[GRASS-SVN] r53609 - grass/trunk/scripts/v.db.reconnect.all
Mon Oct 29 10:33:42 PDT 2012
Author: martinl
Date: 2012-10-29 10:33:41 -0700 (Mon, 29 Oct 2012)
New Revision: 53609
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
v.db.reconnect.all: major update
		    flag for creating tables in target database if not exist
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html	2012-10-29 15:22:43 UTC (rev 53608)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html	2012-10-29 17:33:41 UTC (rev 53609)
@@ -1,17 +1,94 @@
 <h2>DESCRIPTION</h2>
+<em>v.db.reconnect.all</em> changes database connection of all layers
+of all vector maps in the current mapset from the source
+(<b>old_database</b>) to the target (<b>new_database</b>) database. If
+a link does not match the <b>old_database</b> it is left untouched.
-<em>v.db.reconnect.all</em> changes database connection of all layers of
-all vectors in the current mapset from old_database to database. If a link
-does not match the old_database it is left untouched.
+<p>
+Optionally attribute tables in <b>new_database</b> can be created if
+not exist by <b>-c</b> flag.
 <h2>NOTES</h2>
-The value of the <em>old_database</em> option needs to be the exact
+The value of the <b>old_database</b> option needs to be the exact
 string which appears as the fourth field printed by
-<tt>v.db.connect -g</tt>, i.e. with substituted variables.
+<tt>v.db.connect -g</tt>.
+<div class="code"><pre>
+v.db.connect -g map=census
+1/census|census|cat|/home/user/grassdata/nc_spm_base/PERMANENT/dbf/|dbf
+</pre></div>
-<h2>AUTHOR</h2>
-Radim Blazek
+<em>v.db.reconnect.all</em> respect also variables to be
+substituted. In the example above,
+database <tt>/home/user/grassdata/nc_spm_base/PERMANENT/dbf/</tt> can
+be also defined as <tt>'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'</tt>
+(see examples).
+<p>
+Attribute tables from <b>old_database</b> are after reconnecting left
+untouched. <em>v.db.reconnect.all</em> deletes those tables
+automatically only when <b>-d</b> flag is given.
-<p><i>Last changed: $Date$</i>
+<p>
+Also note that <em>v.db.reconnect.all</em> doesn't change default
+database driver or database (<tt>db.connect -p</tt>). Default database
+connection settings for newly created attribute data can be defined
+by <em><a href="db.connect.html">db.connect</a></em>.
+<h2>EXAMPLES</h2>
+In the examples below are assumed, that attribute tables are linked to
+the vector maps through <a href="grass-dbf.html">DBF</a> database
+driver.
+<h3>Reconnect DBF attribute tables to SQLite database</h3>
+Reconnect <a href="grass-dbf.html">DBF</a> attribute tables linked to
+the vector maps in the current mapset
+to <a href="grass-sqlite.html">SQLite</a> database:
+v.db.reconnect.all old_database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' \
+ new_driver=sqlite new_database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+</pre></div>
+If attribute table doesn't exist in the target database
+(<b>new_database</b>) then the module prints an error message.
+<h3>Convert DBF attribute tables to SQLite database</h3>
+For coping DBF tables to SQLite database and reconnecting them for all
+vector maps in the current mapset must be defined also <b>-c</b> flag.
+v.db.reconnect.all -c old_database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' \
+</pre></div>
+To automatically remove original DBF attribute tables after
+reconnecting the vector maps use <b>-d</b> flag. Note that attribute
+tables will be deleted <i>permanently</i> from the source
+database. This option should be used very carefully!
+<h2>SEE ALSO</h2>
+<em>
+  <a href="v.db.connect.html">v.db.connect</a>,
+  <a href="db.connect.html">db.connect</a>,
+  <a href="db.copy.html">db.copy</a>,
+  <a href="db.createdb.html">db.createdb</a>,
+  <a href="db.droptable.html">db.droptable</a>
+</em>
+<p>
+<a href="sql.html">GRASS SQL interface</a>
+<h2>AUTHORS</h2>
+Radim Blazek<br>
+Major update by Martin Landa, Czech Technical University in Prague, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2012-10-29 15:22:43 UTC (rev 53608)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2012-10-29 17:33:41 UTC (rev 53609)
@@ -1,91 +1,181 @@
 #!/usr/bin/env python
-# MODULE:	v.db.reconnect.all
-# AUTHOR(S):	Radim Blazek
+# MODULE:       v.db.reconnect.all
+# AUTHOR(S):    Radim Blazek
 #               Converted to Python by Glynn Clements
-# PURPOSE:	Reconnect vectors
-# COPYRIGHT:	(C) 2004 by the GRASS Development Team
+#               Update for GRASS 7 by Martin Landa <landa.martin gmail.com>
+# PURPOSE:      Reconnect all vector maps from the current mapset
+# COPYRIGHT:    (C) 2004, 2012 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
+#               This program is free software under the GNU General
+#               Public License (>=v2). Read the file COPYING that
+#               comes with GRASS for details.
 #%module
-#% description: Reconnects vectors to a new database.
+#% description: Reconnects attribute tables for all vector maps from the current mapset to a new database.
 #% keywords: vector
 #% keywords: attribute table
 #% keywords: database
 #%end
+#%flag
+#% key: c
+#% description: Copy attribute tables to the target database if not exist
+#%end
+#%flag
+#% key: d
+#% description: Delete attribute tables from the source database
+#%end
 #%option G_OPT_DB_DATABASE
 #% key: old_database
-#% description: Name of old database
+#% description: Name of source database
 #% required: yes
 #%end
+#%option G_OPT_DB_SCHEMA
+#% key: old_schema
+#% label: Name of source database schema
+#%end
+#%option
+#% key: new_driver
+#% description: Name for target driver
+#%end
 #% key: new_database
-#% description: Name of new database
+#% description: Name for target database
 #% required: yes
 #%end
-#% key: old_schema
-#% description: Old database schema
-#%end
-#%option G_OPT_DB_SCHEMA
 #% key: new_schema
-#% description: New database schema
+#% label: Name for target database schema
 #%end
 import sys
 import os
+import string
 import grass.script as grass
+# substitute variables (gisdbase, location_name, mapset)
+def substitute_db(database):
+    gisenv = grass.gisenv()
+    tmpl = string.Template(database)
+    return tmpl.substitute(GISDBASE = gisenv['GISDBASE'],
+                           LOCATION_NAME = gisenv['LOCATION_NAME'],
+                           MAPSET = gisenv['MAPSET'])
+# create database if doesn't exist
+def create_db(driver, database):
+    if database in grass.read_command('db.databases', quiet = True,
+                                      driver = driver).splitlines():
+        return False
+    grass.info(_("Target database doesn't exist, "
+                 "creating a new database using <%s> driver...") % driver)
+    if 0 != grass.run_command('db.createdb', driver = driver,
+                              database = database):
+        grass.fatal(_("Unable to create database <%s> by driver <%s>") % \
+                        (database, driver))
+    return False
+# copy tables if required (-c)
+def copy_tab(from_driver, from_database, from_table,
+             to_driver, to_database, to_table):
+    if to_table in grass.read_command('db.tables', quiet = True,
+                                      driver = to_driver,
+                                      database = to_database,
+                                      stderr = nuldev).splitlines():
+        return False
+    grass.info("Table <%s> in target database doesn't exist, "
+               "copying data..." % to_table)
+    if 0 != grass.run_command('db.copy', from_driver = from_driver,
+                              from_database = from_database,
+                              from_table = from_table, to_driver = to_driver,
+                              to_database = to_database,
+                              to_table = to_table):
+        grass.fatal(_("Unable to copy table <%s>") % from_table)
+    return True
+# drop tables if required (-d)
+def drop_tab(driver, database, table):
+    if 0 != grass.run_command('db.droptable', quiet = True, flags = 'f',
+                              driver = driver, database = database,
+                              table = table, stderr = nuldev):
+        grass.fatal(_("Unable to drop table <%s>") % table)
 def main():
-    old_database = options['old_database']
-    new_database = options['new_database']
+    old_database = substitute_db(options['old_database'])
+    if options['new_driver']:
+        new_driver = options['new_driver']
+    else:
+        new_driver = grass.parse_command('db.connect', flags = 'g')['driver']
+    new_database = substitute_db(options['new_database'])
     old_schema = options['old_schema']
     new_schema = options['new_schema']
     mapset = grass.gisenv()['MAPSET']
-    nuldev = file(os.devnull, 'w')
     for vect in grass.list_grouped('vect')[mapset]:
-	vect = "%s@%s" % (vect, mapset)
-	grass.message(_("Reconnecting vector <%s>") % vect)
-	for f in grass.vector_db(map, stderr = nuldev).itervalues():
-	    layer = f['layer']
-	    schema_table = f['table']
-	    key = f['key']
-	    database = f['database']
-	    driver = f['driver']
-	    if '.' in schema_table:
-		st = schema_table.split('.', 1)
-		schema = st[0]
-		table = st[1]
-	    else:
-		schema = ''
-		table = schema_table
+        vect = "%s@%s" % (vect, mapset)
+        grass.message('-' * 60)
+        grass.message(_("Reconnecting vector map <%s>...") % vect)
+        for f in grass.vector_db(vect, stderr = nuldev).itervalues():
+            layer = f['layer']
+            schema_table = f['table']
+            key = f['key']
+            database = f['database']
+            driver = f['driver']
+            # split schema.table
+            if '.' in schema_table:
+                schema, table = schema_table.split('.', 1)
+            else:
+                schema = ''
+                table = schema_table
+            if new_schema:
+                new_schema_table = "%s.%s" % (new_schema, table)
+            else:
+                new_schema_table = table
+            grass.debug("DATABASE = '%s' SCHEMA = '%s' TABLE = '%s' ->\n"
+                        "      NEW_DATABASE = '%s' NEW_SCHEMA_TABLE = '%s'" % \
+                            (old_database, schema, table, new_database, new_schema_table))
+            if database == old_database and schema == old_schema:
+                grass.verbose(_("Reconnecting layer %d...") % layer)
+                if flags['c']:
+                    # check if database exists
+                    create_db(new_driver, new_database)
+                    # check if table exists in new database
+                    copy_tab(driver, database, schema_table,
+                             new_driver, new_database, new_schema_table)
+                # reconnect tables
+                if 0 != grass.run_command('v.db.connect', flags = 'o', quiet = True, map = vect,
+                                          layer = layer, driver = new_driver, database = new_database,
+                                          table = new_schema_table, key = key):
+                    grass.warning(_("Operation canceled"))
+                # drop original table if required
+                if flags['d']:
+                    drop_tab(driver, database, schema_table)
-	    if new_schema:
-		new_schema_table = "%s.%s" % (new_schema, table)
-	    else:
-		new_schema_table = table
+            else:
+                grass.warning(_("Layer <%d> will not be reconnected, "
+                                "database or schema do not match.") % layer)
+    return 0
-	    grass.message(_("SCHEMA = %s TABLE = %s NEW_SCHEMA_TABLE = %s") % (schema, table, new_schema_table))
-	    if database == old_database and schema == old_schema:
-		grass.message(_("Reconnecting layer ") + layer)
-		grass.message(_("v.db.connect -o map=%s layer=%s driver=%s database=%s table=%s key=%s") %
-			      (vect, layer, driver, new_database, new_schema_table, key))
-		grass.run_command('v.db.connect', flags = 'o', map = vect,
-				  layer = layer, driver = driver, database = new_database,
-				  table = new_schema_table, key = key)
-	    else:
-		grass.message(_("Layer <%s> will not be reconnected, database or schema do not match.") % layer)
 if __name__ == "__main__":
     options, flags = grass.parser()
-    main()
+    nuldev = file(os.devnull, 'w')
+    sys.exit(main())
