[GRASS-SVN] r53498 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri Oct 19 06:48:50 PDT 2012
Author: martinl
Date: 2012-10-19 06:48:50 -0700 (Fri, 19 Oct 2012)
New Revision: 53498
grass/trunk/lib/init/grass.py
eliminate gisenv LANG
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2012-10-19 12:41:01 UTC (rev 53497)
+++ grass/trunk/lib/init/grass.py 2012-10-19 13:48:50 UTC (rev 53498)
@@ -52,7 +52,7 @@
else:
grass_config_dirname = ".grass7"
grass_config_dir = os.path.join(os.getenv('HOME'), grass_config_dirname)
- grass_env_file = os.path.join(grass_config_dir, 'bashrc')
+ grass_env_file = None # see check_shell()
gisbase = os.path.normpath(gisbase)
@@ -639,13 +639,25 @@
location = os.path.join(gisdbase, location_name, mapset)
-def set_env_from_gisrc():
- ### TODO: eliminate all env-from-gisrc
+def get_env_variable_from_file(key):
+ if not os.access(grass_env_file, os.R_OK):
+ return None
+ for line in readfile(grass_env_file).split(os.linesep):
+ try:
+ k, v = map(lambda x: x.strip(), line.strip().split(' ', 1)[1].split('=', 1))
+ except:
+ continue
+ if k == key:
+ return v
+ return None
+def set_language():
import locale
- kv = read_gisrc()
### language
- language = kv.get('LANG')
+ language = get_env_variable_from_file('LANG')
if language:
language = language.split('.')[0] # Split off ignored .encoding part if present
orig_language = language
@@ -722,7 +734,7 @@
call(["g.mkfontcap"])
def check_shell():
- global sh, shellname
+ global sh, shellname, grass_env_file
# cygwin has many problems with the shell setup
# below, so i hardcoded everything here.
if os.getenv('CYGWIN'):
@@ -745,6 +757,11 @@
else:
shellname = "shell"
+ if sh in ['csh', 'tcsh']:
+ grass_env_file = os.path.join(grass_config_dir, 'cshrc')
+ elif sh in ['bash', 'msh', 'cygwin']:
+ grass_env_file = os.path.join(grass_config_dir, 'bashrc')
# check for SHELL
if not os.getenv('SHELL'):
fatal(_("The SHELL variable is not set"))
@@ -847,9 +864,11 @@
f.write("GRASS %s > '" % grass_version)
f.write("set BOGUS=``;unset BOGUS")
- path = os.path.join(userhome, ".grass.cshrc")
+ path = os.path.join(userhome, ".grass.cshrc") # left for backward compatibility
if os.access(path, os.R_OK):
- f.write(readfile(path))
+ f.write(readfile(path) + '\n')
+ if os.access(grass_env_file, os.R_OK):
+ f.write(readfile(grass_env_file) + '\n')
mail_re = re.compile(r"^ *set *mail *= *")
@@ -906,7 +925,7 @@
f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
f.close()
exit_val = call([gfile("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
@@ -1094,9 +1113,6 @@
# Ensure GUI is set
read_gui()
-# Get environmental variables from gisenv variables
-set_env_from_gisrc()
# Set PATH, PYTHONPATH
set_paths()
@@ -1164,6 +1180,9 @@
check_shell()
+# Set language
+set_language()
check_batch_job()
if not batch_job:
