[GRASS-SVN] r53619 - grass/branches/develbranch_6/gui/wxpython/core
svn_grass at osgeo.org
Wed Oct 31 07:49:40 PDT 2012
Author: martinl
Date: 2012-10-31 07:49:39 -0700 (Wed, 31 Oct 2012)
New Revision: 53619
grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
wxGUI: fix language settings (wx)
(merge r53617 & r53618 from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-31 14:45:49 UTC (rev 53618)
+++ grass/branches/develbranch_6/gui/wxpython/core/globalvar.py 2012-10-31 14:49:39 UTC (rev 53619)
@@ -203,45 +203,57 @@
import locale
language = os.getenv('LANG')
- if language:
- language = language.split('.')[0] # Split off ignored .encoding part if present
- orig_language = language
- try:
- locale.setlocale(locale.LC_ALL, language)
- except:
+ if not language:
+ return
+ language = language.split('.')[0] # Split off ignored .encoding part if present
+ orig_language = language
+ try:
+ locale.setlocale(locale.LC_ALL, language)
+ except locale.Error, e:
+ if sys.platform != 'win32': # Don't try on Windows, it will probably not work
+ sys.stderr.write("Failed to set LC_ALL to %s (%s)\n" % (language, e))
try:
- # Locale lang.encoding might be missing. Let's try UTF-8 encoding before giving up
- # as on Linux systems lang.UTF-8 locales are more common than legacy ISO-8859 ones.
- language = locale.normalize('%s.UTF-8' % language)
+ # Locale lang.encoding might be missing. Let's try
+ # UTF-8 encoding before giving up as on Linux systems
+ # lang.UTF-8 locales are more common than legacy
+ # ISO-8859 ones.
+ language = locale.normalize('%s.UTF-8' % (language))
- except:
- # If we got so far, provided locale is not supported on this system
- sys.stderr.write("Failed to set LC_ALL to %s\n" % language)
- try:
- default_locale = locale.getdefaultlocale()
- except:
- default_locale = None
- if default_locale and default_locale[0]:
- language = default_locale[0]
- else:
- language = 'C'
- # Set up environment for subprocesses
- for lc in ('LC_CTYPE', 'LC_MESSAGES', 'LC_TIME', 'LC_COLLATE', 'LC_MONETARY', 'LC_PAPER', 'LC_NAME', 'LC_ADDRESS', 'LC_TELEPHONE', 'LC_MEASUREMENT', 'LC_IDENTIFICATION'):
- os.environ[lc] = language
- # Some code in GRASS might not like other decimal separators than .
- # Other potential sources for problems are: LC_TIME LC_CTYPE
- locale.setlocale(locale.LC_NUMERIC, 'C')
- os.environ['LC_NUMERIC'] = 'C'
- if os.getenv('LC_ALL'):
- del os.environ['LC_ALL'] # Remove LC_ALL to not override LC_NUMERIC
- # Even if setting locale has failed, let's set LANG in a hope, that UI will use it
- # GRASS texts will be in selected language, system messages (i.e. OK, Cancel etc.) - in system default language
- os.environ['LANGUAGE'] = orig_language
- os.environ['LANG'] = orig_language
+ # If we got so far, provided locale is not supported
+ # on this system
+ ### locale.getdefaultlocale() is probably related to gettext?
+ # try:
+ # default_locale = locale.getdefaultlocale()
+ # except:
+ # default_locale = None
+ # if default_locale and default_locale[0]:
+ # language = default_locale[0]
+ # else:
+ language = 'C'
+ # Set up environment for subprocesses
+ for lc in ('LC_CTYPE', 'LC_MESSAGES', 'LC_TIME', 'LC_COLLATE', 'LC_MONETARY', 'LC_PAPER',
+ 'LC_NAME', 'LC_ADDRESS', 'LC_TELEPHONE', 'LC_MEASUREMENT', 'LC_IDENTIFICATION'):
+ os.environ[lc] = language
+ Debug.msg(1, "Language setttings: (WX) %s / (GRASS) %s", language, orig_language)
+ # Some code in GRASS might not like other decimal separators than .
+ # Other potential sources for problems are: LC_TIME LC_CTYPE
+ locale.setlocale(locale.LC_NUMERIC, 'C')
+ os.environ['LC_NUMERIC'] = 'C'
+ if os.getenv('LC_ALL'):
+ del os.environ['LC_ALL'] # Remove LC_ALL to not override LC_NUMERIC
+ # Even if setting locale has failed, let's set LANG in a hope,
+ # that UI will use it GRASS texts will be in selected language,
+ # system messages (i.e. OK, Cancel etc.) - in system default
+ # language
+ os.environ['LANGUAGE'] = orig_language
+ os.environ['LANG'] = orig_language
"""@brief Collected GRASS-relared binaries/scripts"""
grassCmd, grassScripts = GetGRASSCommands()
