[GRASS-SVN] r53531 - grass/branches/develbranch_6/gui/wxpython/gui_core
svn_grass at osgeo.org
Tue Oct 23 11:45:42 PDT 2012
Author: martinl
Date: 2012-10-23 11:45:42 -0700 (Tue, 23 Oct 2012)
New Revision: 53531
grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
bugfix #1769 + variables in CamelCase
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py 2012-10-23 18:31:03 UTC (rev 53530)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py 2012-10-23 18:45:42 UTC (rev 53531)
@@ -785,8 +785,8 @@
else:
self.goutput = None
- self.manualTab = HelpPanel(parent = self, grass_command = self.task.name)
- if not self.manualTab.IsFile():
+ self.manualTab = HelpPanel(parent = self, command = self.task.name)
+ if not self.manualTab.GetFile():
self.manualTab.Hide()
else:
self.notebook.AddPage(page = self.manualTab, text = _("Manual"), name = 'manual')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py 2012-10-23 18:31:03 UTC (rev 53530)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py 2012-10-23 18:45:42 UTC (rev 53531)
@@ -572,13 +572,13 @@
The SYNOPSIS section is skipped, since this Panel is supposed to
be integrated into the cmdPanel and options are obvious there.
- def __init__(self, parent, grass_command, text, skip_description,
+ def __init__(self, parent, command, text, skipDescription,
**kwargs):
- """!If grass_command is given, the corresponding HTML help
+ """!If command is given, the corresponding HTML help
file will be presented, with all links pointing to absolute
paths of local files.
- If 'skip_description' is True, the HTML corresponding to
+ If 'skipDescription' is True, the HTML corresponding to
SYNOPSIS will be skipped, thus only presenting the help file
from the DESCRIPTION section onwards.
@@ -589,25 +589,24 @@
wx.InitAllImageHandlers()
wx.html.HtmlWindow.__init__(self, parent = parent, **kwargs)
- gisbase = os.getenv("GISBASE")
self.loaded = False
self.history = list()
self.historyIdx = 0
- self.fspath = os.path.join(gisbase, "docs", "html")
+ self.fspath = os.path.join(os.getenv("GISBASE"), "docs", "html")
self.SetStandardFonts (size = 10)
self.SetBorders(10)
if text is None:
- if skip_description:
- url = os.path.join(self.fspath, grass_command + ".html")
+ if skipDescription:
+ url = os.path.join(self.fspath, command + ".html")
self.fillContentsFromFile(url,
- skip_description = skip_description)
+ skipDescription = skipDescription)
self.history.append(url)
self.loaded = True
else:
### FIXME: calling LoadPage() is strangely time-consuming (only first call)
- # self.LoadPage(self.fspath + grass_command + ".html")
+ # self.LoadPage(self.fspath + command + ".html")
self.loaded = False
else:
self.SetPage(text)
@@ -623,7 +622,7 @@
super(HelpWindow, self).OnLinkClicked(linkinfo)
- def fillContentsFromFile(self, htmlFile, skip_description = True):
+ def fillContentsFromFile(self, htmlFile, skipDescription = True):
"""!Load content from file"""
aLink = re.compile(r'(<a href="?)(.+\.html?["\s]*>)', re.IGNORECASE)
imgLink = re.compile(r'(<img src="?)(.+\.[png|gif])', re.IGNORECASE)
@@ -636,7 +635,7 @@
if not skip:
# do skip the options description if requested
if "SYNOPSIS" in l:
- skip = skip_description
+ skip = skipDescription
else:
# FIXME: find only first item
findALink = aLink.search(l)
@@ -656,13 +655,12 @@
self.loaded = False
class HelpPanel(wx.Panel):
- def __init__(self, parent, grass_command = "index", text = None,
- skip_description = False, **kwargs):
- self.grass_command = grass_command
+ def __init__(self, parent, command = "index", text = None,
+ skipDescription = False, **kwargs):
+ self.command = command
wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
- self.content = HelpWindow(self, grass_command, text,
- skip_description)
+ self.content = HelpWindow(self, command, text, skipDescription)
self.btnNext = wx.Button(parent = self, id = wx.ID_ANY,
label = _("&Next"))
@@ -698,14 +696,27 @@
def LoadPage(self, path = None):
"""!Load page"""
if not path:
- path = os.path.join(self.content.fspath, self.grass_command + ".html")
+ path = self.GetFile()
self.content.history.append(path)
self.content.LoadPage(path)
- def IsFile(self):
- """!Check if file exists"""
- return os.path.isfile(os.path.join(self.content.fspath, self.grass_command + ".html"))
+ def GetFile(self):
+ """!Get HTML file"""
+ fMan = os.path.join(self.content.fspath, self.command + ".html")
+ if os.path.isfile(fMan):
+ return fMan
+ # check also addons
+ aPath = os.getenv('GRASS_ADDON_PATH')
+ if aPath:
+ for path in aPath.split(os.pathsep):
+ faMan = os.path.join(path, "docs", "html",
+ self.command + ".html")
+ if os.path.isfile(faMan):
+ return faMan
+ return None
def IsLoaded(self):
return self.content.loaded
