[GRASS-SVN] r53509 - grass/branches/develbranch_6/gui/wxpython/gui_core
svn_grass at osgeo.org
Fri Oct 19 09:04:01 PDT 2012
Author: martinl
Date: 2012-10-19 09:04:01 -0700 (Fri, 19 Oct 2012)
New Revision: 53509
grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
wxGUI/form: respect `key_desc` for map selector
(merge r53508 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py 2012-10-19 16:00:35 UTC (rev 53508)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py 2012-10-19 16:04:01 UTC (rev 53509)
@@ -1106,8 +1106,8 @@
selection = gselect.Select(parent = which_panel, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE,
type = p.get('element', ''),
- multiple = multiple, mapsets = mapsets,
- fullyQualified = p.get('age', 'old') == 'old')
+ multiple = multiple, nmaps = len(p.get('key_desc', [])),
+ mapsets = mapsets, fullyQualified = p.get('age', 'old') == 'old')
# A select.Select is a combobox with two children: a textctl and a popupwindow;
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py 2012-10-19 16:00:35 UTC (rev 53508)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py 2012-10-19 16:04:01 UTC (rev 53509)
@@ -56,17 +56,18 @@
class Select(wx.combo.ComboCtrl):
def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
- type = None, multiple = False, mapsets = None,
- updateOnPopup = True, onPopup = None,
+ type = None, multiple = False, nmaps = 1,
+ mapsets = None, updateOnPopup = True, onPopup = None,
fullyQualified = True):
"""!Custom control to create a ComboBox with a tree control to
display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple
- selections, when argument multiple=True. Multiple selections
- are separated by commas.
+ selections, when argument <em>multiple</em> is True. Multiple
+ selections are separated by commas.
@param type type of GIS elements ('raster, 'vector', ...)
- @param multiple multiple input allowed?
+ @param multiple True for multiple input
+ @param nmaps number of maps to be entered
@param mapsets force list of mapsets (otherwise search path)
@param updateOnPopup True for updating list of elements on popup
@param onPopup function to be called on Popup
@@ -81,7 +82,7 @@
self.SetPopupExtents(0, 100)
if type:
self.tcp.SetData(type = type, mapsets = mapsets,
+ multiple = multiple, nmaps = nmaps,
updateOnPopup = updateOnPopup, onPopup = onPopup,
fullyQualified = fullyQualified)
self.GetChildren()[0].Bind(wx.EVT_KEY_UP, self.OnKeyUp)
@@ -105,14 +106,14 @@
"""!Load elements"""
self.tcp.GetElementList()
- def SetType(self, etype, multiple = False, mapsets = None,
- updateOnPopup = True, onPopup = None):
+ def SetType(self, etype, multiple = False, nmaps = 1,
+ mapsets = None, updateOnPopup = True, onPopup = None):
"""!Param set element type for widget
@param etype element type, see gselect.ElementSelect
self.tcp.SetData(type = etype, mapsets = mapsets,
updateOnPopup = updateOnPopup, onPopup = onPopup)
class VectorSelect(Select):
@@ -150,6 +151,7 @@
self.value = [] # for multiple is False -> len(self.value) in [0,1]
self.curitem = None
self.multiple = False
+ self.nmaps = 1
self.type = None
self.mapsets = None
self.updateOnPopup = True
@@ -480,11 +482,16 @@
if self.fullyQualified:
fullName += '@' + self.seltree.GetItemText(mapsetItem).split(':', -1)[1].strip()
- if self.multiple is True:
- # text item should be unique
+ if self.multiple:
self.value.append(fullName)
else:
- self.value = [fullName]
+ if self.nmaps > 1: # see key_desc
+ if len(self.value) >= self.nmaps:
+ self.value = [fullName]
+ else:
+ self.value.append(fullName)
+ else:
self.Dismiss()
@@ -514,12 +521,17 @@
+ if self.multiple:
else:
+ else:
+ else:
self.Dismiss()
evt.Skip()
@@ -532,6 +544,8 @@
self.mapsets = kargs['mapsets']
if 'multiple' in kargs:
self.multiple = kargs['multiple']
+ if 'nmaps' in kargs:
+ self.nmaps = kargs['nmaps']
if 'updateOnPopup' in kargs:
self.updateOnPopup = kargs['updateOnPopup']
if 'onPopup' in kargs:
