[GRASS-SVN] r53549 - grass/branches/develbranch_6/gui/wxpython/gui_core
Thu Oct 25 03:04:01 PDT 2012
Author: martinl
Date: 2012-10-25 03:04:01 -0700 (Thu, 25 Oct 2012)
New Revision: 53549
   grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py
wxGUI: improve search module widget (Ctrl+Enter to run selected command)
       (merge r53548 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py	2012-10-25 10:01:10 UTC (rev 53548)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py	2012-10-25 10:04:01 UTC (rev 53549)
@@ -56,7 +56,7 @@
                              _('keywords')    : 'keywords' }
         self.box = wx.StaticBox(parent = self, id = wx.ID_ANY,
-                                label = " %s " % _("Find module(s)"))
+                                label = " %s " % _("Find module - (press Enter for next match)"))
         self.searchBy = wx.Choice(parent = self, id = wx.ID_ANY,
                                   choices = [_('description'),
@@ -64,10 +64,10 @@
                                              _('command')])
         self.searchBy.SetSelection(0)
-        self.search = wx.TextCtrl(parent = self, id = wx.ID_ANY,
-                                  value = "", size = (-1, 25),
-                                  style = wx.TE_PROCESS_ENTER)
-        self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
+        self.search = wx.SearchCtrl(parent = self, id = wx.ID_ANY,
+                                    size = (-1, 25), style = wx.TE_PROCESS_ENTER)
+        if self.cmdPrompt:
+            self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
         if self.showTip:
             self.searchTip = StaticWrapText(parent = self, id = wx.ID_ANY,
@@ -106,6 +106,10 @@
         self.SetSizer(sizer)
         sizer.Fit(self)
+    def GetCtrl(self):
+        """!Get SearchCtrl widget"""
+        return self.search
     def GetSelection(self):
         """!Get selected element"""
         selection = self.searchBy.GetStringSelection()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py	2012-10-25 10:01:10 UTC (rev 53548)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py	2012-10-25 10:04:01 UTC (rev 53549)
@@ -132,7 +132,7 @@
         wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
         self.dataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
-                                    label = " %s " % _("Menu tree (double-click to run command)"))
+                                    label = " %s " % _("Menu tree (double-click or Ctrl-Enter to run command)"))
         # tree
         self.tree = MenuTree(parent = self, data = ManagerData())
         self.tree.Load()
@@ -142,15 +142,16 @@
         # buttons
         self.btnRun   = wx.Button(self, id = wx.ID_OK, label = _("&Run"))
-        self.btnRun.SetToolTipString(_("Run selected command"))
+        self.btnRun.SetToolTipString(_("Run selected command from the menu tree"))
         self.btnRun.Enable(False)
         # bindings
         self.btnRun.Bind(wx.EVT_BUTTON,            self.OnRun)
         self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
         self.tree.Bind(wx.EVT_TREE_SEL_CHANGED,    self.OnItemSelected)
-        self.search.Bind(wx.EVT_TEXT_ENTER,        self.OnShowItem)
-        self.search.Bind(wx.EVT_TEXT,              self.OnUpdateStatusBar)
+#        self.search.GetCtrl().Bind(wx.EVT_TEXT_ENTER,  self.OnShowItem)
+        self.search.GetCtrl().Bind(wx.EVT_TEXT,        self.OnUpdateStatusBar)
+        self.search.GetCtrl().Bind(wx.EVT_KEY_UP,      self.OnKeyUp)
         self._layout()
@@ -211,6 +212,13 @@
         else:
             eval(handler)(None)
+    def OnKeyUp(self, event):
+        if event.GetKeyCode() == wx.WXK_RETURN:
+            if event.ControlDown():
+                self.OnRun(event)
+            else:
+                self.OnShowItem(event)
     def OnShowItem(self, event):
         """!Show selected item"""
         self.tree.OnShowItem(event)
@@ -253,11 +261,11 @@
     def OnUpdateStatusBar(self, event):
         """!Update statusbar text"""
         element = self.search.GetSelection()
-        self.tree.SearchItems(element = element,
-                              value = event.GetString())
+        value = event.GetEventObject().GetValue()
+        self.tree.SearchItems(element = element, value = value)
         nItems = len(self.tree.itemsMarked)
-        if event.GetString():
+        if value:
             self.parent.SetStatusText(_("%d modules match") % nItems, 0)
         else:
             self.parent.SetStatusText("", 0)
