[GRASS-SVN] r53592 - grass/trunk/imagery/i.landsat.toar
svn_grass at osgeo.org
Sun Oct 28 03:20:44 PDT 2012
Author: neteler
Date: 2012-10-28 03:20:43 -0700 (Sun, 28 Oct 2012)
New Revision: 53592
grass/trunk/imagery/i.landsat.toar/landsat.h
grass/trunk/imagery/i.landsat.toar/landsat_set.c
grass/trunk/imagery/i.landsat.toar/main.c
Jorge Tizado: better management of metadata file
Modified: grass/trunk/imagery/i.landsat.toar/landsat.h
--- grass/trunk/imagery/i.landsat.toar/landsat.h 2012-10-28 10:19:12 UTC (rev 53591)
+++ grass/trunk/imagery/i.landsat.toar/landsat.h 2012-10-28 10:20:43 UTC (rev 53592)
@@ -3,6 +3,7 @@
#define UNCORRECTED 0
#define CORRECTED 1
#define DOS 10
#define DOS1 12
#define DOS2 14
@@ -10,6 +11,8 @@
#define DOS3 16
#define DOS4 18
+#define NOMETADATAFILE 0
+#define METADATAFILE 1
* Landsat Structures
@@ -40,6 +43,7 @@
typedef struct
+ int flag;
unsigned char number; /* Landsat number */
char creation[11]; /* Image production date */
Modified: grass/trunk/imagery/i.landsat.toar/landsat_set.c
--- grass/trunk/imagery/i.landsat.toar/landsat_set.c 2012-10-28 10:19:12 UTC (rev 53591)
+++ grass/trunk/imagery/i.landsat.toar/landsat_set.c 2012-10-28 10:20:43 UTC (rev 53592)
@@ -421,10 +421,9 @@
jbuf = julian_char("2004-04-04");
- if (julian >= jbuf) {
- G_warning
- ("Using QCalMin=1.0 as a NLAPS product processed after 4/4/2004");
- G_warning("Ignore this message when using the metfile option");
+ if (julian >= jbuf && !(lsat->flag & METADATAFILE) )
+ G_warning("Using QCalMin=1.0 as a NLAPS product processed after 04/04/2004");
lsat->number = 5;
sensor_TM(lsat);
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2012-10-28 10:19:12 UTC (rev 53591)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2012-10-28 10:20:43 UTC (rev 53592)
@@ -11,7 +11,7 @@
* PURPOSE: Calculate TOA Radiance or Reflectance and Kinetic Temperature
* for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
- * COPYRIGHT: (C) 2002-2012 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2012 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -39,9 +39,9 @@
int infd, outfd;
void *ptr;
int nrows, ncols, row, col;
RASTER_MAP_TYPE in_data_type;
struct Option *input_prefix, *output_prefix, *metfn, *sensor, *adate, *pdate, *elev,
*bgain, *metho, *perc, *dark, *atmo;
char *inputname, *met, *outputname, *sensorname;
@@ -57,7 +57,7 @@
struct FPRange range;
double min, max;
unsigned long hist[256], h_max;
/* initialize GIS environment */
G_gisinit(argv[0]);
@@ -101,7 +101,7 @@
sensor->options = "mss1,mss2,mss3,mss4,mss5,tm4,tm5,tm7";
desc = NULL;
G_asprintf(&desc,
- "mss1;%s;mss2;%s;mss3;%s;mss4;%smss5;%stm4;%s;tm5;%s;tm7;%s",
+ "mss1;%s;mss2;%s;mss3;%s;mss4;%s;mss5;%s;tm4;%s;tm5;%s;tm7;%s",
_("Landsat-1 MSS"),
_("Landsat-2 MSS"),
_("Landsat-3 MSS"),
@@ -213,8 +213,10 @@
G_fatal_error(_("Illegal date format: [%s] (yyyy-mm-dd)"),
lsat.date);
+ /* Unnecessary because G_zero filled
else
lsat.date[0] = '\0';
if (pdate->answer != NULL) {
strncpy(lsat.creation, pdate->answer, 11);
@@ -223,17 +225,23 @@
lsat.creation);
else
lsat.creation[0] = '\0';
lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
percent = atof(perc->answer);
pixel = atoi(dark->answer);
rayleigh = atof(atmo->answer);
+ lsat.flag = NOMETADATAFILE;
/* Data from metadata file */
if (met != NULL)
+ lsat.flag = METADATAFILE;
i = strlen(met);
if (strcmp(met + i - 7, "MTL.txt") == 0)
@@ -242,7 +250,7 @@
else if (strcmp(met + i - 4, ".met") == 0)
if (strcmp(sensorname, "tm7") == 0)
- lsat_mtldata(met, &lsat); /* .met of Landsat-7 = new MTL file */
+ lsat_mtldata(met, &lsat); /* old .met of Landsat-7 = new MTL file */
else
lsat_metdata(met, &lsat);
@@ -536,7 +544,7 @@
Rast_put_row(outfd, outrast, DCELL_TYPE);
G_percent(1, 1, 1);
ref_mode = 0.;
if (method > DOS && !lsat.band[i].thermal) {
ref_mode = lsat_qcal2rad(dn_mode[i], &lsat.band[i]);
