[GRASS-SVN] r53581 - grass-web/trunk/grass64/binary/mswindows/cygwin
    svn_grass at osgeo.org
    Sun Oct 28 01:28:47 PDT 2012
Author: neteler
Date: 2012-10-28 01:28:47 -0700 (Sun, 28 Oct 2012)
New Revision: 53581
   grass-web/trunk/grass64/binary/mswindows/cygwin/README.html
mention missing setup.ini.sig + workaround
Modified: grass-web/trunk/grass64/binary/mswindows/cygwin/README.html
--- grass-web/trunk/grass64/binary/mswindows/cygwin/README.html	2012-10-27 10:08:41 UTC (rev 53580)
+++ grass-web/trunk/grass64/binary/mswindows/cygwin/README.html	2012-10-28 08:28:47 UTC (rev 53581)
@@ -57,7 +57,8 @@
 Part 2: GRASS GIS installation:
 <ol>
 <li> Create a shortcut to the previously saved Cygwin "setup.exe" (see above)
-<li> Edit the shortcut <i>Properties</i> (in right-mouse-button menu) and add " -X"
+<li> Since we cannot offer a signature file (setup.ini.sig), you need to add a workaround:<br>
+     Edit the shortcut <i>Properties</i> (in right-mouse-button menu) and add " -X"
      (without quotes) as parameter to "setup.exe". The -X permits to run an own setup.ini based installation.<br>
      Example:<br>
      Change <tt>"C:\Documents and Settings\user\Documenti\Download\setup.exe"</tt><br>
