[GRASS-SVN] r53543 - grass-addons/grass7/raster/r.in.wms2
svn_grass at osgeo.org
Wed Oct 24 07:54:55 PDT 2012
Author: turek
Date: 2012-10-24 07:54:55 -0700 (Wed, 24 Oct 2012)
New Revision: 53543
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
grass-addons/grass7/raster/r.in.wms2/wms_base.py
grass-addons/grass7/raster/r.in.wms2/wms_drv.py
r.in.wms2: Added NASA OnEarth Tiled WMS support, minor imrovements in WMTS
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-10-24 10:41:58 UTC (rev 53542)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-10-24 14:54:55 UTC (rev 53543)
@@ -2,18 +2,15 @@
<em>r.in.wms2</em> handles all of downloading and importing raster
data from an <a href="http://www.opengeospatial.org/standards/wms">OGC
-WMS</a> and <a href="http://www.opengeospatial.org/standards/wmts">OGC
-WMTS</a> web mapping servers. It need only be told the desired data to
+WMS</a>, <a href="http://www.opengeospatial.org/standards/wmts">OGC
+WMTS</a> and <a href="http://onearth.jpl.nasa.gov/tiled.html">NASA OnEarth
+Tiled WMS</a> web mapping servers. It needs only be told the desired data to
collect (bounds and resolution) via a region, the server to get the
data from, and the layer or layers to get. It downloads the data in
tiles, reprojects it, imports it, and patches it back together.
<h2>NOTES</h2>
-By default data is downloaded to <tt>$GISDBASE/wms_download</tt>. This can be changed
-by setting the <b>folder</b> option when using <em>r.in.wms</em>.
<p>To understand the data you are getting it is necessary to look at the
capabilities of the WMS server. This should be available via a capabilities
@@ -21,6 +18,17 @@
<a href="http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities">example
capabilities request to NASA's OnEarth server</a>.
+<h3>>NASA OnEarth Tiled WMS</h3>
+Into parameter <b>layers</b> insert name of <b>TiledGroup</b> from Tile Service file.
+<br>
+<br>
+Time variable is possible to specify in <b>urlparams</b> parameter.
+<br>
+e. g: urlparams='time=2012-1-1'
<h2>EXAMPLES</h2>
<h3>General Get Capabilities Request</h3>
@@ -29,10 +37,10 @@
r.in.wms2 -c url=http://wms.cuzk.cz/wms.asp
</pre></div>
-<h3>>Download raster data from WMS server (GetMap request)</h3>
+<h3>Download raster data from WMS server (GetMap request)</h3>
-World extend data:
+<h4>World extend data:</h4>
<div class="code"><pre>
r.in.wms2 url=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
@@ -43,18 +51,18 @@
r.in.wms2 url=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
</pre></div>
* Server supports only WMS 1.1.1
-<br>
-<br>
r.in.wms2 url=http://gpp3-wxs.ign.fr/yourAPIkey/geoportail/wmts layers=ORTHOIMAGERY.ORTHOPHOTOS output=orthophoto srs=3857 format=jpeg driver=WMTS_GRASS style=normal password=* username=*
</pre></div>
-* Username, password and API key can be get at <a href="http://api.ign.fr/">IGN API</a> website
-<br>
-<br>
+* Username, password and API key can be get from <a href="http://api.ign.fr/">IGN API</a> website
-Data in extend of Czech Republic:
+<div class="code"><pre>
+r.in.wms2 output=global_mosaic url=http://onearth.jpl.nasa.gov/wms.cgi layers='Global Mosaic, visual' driver=OnEarth_GRASS
+</pre></div>
+<h4>Data in extend of Czech Republic:</h4>
r.in.wms2 output=kn url=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
</pre></div>
@@ -63,6 +71,15 @@
r.in.wms2 url=http://geoportal.cuzk.cz/WMTS_ORTOFOTO/WMTService.aspx layers=orto output=ortofoto srs=3857 format=jpeg driver=WMTS_GRASS style=default
</pre></div>
+<H2>REQUIRED PROGRAMS</H2>
+<EM>r.in.wms2</EM> requires the following programs to work:
+<ul>
+<li><a href="http://www.gdal.org">gdalwarp</a>
+</ul>
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-10-24 10:41:58 UTC (rev 53542)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-10-24 14:54:55 UTC (rev 53543)
@@ -149,8 +149,8 @@
#% key: driver
#% type:string
#% description: Driver for communication with server
-#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS
-#% answer:WMS_GDAL
+#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
+#% answer:WMS_GRASS
#%end
Modified: grass-addons/grass7/raster/r.in.wms2/wms_base.py
--- grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-10-24 10:41:58 UTC (rev 53542)
+++ grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-10-24 14:54:55 UTC (rev 53543)
@@ -81,6 +81,9 @@
for key in ['url', 'layers', 'styles', 'output', 'method']:
self.params[key] = options[key].strip()
+ if self.params['styles'] != "" and 'OnEarth_GRASS' in self.params['driver']:
+ grass.warning(_("Parameter '%s' is not relevant for %s driver.") % ('styles', 'OnEarth_GRASS'))
for key in ['password', 'username', 'urlparams']:
if self.params[key] != "" and 'GRASS' not in self.params['driver']:
@@ -88,18 +91,18 @@
if (self.params ['password'] and self.params ['username'] == '') or \
(self.params ['password'] == '' and self.params ['username']):
- grass.fatal(_("Please insert both password and username parameters or none of them."))
+ grass.fatal(_("Please insert both %s and %s parameters or none of them." % ('password', 'username')))
self.params['bgcolor'] = options['bgcolor'].strip()
if self.params['bgcolor'] != "" and 'WMS_GRASS' not in self.params['driver']:
grass.warning(_("Parameter '%s' is relevant only for %s driver.") % ('bgcolor', 'WMS_GRASS'))
- self.params['wms_version'] = options['wms_version']
+ self.params['wms_version'] = options['wms_version']
if self.params['wms_version'] == "1.3.0":
self.params['proj_name'] = "CRS"
else:
- self.params['proj_name'] = "SRS"
+ self.params['proj_name'] = "SRS"
if options['format'] == "geotiff":
self.params['format'] = "image/geotiff"
elif options['format'] == "tiff":
@@ -108,13 +111,15 @@
self.params['format'] = "image/png"
elif options['format'] == "jpeg":
self.params['format'] = "image/jpeg"
- if flags['o']:
+ if not flags['o'] and \
+ 'WMS' in self.params['driver']:
grass.warning(_("JPEG format does not support transparency"))
elif self.params['format'] == "gif":
self.params['format'] = "image/gif"
else:
self.params['format'] = self.params['format']
+ #TODO: get srs from Tile Service file in OnEarth_GRASS driver
self.params['srs'] = int(options['srs'])
if self.params['srs'] <= 0:
grass.fatal(_("Invalid EPSG code %d") % self.params['srs'])
@@ -207,12 +212,14 @@
if 'WMTS' in options['driver']:
cap_url += "?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0"
+ elif 'OnEarth' in options['driver']:
+ cap_url += "?REQUEST=GetTileService"
else:
cap_url += "?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=" + options['wms_version']
try:
cap = urlopen(cap_url)
- except (IOError, HTTPError):
+ except (IOError, HTTPError, HTTPException):
grass.fatal(_("Unable to get capabilities from '%s'") % options['url'])
return cap
@@ -354,8 +361,12 @@
self.cleanup_layers = True
# setting region for full extend of imported raster
- os.environ['GRASS_REGION'] = grass.region_env(rast = self.params['output'] + '.red')
+ if grass.find_file(self.params['output'] + '.red', element = 'cell', mapset = '.')['file']:
+ region_map = self.params['output'] + '.red'
+ else:
+ os.environ['GRASS_REGION'] = grass.region_env(rast = region_map)
# mask created from alpha layer, which describes real extend
# of warped layer (may not be a rectangle), also mask contains
# transparent parts of raster
@@ -377,12 +388,14 @@
input = self.params['output'] + '.alpha') != 0:
grass.fatal(_('%s failed') % 'r.mask')
- if grass.run_command('r.composite',
- quiet = True,
- red = self.params['output'] + '.red',
- green = self.params['output'] + '.green',
- blue = self.params['output'] + '.blue',
- output = self.params['output'] ) != 0:
+ #TODO one band + alpha band?
+ if grass.run_command('r.composite',
+ quiet = True,
+ red = self.params['output'] + '.red',
+ green = self.params['output'] + '.green',
+ blue = self.params['output'] + '.blue',
+ output = self.params['output'] ) != 0:
grass.fatal(_('%s failed') % 'r.composite')
grass.try_remove(temp_warpmap)
Modified: grass-addons/grass7/raster/r.in.wms2/wms_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-10-24 10:41:58 UTC (rev 53542)
+++ grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-10-24 14:54:55 UTC (rev 53543)
@@ -1,6 +1,6 @@
+import grass.script as grass
import base64
-import grass.script as grass
from urllib2 import urlopen, HTTPError
from httplib import HTTPException
@@ -32,6 +32,8 @@
req_mgr = WMTSRequestMgr(self.params, self.bbox, self.region, self.proj_srs, self._fetchCapabilities(self.params))
elif self.params['driver'] == 'WMS_GRASS':
req_mgr = WMSRequestMgr(self.params, self.bbox, self.region, self.tile_size, self.proj_srs)
+ elif self.params['driver'] == 'OnEarth_GRASS':
+ req_mgr = OnEarthRequestMgr(self.params, self.bbox, self.region, self.proj_srs, self._fetchCapabilities(self.params))
# get information about size in pixels and bounding box of raster, where all tiles will be joined
map_region = req_mgr.GetMapRegion()
@@ -53,8 +55,7 @@
query_url = tile[0]
# the tile size and offset in pixels for placing it into raster where tiles are joined
- tileRef = tile[1]
+ tile_ref = tile[1]
grass.debug(query_url)
try:
request = urllib2.Request(query_url)
@@ -123,11 +124,11 @@
init = False
# tile is written into temp_map
- tile_to_temp_map = tile_dataset.ReadRaster(0, 0, tileRef['sizeX'], tileRef['sizeY'],
- tileRef['sizeX'], tileRef['sizeY'])
+ tile_to_temp_map = tile_dataset.ReadRaster(0, 0, tile_ref['sizeX'], tile_ref['sizeY'],
+ tile_ref['sizeX'], tile_ref['sizeY'])
- temp_map_dataset.WriteRaster(tileRef['t_cols_offset'], tileRef['t_rows_offset'],
- tileRef['sizeX'], tileRef['sizeY'], tile_to_temp_map)
+ temp_map_dataset.WriteRaster(tile_ref['t_cols_offset'], tile_ref['t_rows_offset'],
+ tile_ref['sizeX'], tile_ref['sizeY'], tile_to_temp_map)
tile_dataset = None
tile_dataset_info = None
@@ -200,6 +201,80 @@
class BaseRequestMgr:
"""!Base class for request managers.
+ def _computeRequestData(self, bbox, tl_corner, tile_span, tile_size, mat_num_bbox):
+ """!Initialize data needed for iteration through tiles. Used by WMTS_GRASS and OnEarth_GRASS drivers.
+ epsilon = 1e-15
+ # request data bbox specified in row and col number
+ self.t_num_bbox = {}
+ self.t_num_bbox['min_col'] = int(floor((bbox['minx'] - tl_corner['minx']) / tile_span['x'] + epsilon))
+ self.t_num_bbox['max_col'] = int(floor((bbox['maxx'] - tl_corner['minx']) / tile_span['x'] - epsilon))
+ self.t_num_bbox['min_row'] = int(floor((tl_corner['maxy'] - bbox['maxy']) / tile_span['y'] + epsilon))
+ self.t_num_bbox['max_row'] = int(floor((tl_corner['maxy'] - bbox['miny']) / tile_span['y'] - epsilon))
+ # Does required bbox intersects bbox of data available on server?
+ self.intersects = False
+ for col in ['min_col', 'max_col']:
+ for row in ['min_row', 'max_row']:
+ if (self.t_num_bbox['min_row'] <= self.t_num_bbox[row] and self.t_num_bbox[row] <= mat_num_bbox['max_row']) and \
+ (self.t_num_bbox['min_col'] <= self.t_num_bbox[col] and self.t_num_bbox[col] <= mat_num_bbox['max_col']):
+ self.intersects = True
+ if not self.intersects:
+ grass.warning(_('Region is out of server data extend.'))
+ self.map_region = None
+ return
+ # crop request bbox to server data bbox extend
+ if self.t_num_bbox['min_col'] < (mat_num_bbox['min_col']):
+ self.t_num_bbox['min_col'] = int(mat_num_bbox['min_col'])
+ if self.t_num_bbox['max_col'] > (mat_num_bbox['max_col']):
+ self.t_num_bbox['max_col'] = int(mat_num_bbox['max_col'])
+ if self.t_num_bbox['min_row'] < (mat_num_bbox['min_row']):
+ self.t_num_bbox['min_row'] = int(mat_num_bbox['min_row'])
+ if self.t_num_bbox['max_row'] > (mat_num_bbox['max_row']):
+ self.t_num_bbox['max_row'] = int(mat_num_bbox['max_row'])
+ num_tiles = (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1) * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
+ grass.message(_('Fetching %d tiles with %d x %d pixel size per tile...') % (num_tiles, tile_size['x'], tile_size['y']))
+ # georeference of raster, where tiles will be merged
+ self.map_region = {}
+ self.map_region['minx'] = self.t_num_bbox['min_col'] * tile_span['x'] + tl_corner['minx']
+ self.map_region['maxy'] = tl_corner['maxy'] - (self.t_num_bbox['min_row']) * tile_span['y']
+ self.map_region['maxx'] = (self.t_num_bbox['max_col'] + 1) * tile_span['x'] + tl_corner['minx']
+ self.map_region['miny'] = tl_corner['maxy'] - (self.t_num_bbox['max_row'] + 1) * tile_span['y']
+ # size of raster, where tiles will be merged
+ self.map_region['cols'] = int(tile_size['x'] * (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1))
+ self.map_region['rows'] = int(tile_size['y'] * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1))
+ # hold information about current column and row during iteration
+ self.i_col = self.t_num_bbox['min_col']
+ self.i_row = self.t_num_bbox['min_row']
+ # bbox for first tile request
+ self.query_bbox = {
+ 'minx' : tl_corner['minx'],
+ 'maxy' : tl_corner['maxy'],
+ 'maxx' : tl_corner['minx'] + tile_span['x'],
+ 'miny' : tl_corner['maxy'] - tile_span['y'],
+ self.tile_ref = {
+ 'sizeX' : tile_size['x'],
+ 'sizeY' : tile_size['y']
def _isGeoProj(self, proj):
"""!Is it geographic projection?
@@ -209,32 +284,6 @@
return True
return False
- def find(self, etreeElement, tag, ns = None):
- """!Wraper for etree element find method.
- if not ns:
- res = etreeElement.find(tag)
- else:
- res = etreeElement.find(ns(tag))
- if res is None:
- grass.fatal(_("Unable to parse capabilities file. \n Tag '%s' was not found.") % tag)
- return res
- def findall(self, etreeElement, tag, ns = None):
- """!Wraper for etree element findall method.
- if not ns:
- res = etreeElement.findall(tag)
- else:
- res = etreeElement.findall(ns(tag))
- if not res:
- return res
class WMSRequestMgr(BaseRequestMgr):
def __init__(self, params, bbox, region, tile_size, proj_srs, cap_file = None):
@@ -245,7 +294,7 @@
(params['wms_version'], params['layers'], tile_size['cols'], tile_size['rows'], params['styles'], \
params['bgcolor'], params['transparent']))
self.url += "&" +proj+ "&" + "FORMAT=" + params['format']
self.bbox = bbox
self.proj_srs = proj_srs
self.tile_rows = tile_size['rows']
@@ -292,17 +341,17 @@
return self.map_region
def GetNextTile(self):
- """!Get url for request the tile from server and information for merging the tile with other tiles
+ """!Get url for tile request from server and information for merging the tile with other tiles
- tileRef = {}
+ tile_ref = {}
if self.i_x >= self.num_tiles_x:
return None
- tileRef['sizeX'] = self.tile_cols
+ tile_ref['sizeX'] = self.tile_cols
if self.i_x == self.num_tiles_x - 1 and self.last_tile_x:
- tileRef['sizeX'] = self.last_tile_x_size
+ tile_ref['sizeX'] = self.last_tile_x_size
# set bbox for tile (N, S)
if self.i_y != 0:
@@ -312,9 +361,9 @@
self.tile_bbox['maxy'] = self.bbox['maxy']
self.tile_bbox['miny'] = self.bbox['maxy'] - self.tile_length_y
- tileRef['sizeY'] = self.tile_rows
+ tile_ref['sizeY'] = self.tile_rows
if self.i_y == self.num_tiles_y - 1 and self.last_tile_y:
- tileRef['sizeY'] = self.last_tile_y_size
+ tile_ref['sizeY'] = self.last_tile_y_size
if self._isGeoProj(self.proj_srs) and self.version == "1.3.0":
query_bbox = self._flipBbox(self.tile_bbox, self.proj_srs)
@@ -322,8 +371,8 @@
query_bbox = self.tile_bbox
query_url = self.url + "&" + "BBOX=%s,%s,%s,%s" % ( query_bbox['minx'], query_bbox['miny'], query_bbox['maxx'], query_bbox['maxy'])
- tileRef['t_cols_offset'] = int(self.tile_cols * self.i_x)
- tileRef['t_rows_offset'] = int(self.tile_rows * self.i_y)
+ tile_ref['t_cols_offset'] = int(self.tile_cols * self.i_x)
+ tile_ref['t_rows_offset'] = int(self.tile_rows * self.i_y)
if self.i_y >= self.num_tiles_y - 1:
self.i_y = 0
@@ -334,7 +383,7 @@
else:
self.i_y += 1
- return query_url, tileRef
+ return query_url, tile_ref
def _flipBbox(self, bbox, proj, version):
@@ -374,33 +423,39 @@
cap_tree = etree.parse(cap_file)
root = cap_tree.getroot()
- # get layer tile matrix sets with same projection
- mat_sets = self._getMatSets(root, params)
+ # get layer tile matrix sets with required projection
+ mat_sets = self._getMatSets(root, params['layers'], params['srs']) #[[TileMatrixSet, TileMatrixSetLink], ....]
- # TODO: what if more tile matrix sets are returned?
- params['tile_matrix_set'] = mat_sets[0].find(self._ns_ows('Identifier')).text
+ # TODO: what if more tile matrix sets have required srs (returned more than 1)?
+ mat_set = mat_sets[0][0]
+ mat_set_link = mat_sets[0][1]
+ params['tile_matrix_set'] = mat_set.find(self._ns_ows('Identifier')).text
# find tile matrix with resolution closest and smaller to wanted resolution
- tile_mat = self._findTileMats(mat_sets[0].findall(self._ns_wmts('TileMatrix')), region, bbox)
+ tile_mat = self._findTileMats(mat_set.findall(self._ns_wmts('TileMatrix')), region, bbox)
+ # get extend of data available on server expressed in max/min rows and cols of tile matrix
+ mat_num_bbox = self._getMatSize(tile_mat, mat_set_link)
# initialize data needed for iteration through tiles
- self._computeRequestData(tile_mat, params, bbox)
+ self._computeRequestData(tile_mat, params, bbox, mat_num_bbox)
def GetMapRegion(self):
"""!Get size in pixels and bounding box of raster where all tiles will be merged.
- def _getMatSets(self, root, params):
+ def _getMatSets(self, root, layer_name, srs):
"""!Get matrix sets which are available for chosen layer and have required EPSG.
contents = self.find(root, 'Contents', self._ns_wmts)
layers = self.findall(contents, 'Layer', self._ns_wmts)
ch_layer = None
for layer in layers:
layer_id = layer.find(self._ns_ows('Identifier')).text
- if layer_id and layer_id == params['layers']:
+ if layer_id and layer_id == layer_name:
ch_layer = layer
break
@@ -421,16 +476,16 @@
if mat_set_id and mat_set_id != mat_set_link_id:
continue
mat_set_srs = mat_set.find(self._ns_ows('SupportedCRS')).text
- if mat_set_srs and mat_set_srs.lower() == ("EPSG:"+ str(params['srs'])).lower():
- suitable_mat_sets.append(mat_set)
+ if mat_set_srs and mat_set_srs.lower() == ("EPSG:"+ str(srs)).lower():
+ suitable_mat_sets.append([mat_set, link])
if not suitable_mat_sets:
- grass.fatal(_("Layer '%s' is not available with %s code.") % (params['layers'], "EPSG:" + str(params['srs'])))
+ grass.fatal(_("Layer '%s' is not available with %s code.") % (params['layers'], "EPSG:" + str(srs)))
- return suitable_mat_sets
+ return suitable_mat_sets # [[TileMatrixSet, TileMatrixSetLink], ....]
def _findTileMats(self, tile_mats, region, bbox):
- """!Find tile matrix set with closest and smaller resolution to requested resolution
+ """!Find best tile matrix set for requested resolution.
scale_dens = []
@@ -458,7 +513,7 @@
return best_t_mat
def _getMetersPerUnit(self):
- """!Get coefficient which allows to convert units of request projection into meters
+ """!Get coefficient which allows to convert units of request projection into meters.
if self.meters_per_unit:
return self.meters_per_unit
@@ -487,99 +542,85 @@
- def _computeRequestData(self, tile_mat, params, bbox):
- """!Initialize data needed for iteration through tiles.
- scale_den = float(tile_mat.find(self._ns_wmts('ScaleDenominator')).text)
+ def _getMatSize(self, tile_mat, mat_set_link):
+ """!Get rows and cols extend of data available on server for chosen layer and tile matrix.
- pixel_span = scale_den * self.pixel_size / self._getMetersPerUnit()
+ # general tile matrix size
+ mat_num_bbox = {}
+ mat_num_bbox['min_col'] = mat_num_bbox['min_row'] = 0
+ mat_num_bbox['max_col'] = int(tile_mat.find(self._ns_wmts('MatrixWidth')).text) - 1
+ mat_num_bbox['max_row'] = int(tile_mat.find(self._ns_wmts('MatrixHeight')).text) - 1
- tl_corner = tile_mat.find(self._ns_wmts('TopLeftCorner')).text.split(' ')
+ # get extend restriction in TileMatrixSetLink for the tile matrix, if exists
+ tile_mat_set_limits = mat_set_link.find((self._ns_wmts('TileMatrixSetLimits')))
+ if tile_mat_set_limits is None:
+ return mat_num_bbox
- self.t_cols = int(tile_mat.find(self._ns_wmts('TileWidth')).text)
- t_length_x = pixel_span * self.t_cols
- self.t_rows = int(tile_mat.find(self._ns_wmts('TileHeight')).text)
- t_length_y = pixel_span * self.t_rows
- t_mat_min_x = float(tl_corner[0])
- t_mat_max_y = float(tl_corner[1])
- epsilon = 2e-15
+ tile_mat_id = tile_mat.find(self._ns_ows('Identifier')).text
+ tile_mat_limits = tile_mat_set_limits.findall(self._ns_wmts('TileMatrixLimits'))
- self.t_num_bbox = {}
- self.t_num_bbox['min_col'] = int(floor((bbox['minx'] - t_mat_min_x) / t_length_x + epsilon))
- self.t_num_bbox['max_col'] = int(floor((bbox['maxx'] - t_mat_min_x) / t_length_x - epsilon))
+ for limit in tile_mat_limits:
+ limit_tile_mat = limit.find(self._ns_wmts('TileMatrix'))
+ limit_id = limit_tile_mat.text
- self.t_num_bbox['min_row'] = int(floor((t_mat_max_y - bbox['maxy']) / t_length_y + epsilon))
- self.t_num_bbox['max_row'] = int(floor((t_mat_max_y - bbox['miny']) / t_length_y - epsilon))
+ if limit_id is None:
+ continue
- matWidth = int(tile_mat.find(self._ns_wmts('MatrixWidth')).text)
- matHeight = int(tile_mat.find(self._ns_wmts('MatrixHeight')).text)
+ if limit_id == tile_mat_id:
- self.intersects = False
- for col in ['min_col', 'max_col']:
- for row in ['min_row', 'max_row']:
- if (0 <= self.t_num_bbox[row] and self.t_num_bbox[row] <= matHeight) and \
- (0 <= self.t_num_bbox[col] and self.t_num_bbox[col] <= matWidth):
- self.intersects = True
- if not self.intersects:
- grass.warning(_('Region is out of server data extend.'))
- self.map_region = None
- return
+ for i in [['min_row', 'MinTileRow'], ['max_row', 'MaxTileRow'], \
+ ['min_col', 'MinTileCol'], ['max_col', 'MaxTileCol']]:
+ i_tag = limit.find(self._ns_wmts(i[1]))
- if self.t_num_bbox['min_col'] < 0:
- self.t_num_bbox['min_col'] = 0
+ if i_tag is None:
+ continue
+ try:
+ mat_num_bbox[i[0]] = int(i_tag.text)
+ except ValueError:
+ continue
+ break
- if self.t_num_bbox['max_col'] > (matWidth - 1):
- self.t_num_bbox['max_col'] = matWidth - 1
+ def _computeRequestData(self, tile_mat, params, bbox, mat_num_bbox):
+ scale_den = float(tile_mat.find(self._ns_wmts('ScaleDenominator')).text)
- if self.t_num_bbox['min_row'] < 0:
- self.t_num_bbox['min_row'] = 0
+ pixel_span = scale_den * self.pixel_size / self._getMetersPerUnit()
- if self.t_num_bbox['max_row'] > (matHeight - 1):
- self.t_num_bbox['max_row'] = matHeight - 1
+ tl_str = tile_mat.find(self._ns_wmts('TopLeftCorner')).text.split(' ')
- num_tiles = (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1) * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
- grass.message(_('Fetching %d tiles with %d x %d pixel size per tile...') % (num_tiles, self.t_cols, self.t_rows))
+ tl_corner = {}
+ tl_corner['minx'] = float(tl_str[0])
+ tl_corner['maxy'] = float(tl_str[1])
+ tile_span = {}
+ self.tile_size = {}
+ self.tile_size['x'] = int(tile_mat.find(self._ns_wmts('TileWidth')).text)
+ tile_span['x'] = pixel_span * self.tile_size['x']
+ self.tile_size['y'] = int(tile_mat.find(self._ns_wmts('TileHeight')).text)
+ tile_span['y'] = pixel_span * self.tile_size['y']
self.url = params['url'] + ("?SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&" \
"LAYER=%s&STYLE=%s&FORMAT=%s&TILEMATRIXSET=%s&TILEMATRIX=%s" % \
(params['layers'], params['styles'], params['format'],
params['tile_matrix_set'], tile_mat.find(self._ns_ows('Identifier')).text ))
- if params['urlparams'] != "":
- self.url += "&" + params['urlparams']
+ BaseRequestMgr._computeRequestData(self, bbox, tl_corner, tile_span, self.tile_size, mat_num_bbox)
- self.map_region = {}
- self.map_region['minx'] = self.t_num_bbox['min_col'] * t_length_x + t_mat_min_x
- self.map_region['maxy'] = t_mat_max_y - (self.t_num_bbox['min_row']) * t_length_y
- self.map_region['maxx'] = (self.t_num_bbox['max_col'] + 1) * t_length_x + t_mat_min_x
- self.map_region['miny'] = t_mat_max_y - (self.t_num_bbox['max_row'] + 1) * t_length_y
- self.map_region['cols'] = self.t_cols * (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1)
- self.map_region['rows'] = self.t_rows * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
- self.i_col = self.t_num_bbox['min_col']
- self.i_row = self.t_num_bbox['min_row']
- self.tileRef = {
- 'sizeX' : self.t_cols,
- 'sizeY' : self.t_rows
+ """!Get url for tile request from server and information for merging the tile with other tiles.
if not self.intersects or self.i_col > self.t_num_bbox['max_col']:
return None
query_url = self.url + "&TILECOL=%i&TILEROW=%i" % (int(self.i_col), int(self.i_row))
- self.tileRef['t_cols_offset'] = int(self.t_cols * (self.i_col - self.t_num_bbox['min_col']))
- self.tileRef['t_rows_offset'] = int(self.t_rows * (self.i_row - self.t_num_bbox['min_row']))
+ self.tile_ref['t_cols_offset'] = int(self.tile_size['x'] * (self.i_col - self.t_num_bbox['min_col']))
+ self.tile_ref['t_rows_offset'] = int(self.tile_size['y'] * (self.i_row - self.t_num_bbox['min_row']))
if self.i_row >= self.t_num_bbox['max_row']:
@@ -587,14 +628,317 @@
else:
self.i_row += 1
- return query_url, self.tileRef
+ return query_url, self.tile_ref
+ def find(self, etreeElement, tag, ns = None):
+ """!Wraper for etree element find method.
+ if not ns:
+ res = etreeElement.find(tag)
+ else:
+ res = etreeElement.find(ns(tag))
+ if res is None:
+ grass.fatal(_("Unable to parse capabilities file. \n Tag '%s' was not found.") % tag)
+ return res
+ def findall(self, etreeElement, tag, ns = None):
+ """!Wraper for etree element findall method.
+ if not ns:
+ res = etreeElement.findall(tag)
+ else:
+ res = etreeElement.findall(ns(tag))
+ if not res:
+ return res
def _ns_wmts(self, tag):
- """!Helper method - XML namespace
+ """!Helper method - XML namespace.
return "{http://www.opengis.net/wmts/1.0}" + tag
def _ns_ows(self, tag):
return "{http://www.opengis.net/ows/1.1}" + tag
+class OnEarthRequestMgr(BaseRequestMgr):
+ def __init__(self, params, bbox, region, proj_srs, tile_service):
+ """!Initializes data needed for iteration through tiles.
+ tile_service_tree = etree.parse(tile_service)
+ root = tile_service_tree.getroot()
+ # parse tile service file and get needed data for making tile requests
+ url, self.tile_span, t_patt_bbox, self.tile_size = self._parseTileService(root, bbox, region, params)
+ self.url = url
+ self.url[0] = params['url'] + '?' + url[0]
+ # initialize data needed for iteration through tiles
+ self._computeRequestData(bbox, t_patt_bbox, self.tile_span, self.tile_size)
+ def GetMapRegion(self):
+ """!Get size in pixels and bounding box of raster where all tiles will be merged.
+ return self.map_region
+ def _parseTileService(self, root, bbox, region, params):
+ """!Get data from tile service file
+ tiled_patterns = self.find(root, 'TiledPatterns')
+ tile_groups = self._getAllTiledGroup(tiled_patterns)
+ if not tile_groups:
+ grass.fatal(_("Unable to parse tile service file. \n No tag '%s' was found.") % 'TiledGroup')
+ req_group = None
+ for group in tile_groups:
+ name = group.find('Name')
+ if name is not None and name.text == params['layers']:
+ req_group = group
+ break
+ if req_group is None:
+ grass.fatal(_("Tiled group '%s' was not found in tile service file") % params['layers'])
+ group_t_patts = self.findall(req_group, 'TilePattern')
+ best_patt = self._parseTilePattern(group_t_patts, bbox, region)
+ if best_patt is None:
+ grass.fatal("Unable to parse any url in '%s' of %s '%s'" % ('TilePattern', params['layers'], 'TiledGroup'))
+ urls = self._getUrls(best_patt)
+ if params['urlparams']:
+ url = self._insTimeToTilePatternUrl(params['urlparams'], urls)
+ else:
+ url = urls[0]
+ for u in urls:
+ if not 'time=${' in u:
+ url = u
+ url, t_bbox, width, height = self._parseUrl(url)
+ tile_span = {}
+ tile_span['x'] = abs(t_bbox[0] - t_bbox[2])
+ tile_span['y'] = abs(t_bbox[1] - t_bbox[3])
+ tile_pattern_bbox = self.find(req_group, 'LatLonBoundingBox')
+ t_patt_bbox = {}
+ for s in ['minx', 'miny', 'maxx', 'maxy']:
+ t_patt_bbox[s] = float(tile_pattern_bbox.get(s))
+ tile_size = {}
+ tile_size['x'] = width
+ tile_size['y'] = height
+ return url, tile_span, t_patt_bbox, tile_size
+ def _getAllTiledGroup(self, parent, tiled_groups = None):
+ """!Get all 'TileGroup' tags
+ if not tiled_groups:
+ tiled_groups = []
+ tiled_groups += parent.findall('TiledGroup')
+ new_groups = parent.findall('TiledGroups')
+ for group in new_groups:
+ self._getAllTiledGroup(group, tiled_groups)
+ return tiled_groups
+ def _parseTilePattern(self, group_t_patts, bbox, region):
+ """!Find best tile pattern for requested resolution.
+ res = {}
+ res['y'] = (bbox['maxy'] - bbox['miny']) / region['rows']
+ res['x'] = (bbox['maxx'] - bbox['minx']) / region['cols']
+ if res['x'] < res['y']:
+ comp_res = 'x'
+ else:
+ comp_res = 'y'
+ t_res = {}
+ best_patt = None
+ for pattern in group_t_patts:
+ urls = self._getUrls(pattern)
+ if not urls:
+ continue
+ ret = self._parseUrl(urls[0])
+ if not ret:
+ continue
+ url, t_bbox, width, height = ret
+ t_res['x'] = abs(t_bbox[0] - t_bbox[2]) / width
+ t_res['y'] = abs(t_bbox[1] - t_bbox[3]) / height
+ best_res = t_res[comp_res]
+ best_patt = pattern
+ first = False
+ continue
+ best_diff = best_res - res[comp_res]
+ tile_diff = t_res[comp_res] - res[comp_res]
+ if (best_diff < tile_diff and tile_diff < 0) or \
+ (best_diff > tile_diff and best_diff > 0):
+ return best_patt
+ def _getUrls(self, tile_pattern):
+ """!Get all urls from tile pattern.
+ urls = []
+ if tile_pattern.text is not None:
+ tile_patt_lines = tile_pattern.text.split('\n')
+ for line in tile_patt_lines:
+ if 'request=GetMap' in line:
+ urls.append(line.strip())
+ return urls
+ def _parseUrl(self, url):
+ """!Parse url string in Tile Pattern.
+ par_url = bbox = width = height = None
+ bbox_idxs = self._getParameterIdxs(url, "bbox=")
+ if bbox_idxs is None:
+ return None
+ par_url = [url[:bbox_idxs[0] - 1], url[bbox_idxs[1]:]]
+ bbox = url[bbox_idxs[0] + len('bbox=') : bbox_idxs[1]]
+ bbox = map(float, bbox.split(','))
+ width_idxs = self._getParameterIdxs(url, "width=")
+ if width_idxs is None:
+ return None
+ width = int(url[width_idxs[0] + len('width=') : width_idxs[1]])
+ height_idxs = self._getParameterIdxs(url, "height=")
+ if height_idxs is None:
+ return None
+ height = int(url[height_idxs[0] + len('height=') : height_idxs[1]])
+ return par_url, bbox, width, height
+ def _insTimeToTilePatternUrl(self, url_params, urls):
+ """!Time can be variable in some urls in OnEarth TMS.
+ Insert requested time from 'urlparams' into the variable if any url of urls contains the variable.
+ url = None
+ not_sup_params = []
+ url_params_list = url_params.split('&')
+ for param in url_params_list:
+ try:
+ k, v = param.split('=')
+ grass.warning(_("Wrong form of parameter '%s' in '%s'. \n \
+ The parameter was ignored.") % (param, 'urlparams'))
+ if k != 'time':
+ not_sup_params.append(k)
+ continue
+ has_time_var = False
+ for url in urls:
+ url_p_idxs = self._getParameterIdxs(url, k)
+ if not url_p_idxs:
+ continue
+ url_p_value = url[url_p_idxs[0] + len(k + '=') : url_p_idxs[1]]
+ if url_p_value[:2] == '${' and \
+ url_p_value[len(url_p_value) - 1] == '}':
+ url = url[:url_p_idxs[0]] + param + url[url_p_idxs[1]:]
+ has_time_var = True
+ break
+ if not has_time_var:
+ grass.warning(_("Parameter '%s' in '%s' is not variable in tile pattern url.") % (k, 'urlparams'))
+ if not_sup_params:
+ grass.warning(_("%s driver supports only '%s' parameter in '%s'. Other parameters are ignored.") % \
+ ('OnEarth GRASS', 'time', 'urlparams'))
+ return url
+ def _getParameterIdxs(self, params_str, param_key):
+ """!Find start and end index of parameter and it's value in url string
+ start_i = params_str.lower().find(param_key)
+ if start_i < 0:
+ return None
+ end_i = params_str.find("&", start_i)
+ if end_i < 0:
+ end_i = len(params_str)
+ return (start_i, end_i)
+ def _computeRequestData(self, bbox, t_patt_bbox, tile_span, tile_size):
+ epsilon = 1e-15
+ mat_num_bbox = {}
+ mat_num_bbox['min_row'] = mat_num_bbox['min_col'] = 0
+ mat_num_bbox['max_row'] = floor((t_patt_bbox['maxy'] - t_patt_bbox['miny'])/ tile_span['y'] + epsilon)
+ mat_num_bbox['max_col'] = floor((t_patt_bbox['maxx'] - t_patt_bbox['minx'])/ tile_span['x'] + epsilon)
+ BaseRequestMgr._computeRequestData(self, bbox, t_patt_bbox, self.tile_span, self.tile_size, mat_num_bbox)
+ def GetNextTile(self):
+ if self.i_col > self.t_num_bbox['max_col']:
+ return None
+ x_offset = self.tile_span['x'] * self.i_col
+ y_offset = self.tile_span['y'] * self.i_row
+ query_url = self.url[0] + "&" + "bbox=%s,%s,%s,%s" % (float(self.query_bbox['minx'] + x_offset),
+ float(self.query_bbox['miny'] - y_offset),
+ float(self.query_bbox['maxx'] + x_offset),
+ float(self.query_bbox['maxy'] - y_offset)) + self.url[1]
+ self.tile_ref['t_cols_offset'] = int(self.tile_size['y'] * (self.i_col - self.t_num_bbox['min_col']))
+ self.tile_ref['t_rows_offset'] = int(self.tile_size['x'] * (self.i_row - self.t_num_bbox['min_row']))
+ if self.i_row >= self.t_num_bbox['max_row']:
+ self.i_col += 1
+ else:
+ self.i_row += 1
+ def find(self, etreeElement, tag):
+ if res is None:
+ grass.fatal(_("Unable to parse tile service file. \n Tag '%s' was not found.") % tag)
+ return res
+ def findall(self, etreeElement, tag):
+ if not res:
+ return res
\ No newline at end of file
