev 53493)
+++ grass/branches/releasebranch_6_4/lib/init/init.sh	2012-10-19 11:29:24 UTC (rev 53494)
@@ -742,15 +742,6 @@
     exit 1
 fi
-# check gisenv's ADDON_PATH
-ADDON_PATH=`g.gisenv ADDON_PATH`
-if [ -n "$ADDON_PATH" ] ; then
-    GRASS_ADDON_PATH="$GRASS_ADDON_PATH:$ADDON_PATH"
-    export GRASS_ADDON_PATH
-    PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
-    export PATH
-fi
 LOCATION="${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}"
 # Check for concurrent use
