[GRASS-SVN] r53551 - grass/trunk/lib/python/pygrass/modules
svn_grass at osgeo.org
Thu Oct 25 07:41:10 PDT 2012
Author: zarch
Date: 2012-10-25 07:41:09 -0700 (Thu, 25 Oct 2012)
New Revision: 53551
grass/trunk/lib/python/pygrass/modules/__init__.py
Change value type check and add __str__ method to the Module class
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py 2012-10-25 11:56:43 UTC (rev 53550)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py 2012-10-25 14:41:09 UTC (rev 53551)
@@ -44,9 +44,9 @@
_GETTYPE = {
'string': str,
- 'integer': np.int32,
- 'float': np.float32,
- 'double': np.float64,
+ 'integer': int,
+ 'float': float,
+ 'double': float,
@@ -177,8 +177,8 @@
else:
self._value = value
else:
- raise TypeError('The Parameter <%s>, require: %s' %
- (self.name, self.typedesc))
+ str_err = 'The Parameter <%s>, require: %s, get: %s instead'
+ raise TypeError(str_err % (self.name, self.typedesc, type(value)))
# here the property function is used to transform value in an attribute
# in this case we define which function must be use to get/set the value
@@ -463,6 +463,9 @@
if self.run_:
self.run()
+ def __str__(self):
+ return ' '.join(self.make_cmd())
@property
def __doc__(self):
"""{cmd_name}({cmd_params})
