[GRASS-SVN] r53630 - in grass/trunk/vector: v.net.alloc v.net.allpairs v.net.bridge v.net.centrality v.net.components v.net.connectivity v.net.distance v.net.flow v.net.iso v.net.path v.net.salesman v.net.spanningtree v.net.steiner v.net.timetable
svn_grass at osgeo.org
Wed Oct 31 14:24:43 PDT 2012
Author: mmetz
Date: 2012-10-31 14:24:42 -0700 (Wed, 31 Oct 2012)
New Revision: 53630
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.allpairs/main.c
grass/trunk/vector/v.net.bridge/main.c
grass/trunk/vector/v.net.centrality/main.c
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net.connectivity/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.net.flow/main.c
grass/trunk/vector/v.net.iso/main.c
grass/trunk/vector/v.net.path/main.c
grass/trunk/vector/v.net.salesman/main.c
grass/trunk/vector/v.net.spanningtree/main.c
grass/trunk/vector/v.net.steiner/main.c
grass/trunk/vector/v.net.timetable/main.c
v.net*: option->description -> option->label
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.alloc/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -78,12 +78,12 @@
afield_opt = G_define_standard_option(G_OPT_V_FIELD);
afield_opt->key = "alayer";
afield_opt->answer = "1";
- afield_opt->description = _("Arc layer");
+ afield_opt->label = _("Arc layer");
nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
nfield_opt->key = "nlayer";
nfield_opt->answer = "2";
- nfield_opt->description = _("Node layer");
+ nfield_opt->label = _("Node layer");
afcol = G_define_option();
afcol->key = "afcolumn";
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.allpairs/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -71,13 +71,13 @@
afield_opt->guisection = _("Selection");
nfield_opt->guisection = _("Selection");
cat_opt = G_define_standard_option(G_OPT_V_CATS);
Modified: grass/trunk/vector/v.net.bridge/main.c
--- grass/trunk/vector/v.net.bridge/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.bridge/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -57,13 +57,13 @@
afield_opt->guisection = _("Cost");
nfield_opt->guisection = _("Cost");
afcol = G_define_standard_option(G_OPT_DB_COLUMN);
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.centrality/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -106,13 +106,13 @@
map_out = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.components/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -80,13 +80,13 @@
Modified: grass/trunk/vector/v.net.connectivity/main.c
--- grass/trunk/vector/v.net.connectivity/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.connectivity/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -62,13 +62,13 @@
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.distance/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -77,19 +77,19 @@
atype_opt = G_define_standard_option(G_OPT_V_TYPE);
atype_opt->options = "line,boundary";
atype_opt->answer = "line,boundary";
- atype_opt->description = _("Arc type");
+ atype_opt->label = _("Arc type");
atype_opt->guisection = _("Cost");
fieldf_opt = G_define_standard_option(G_OPT_V_FIELD);
Modified: grass/trunk/vector/v.net.flow/main.c
--- grass/trunk/vector/v.net.flow/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.flow/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -67,13 +67,13 @@
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.iso/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -83,7 +83,7 @@
- type_opt->description = _("Arc type");
+ type_opt->label = _("Arc type");
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.path/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -48,17 +48,17 @@
file_opt = G_define_standard_option(G_OPT_F_INPUT);
file_opt->key = "file";
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.salesman/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -142,12 +142,12 @@
tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
tfield_opt->key = "nlayer";
tfield_opt->answer = "2";
- tfield_opt->description = _("Node layer (used for cities)");
+ tfield_opt->label = _("Node layer (used for cities)");
Modified: grass/trunk/vector/v.net.spanningtree/main.c
--- grass/trunk/vector/v.net.spanningtree/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.spanningtree/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -56,13 +56,13 @@
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.steiner/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -358,17 +358,17 @@
- tfield_opt->description = _("Node layer (used for terminals)");
+ tfield_opt->label = _("Node layer (used for terminals)");
afcol->key = "acolumn";
Modified: grass/trunk/vector/v.net.timetable/main.c
--- grass/trunk/vector/v.net.timetable/main.c 2012-10-31 21:01:41 UTC (rev 53629)
+++ grass/trunk/vector/v.net.timetable/main.c 2012-10-31 21:24:42 UTC (rev 53630)
@@ -271,13 +271,13 @@
