[GRASS-SVN] r53553 - grass/branches/develbranch_6/vector/v.transform
Thu Oct 25 08:22:24 PDT 2012
Author: mmetz
Date: 2012-10-25 08:22:23 -0700 (Thu, 25 Oct 2012)
New Revision: 53553
   grass/branches/develbranch_6/vector/v.transform/main.c
   grass/branches/develbranch_6/vector/v.transform/trans_digit.c
v.transform: fix memory issues
Modified: grass/branches/develbranch_6/vector/v.transform/main.c
--- grass/branches/develbranch_6/vector/v.transform/main.c	2012-10-25 15:21:43 UTC (rev 53552)
+++ grass/branches/develbranch_6/vector/v.transform/main.c	2012-10-25 15:22:23 UTC (rev 53553)
@@ -54,6 +54,7 @@
     char *mapset, mon[4], date[40], buf[1000];
     struct Map_info Old, New;
+    int ifield;
     int day, yr;
     BOUND_BOX box;
@@ -74,6 +75,7 @@
 	_("Performs an affine transformation (shift, scale and rotate, "
 	  "or GPCs) on vector map.");
+    /* remove in GRASS7 */
     quiet_flag = G_define_flag();
     quiet_flag->key = 'q';
     quiet_flag->description =
@@ -95,7 +97,6 @@
     print_mat_flag->description =
 	_("Print the transformation matrix to stdout");
-    /* remove in GRASS7 */
     shift_flag = G_define_flag();
     shift_flag->key = 's';
     shift_flag->description =
@@ -106,6 +107,7 @@
     vold = G_define_standard_option(G_OPT_V_INPUT);
     field = G_define_standard_option(G_OPT_V_FIELD);
+    field->answer = "-1";
     vnew = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -208,29 +210,42 @@
     Vect_check_input_output_name(vold->answer, vnew->answer, GV_FATAL_EXIT);
     out3d = WITHOUT_Z;
+    ifield = atoi(field->answer);
-    /* please remove in GRASS7 */
     if (shift_flag->answer)
 	G_warning(_("The '%c' flag is deprecated and will be removed in future. "
 		   "Transformation parameters are used automatically when no pointsfile is given."),
 		  shift_flag->key);
+    /* please remove in GRASS7 */
     if (quiet_flag->answer) {
 		   "Please use '--quiet' instead."), quiet_flag->key);
 	G_putenv("GRASS_VERBOSE", "0");
-    if (!table->answer && columns->answer) {
-	G_fatal_error(_("Table name is not defined. Please use '%s' parameter."),
-		      table->key);
+    /* if a table is specified, require columns and layer */
+    /* if columns are specified, but no table, require layer > 0 and use
+     * the table attached to that layer */
+    if (table->answer && !columns->answer) {
+	G_fatal_error(_("Column names are not defined. Please use '%s' parameter."),
+		      columns->key);
+    if ((columns->answer || table->answer) && ifield < 1) {
+	G_fatal_error(_("Please specify a valid layer with '%s' parameter."),
+		      field->key);
     if (table->answer && strcmp(vnew->answer, table->answer) == 0) {
 	G_fatal_error(_("Name of table and name for output vector map must be different. "
 		       "Otherwise the table is overwritten."));
+    if (!columns->answer && !table->answer)
+	ifield = -1;
     if (pointsfile->answer != NULL && !shift_flag->answer) {
 	G_strcpy(Coord.name, pointsfile->answer);
@@ -346,7 +361,7 @@
     /* do the transformation */
     transform_digit_file(&Old, &New, Coord.name[0] ? 1 : 0,
 			 ztozero, swap_flag->answer, trans_params,
-			 table->answer, columns_name, atoi(field->answer));
+			 table->answer, columns_name, ifield);
     if (Vect_copy_tables(&Old, &New, 0))
         G_warning(_("Failed to copy attribute table to output map"));
Modified: grass/branches/develbranch_6/vector/v.transform/trans_digit.c
--- grass/branches/develbranch_6/vector/v.transform/trans_digit.c	2012-10-25 15:21:43 UTC (rev 53552)
+++ grass/branches/develbranch_6/vector/v.transform/trans_digit.c	2012-10-25 15:22:23 UTC (rev 53553)
@@ -50,19 +50,27 @@
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    if (table) {
-	fi = Vect_default_field_info(Old, 1, NULL, GV_1TABLE);
+    if (table || field > 0) {
+	if (table) {
+	    fi = Vect_default_field_info(Old, 1, NULL, GV_1TABLE);
+	    fi->table = table;
+	else
+	    fi = Vect_get_field(Old, field);
 	driver = db_start_driver_open_database(fi->driver, fi->database);
 	if (!driver)
 	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  fi->database, fi->driver);
-	trans_params = (double *)G_calloc(IDX_ZROT, sizeof(double));
+	trans_params = (double *)G_calloc(IDX_ZROT + 1, sizeof(double));
     else {
 	trans_params = trans_params_def;
 	ang = PI * trans_params[IDX_ZROT] / 180;
+	fi = NULL;
+	driver = NULL;
     ret = 1;
@@ -88,7 +96,7 @@
 	/* get transformation parameters */
-	if (table) {
+	if (field > 0) {
 	    Vect_cat_get(Cats, field, &cat);	/* get first category */
 	    if (cat > -1) {
 		for (j = 0; j <= IDX_ZROT; j++) {
@@ -96,7 +104,7 @@
 			trans_params[j] = trans_params_def[j];
 			continue;
-		    ctype = db_column_Ctype(driver, table, columns[j]);
+		    ctype = db_column_Ctype(driver, fi->table, columns[j]);
 		    switch (ctype) {
 		    case DB_C_TYPE_INT:
 		    case DB_C_TYPE_DOUBLE:
@@ -104,19 +112,19 @@
 			break;
 		    case -1:
 			G_fatal_error(_("Missing column <%s> in table <%s>"),
-				      columns[j], table);
+				      columns[j], fi->table);
 		    default:
 			G_fatal_error(_("Unsupported column type of <%s>"),
 				      columns[j]);
 		    if (db_select_value
-			(driver, table, fi->key, cat, columns[j], &val) != 1
+			(driver, fi->table, fi->key, cat, columns[j], &val) != 1
 			|| db_test_value_isnull(&val)) {
 			G_warning(_("Unable to select value for category %d from table <%s>, column <%s>. "
 				   "For category %d using default transformation parameter %.3f."),
-				  cat, table, columns[j], cat,
+				  cat, fi->table, columns[j], cat,
 				  trans_params[j]);
 		    else {
