[GRASS-SVN] r53628 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Oct 31 13:02:44 PDT 2012
Author: mmetz
Date: 2012-10-31 13:02:43 -0700 (Wed, 31 Oct 2012)
New Revision: 53628
grass/trunk/lib/vector/Vlib/remove_duplicates.c
Vlib: fix for Vect_remove_duplicates()
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2012-10-31 19:55:18 UTC (rev 53627)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2012-10-31 20:02:43 UTC (rev 53628)
@@ -36,7 +36,7 @@
struct line_pnts *APoints, *BPoints;
struct line_cats *ACats, *BCats;
int i, j, c, atype, btype, bline;
- int nlines, nbcats_orig;
+ int nlines, nbcats_orig, npoints;
struct bound_box ABox;
struct boxlist *List;
int ndupl;
@@ -66,6 +66,15 @@
atype = Vect_read_line(Map, APoints, ACats, i);
if (!(atype & type))
continue;
+ npoints = APoints->n_points;
+ Vect_line_prune(APoints);
+ if (npoints != APoints->n_points) {
+ Vect_rewrite_line(Map, i, atype, APoints, ACats);
+ nlines = Vect_get_num_lines(Map);
+ continue;
Vect_line_box(APoints, &ABox);
Vect_select_lines_by_box(Map, &ABox, type, List);
@@ -78,6 +87,7 @@
continue;
btype = Vect_read_line(Map, BPoints, BCats, bline);
+ Vect_line_prune(BPoints);
/* check for duplicates */
if (!Vect_line_check_duplicate(APoints, BPoints, Vect_is_3d(Map)))
@@ -114,6 +124,9 @@
\brief Check for duplicate lines
+ Note that lines must be pruned with Vect_line_prune() before passed
+ to Vect_line_check_duplicate()
\param APoints first line geometry
\param BPoints second line geometry
