[GRASS-SVN] r53616 - grass-addons/tools/wingrass-packager
svn_grass at osgeo.org
Tue Oct 30 04:33:36 PDT 2012
Author: martinl
Date: 2012-10-30 04:33:35 -0700 (Tue, 30 Oct 2012)
New Revision: 53616
grass-addons/tools/wingrass-packager/grass_addons.sh
grass-addons/tools/wingrass-packager/grass_compile.sh
grass-addons/tools/wingrass-packager/grass_packager.bat
grass-addons/tools/wingrass-packager/grass_svn_info.sh
wingrass script: support osgeo4w dir postfix
Modified: grass-addons/tools/wingrass-packager/grass_addons.sh
--- grass-addons/tools/wingrass-packager/grass_addons.sh 2012-10-30 11:18:46 UTC (rev 53615)
+++ grass-addons/tools/wingrass-packager/grass_addons.sh 2012-10-30 11:33:35 UTC (rev 53616)
@@ -5,6 +5,8 @@
GISBASE_PREFIX=/c/osgeo4w/usr/src
ADDON_PREFIX=/c/Users/landa/grass_packager
+PATH_ORIG=`echo $PATH`
cd $SVN_PATH
svn up || (svn cleanup && svn up)
@@ -22,8 +24,8 @@
function compile {
- path=`echo $PATH`
- export PATH=$PATH:/c/OSGeo4W/apps/msys/bin:$2/dist.i686-pc-mingw32/bin:$2/dist.i686-pc-mingw32/scripts
+ export PATH=$PATH:/c/OSGeo4W$4/apps/msys/bin:/c/OSGeo4W$4/bin:$2/dist.i686-pc-mingw32/bin:$2/dist.i686-pc-mingw32/scripts
+ export PYTHONHOME=/c/OSGeo4W$4/apps/Python27
rm -rf $3
$SVN_PATH/tools/addons/compile.sh $1 $2 $3 1
cd $3
@@ -45,18 +47,16 @@
cd ..
md5sum $mod.zip > ${mod}.md5sum
done
- export PATH=$path
+ export PATH=$PATH_ORIG
-export PATH=/c/OSGeo4W/apps/msys/bin:/c/OSGeo4W/bin:$PATH
-export PYTHONHOME=/c/OSGeo4W/apps/Python27
export LANGUAGE=C
if test -z $1 ; then
# dev packages
compile $SVN_PATH/grass6 $GISBASE_PREFIX/grass64_release $ADDON_PREFIX/grass64/addons
compile $SVN_PATH/grass6 $GISBASE_PREFIX/grass6_devel $ADDON_PREFIX/grass65/addons
- compile $SVN_PATH/grass7 $GISBASE_PREFIX/grass_trunk $ADDON_PREFIX/grass70/addons
+ compile $SVN_PATH/grass7 $GISBASE_PREFIX/grass_trunk $ADDON_PREFIX/grass70/addons _g7
else
compile $SVN_PATH/grass6 $GISBASE_PREFIX/grass$1 $ADDON_PREFIX/grass$1/addons
fi
Modified: grass-addons/tools/wingrass-packager/grass_compile.sh
--- grass-addons/tools/wingrass-packager/grass_compile.sh 2012-10-30 11:18:46 UTC (rev 53615)
+++ grass-addons/tools/wingrass-packager/grass_compile.sh 2012-10-30 11:33:35 UTC (rev 53616)
@@ -1,20 +1,23 @@
#!/bin/sh
# Compile GRASS 6.4, 6.5 and 7.0 (update source code from SVN repository)
-SRC=/osgeo4w/usr/src
+SRC=/usr/src
PACKAGEDIR=mswindows/osgeo4w/package
function rm_package_7 {
- for f in `/c/OSGeo4W/apps/msys/bin/find $PACKAGEDIR/grass*.tar.bz2 -mtime +7 2>/dev/null`; do
+ for f in `/c/osgeo4w$1/apps/msys/bin/find $PACKAGEDIR/grass*.tar.bz2 -mtime +7 2>/dev/null`; do
rm -rfv $f
done
function compile {
- cd $SRC/$1
+ export PATH=$PATH_ORIG:/c/osgeo4w$3/apps/msys/bin
+ cd /c/osgeo4w$3/$SRC/$1
- rm_package_7
+ rm_package_7 $3
curr=`ls -t $PACKAGEDIR/ 2>/dev/null | head -n1 | cut -d'-' -f5 | cut -d'.' -f1`
if [ $? -eq 0 ]; then
num=$(($curr+1))
@@ -26,18 +29,18 @@
echo "Compiling $1 ($package)..."
rm -f mswindows/osgeo4w/configure-stamp
- ./mswindows/osgeo4w/package.sh $package $2
+ ./mswindows/osgeo4w/package.sh $package $2 $3
-export PATH=$PATH:/c/OSGeo4W/apps/msys/bin
# dev packages
compile grass64_release 64-dev
- compile grass6_devel 65-dev
- compile grass_trunk 70-dev
+ compile grass6_devel 65-dev
+ compile grass_trunk 70-dev _g7
else
- compile grass$1 $1
+ compile grass$1 $1
fi
exit 0
Modified: grass-addons/tools/wingrass-packager/grass_packager.bat
--- grass-addons/tools/wingrass-packager/grass_packager.bat 2012-10-30 11:18:46 UTC (rev 53615)
+++ grass-addons/tools/wingrass-packager/grass_packager.bat 2012-10-30 11:33:35 UTC (rev 53616)
@@ -5,7 +5,7 @@
rem Compile GRASS versions
rmdir /s /q C:\OSGeo4W\apps\grass\grass-6.4.3svn
rmdir /s /q C:\OSGeo4W\apps\grass\grass-6.5.svn
-rmdir /s /q C:\OSGeo4W\apps\grass\grass-7.0.svn
+rmdir /s /q C:\OSGeo4W_g7\apps\grass\grass-7.0.svn
rem native & osgeo4w
C:\OSGeo4W\apps\msys\bin\bash.exe C:\Users\landa\grass_packager\grass_compile.sh
@@ -15,7 +15,7 @@
if exist .\grass65 rmdir /S/Q .\grass65
xcopy C:\OSGeo4W\usr\src\grass6_devel\mswindows\* .\grass65 /S/V/F/I
if exist .\grass70 rmdir /S/Q .\grass70
-xcopy C:\OSGeo4W\usr\src\grass_trunk\mswindows\* .\grass70 /S/V/F/I
+xcopy C:\OSGeo4W_g7\usr\src\grass_trunk\mswindows\* .\grass70 /S/V/F/I
cd .\grass64
call .\GRASS-Packager.bat
@@ -31,7 +31,9 @@
C:\OSGeo4W\apps\msys\bin\sh.exe .\grass_svn_info.sh
C:\DevTools\makensis.exe .\grass64\GRASS-Installer.nsi
C:\DevTools\makensis.exe .\grass65\GRASS-Installer.nsi
C:\DevTools\makensis.exe .\grass70\GRASS-Installer.nsi
C:\OSGeo4W\apps\msys\bin\sh.exe .\grass_md5sum.sh
Modified: grass-addons/tools/wingrass-packager/grass_svn_info.sh
--- grass-addons/tools/wingrass-packager/grass_svn_info.sh 2012-10-30 11:18:46 UTC (rev 53615)
+++ grass-addons/tools/wingrass-packager/grass_svn_info.sh 2012-10-30 11:33:35 UTC (rev 53616)
@@ -1,20 +1,25 @@
#!/bin/sh
# Update SVN version info
+SRC=/usr/src
HOME=/c/Users/landa/grass_packager
function update {
- cd $SRC/$1
+ if [ "$1" = "grass_trunk" ] ; then
+ cd /c/osgeo4w_g7/$SRC/$1
+ else
+ cd /c/osgeo4w/$SRC/$1
+ fi
REV=`svn info | grep 'Last Changed Rev:' | cut -d':' -f2 | tr -d ' '`
- if test -z $3 ; then
+ if test -z $4 ; then
NUM=`ls -t $PACKAGEDIR/ 2>/dev/null | head -n1 | cut -d'-' -f5 | cut -d'.' -f1`
if [ "x$NUM" = "x" ]; then
NUM=1
fi
else
- NUM=$3
+ NUM=$4
fi
exec 3<include/VERSION
@@ -49,10 +54,10 @@
# dev packages
update grass64_release grass64
- update grass6_devel grass65
- update grass_trunk grass70
+ update grass6_devel grass65
+ update grass_trunk grass70
else
- update grass$1 grass$1 $2
+ update grass$1 grass$1 $2
fi
exit 0
