[GRASS-SVN] r53506 - in grass/branches/develbranch_6/gui/wxpython: core modules
svn_grass at osgeo.org
Fri Oct 19 08:05:16 PDT 2012
Author: martinl
Date: 2012-10-19 08:05:15 -0700 (Fri, 19 Oct 2012)
New Revision: 53506
grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
wxGUI: remove addon also from prompt
(merge r53505 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-19 15:02:10 UTC (rev 53505)
+++ grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-19 15:05:15 UTC (rev 53506)
@@ -149,16 +149,25 @@
return set(cmd), scripts
-def UpdateGRASSAddOnCommands():
+def UpdateGRASSAddOnCommands(eList = None):
"""!Update list of available GRASS AddOns commands to use when
parsing string from the command line
+ @param eList list of AddOns commands to remove
global grassCmd, grassScripts
# scan addons (path)
if not os.getenv('GRASS_ADDON_PATH'):
return
+ # remove commands first
+ if eList:
+ for ext in eList:
+ if ext in grassCmd:
+ grassCmd.remove(ext)
+ Debug.msg(1, "Number of removed AddOn commands: %d", len(eList))
nCmd = 0
for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
if not os.path.exists(path) or not os.path.isdir(path):
@@ -172,6 +181,7 @@
continue
if name not in grassCmd:
grassCmd.add(name)
+ Debug.msg(3, "AddOn commands: %s", name)
nCmd += 1
if ext == '.bat' and \
ext in grassScripts.keys() and \
@@ -180,6 +190,7 @@
else:
if fname not in grassCmd:
grassCmd.add(fname)
+ Debug.msg(3, "AddOn commands: %s", fname)
nCmd += 1
Debug.msg(1, "Number of new AddOn commands: %d", nCmd)
Modified: grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
--- grass/branches/develbranch_6/gui/wxpython/modules/extensions.py 2012-10-19 15:02:10 UTC (rev 53505)
+++ grass/branches/develbranch_6/gui/wxpython/modules/extensions.py 2012-10-19 15:05:15 UTC (rev 53506)
@@ -467,6 +467,11 @@
self.extList.LoadData()
+ # update prompt
+ globalvar.UpdateGRASSAddOnCommands(eList)
+ log = self.parent.GetLogWindow()
+ log.GetPrompt().SetFilter(None)
def OnCmdDialog(self, event):
"""!Shows command dialog"""
GUI(parent = self).ParseCommand(cmd = ['g.extension.py'])
