[GRASS-SVN] r53496 - in grass/trunk/gui/wxpython: core gui_core
svn_grass at osgeo.org
Fri Oct 19 05:37:59 PDT 2012
Author: martinl
Date: 2012-10-19 05:37:57 -0700 (Fri, 19 Oct 2012)
New Revision: 53496
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/gui_core/preferences.py
wxGUI: StoreEnvVariable() - variable mismatch
write also skipped lines
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2012-10-19 12:11:03 UTC (rev 53495)
+++ grass/trunk/gui/wxpython/core/utils.py 2012-10-19 12:37:57 UTC (rev 53496)
@@ -762,9 +762,12 @@
return os.path.join(os.getenv('HOME'), '.grass%d' % version)
-def StoreEnvVariable(key, value, envFile = None):
+def StoreEnvVariable(key, value = None, envFile = None):
"""!Store environmental variable
+ If value is not given (is None) then environmental variable is
+ unset.
@param key env key
@param value env value
@param envFile path to the environmental file (None for default location)
@@ -779,32 +782,39 @@
# read env file
environ = dict()
+ lineSkipped = list()
if os.path.exists(envFile):
try:
fd = open(envFile)
except IOError, e:
- sys.stderr.write(_("Unable to open file '%s'") % envFile)
+ sys.stderr.write(_("Unable to open file '%s'\n") % envFile)
return
for line in fd.readlines():
+ line = line.rstrip(os.linesep)
try:
- key, value = line.split(' ', 1).strip().split('=', 1)
- except:
- sys.stderr.write(_("%s: unable to parse '%s'") % (envFile, line))
+ k, v = map(lambda x: x.strip(), line.split(' ', 1)[1].split('=', 1))
+ except StandardError, e:
+ sys.stderr.write(_("%s: line skipped - unable to parse '%s'\n"
+ "Reason: %s\n") % (envFile, line, e))
+ lineSkipped.append(line)
continue
- if key in environ:
- sys.stderr.write(_("Duplicated key: %s") % key)
- environ[key] = value
+ if k in environ:
+ sys.stderr.write(_("Duplicated key: %s\n") % k)
+ environ[k] = v
fd.close()
# update environmental variables
+ if value is None and key in environ:
+ del environ[key]
+ else:
+ environ[key] = value
# write update env file
try:
fd = open(envFile, 'w')
except IOError, e:
- sys.stderr.write(_("Unable to create file '%s'") % envFile)
+ sys.stderr.write(_("Unable to create file '%s'\n") % envFile)
return
if windows:
expCmd = 'set'
@@ -813,7 +823,11 @@
for key, value in environ.iteritems():
fd.write('%s %s=%s\n' % (expCmd, key, value))
+ # write also skipped lines
+ for line in lineSkipped:
+ fd.write(line + os.linesep)
fd.close()
def SetAddOnPath(addonPath = None, key = 'PATH'):
@@ -834,7 +848,7 @@
'GRASS%s' % gVersion,
'addons'))
- StoreEnvVariable('GRASS_ADDON_' + key, addonPath)
+ StoreEnvVariable(key = 'GRASS_ADDON_' + key, value = addonPath)
os.environ['GRASS_ADDON_' + key] = addonPath
# From lib/gis/col_str.c, except purple which is mentioned
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2012-10-19 12:11:03 UTC (rev 53495)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2012-10-19 12:37:57 UTC (rev 53496)
@@ -47,7 +47,7 @@
from core import globalvar
from core.gcmd import RunCommand, GError
-from core.utils import ListOfMapsets, GetColorTables, ReadEpsgCodes, GetSettingsPath
+from core.utils import ListOfMapsets, GetColorTables, ReadEpsgCodes, GetSettingsPath, StoreEnvVariable
from core.settings import UserSettings
from gui_core.dialogs import SymbolDialog
@@ -177,9 +177,9 @@
self.settings.SaveToFile()
self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % self.settings.filePath)
if lang:
- RunCommand('g.gisenv', set = 'LANG=%s' % lang)
+ StoreEnvVariable(key = 'LANG', value = lang)
else:
- RunCommand('g.gisenv', unset = 'LANG')
+ StoreEnvVariable(key = 'LANG')
event = wxSettingsChanged()
wx.PostEvent(self, event)
self.Close()
