[GRASS-SVN] r53054 - grass/branches/releasebranch_6_4/raster/r.grow.distance
Sun Sep 2 05:49:21 PDT 2012
Author: neteler
Date: 2012-09-02 05:49:21 -0700 (Sun, 02 Sep 2012)
New Revision: 53054
   grass/branches/releasebranch_6_4/raster/r.grow.distance/description.html
   grass/branches/releasebranch_6_4/raster/r.grow.distance/main.c
r.grow.distance: backport of geodetic distance support (trunk, r34429); +example
Modified: grass/branches/releasebranch_6_4/raster/r.grow.distance/description.html
--- grass/branches/releasebranch_6_4/raster/r.grow.distance/description.html	2012-09-02 00:09:18 UTC (rev 53053)
+++ grass/branches/releasebranch_6_4/raster/r.grow.distance/description.html	2012-09-02 12:49:21 UTC (rev 53054)
@@ -62,6 +62,12 @@
 g.region rast=streams_derived -p
 r.grow.distance input=streams_derived distance=dist_from_streams
 </pre></div>
+<p>
+Distance from sea in meters in latitude-longitude location:
+<div class="code"><pre>
+g.region rast=sea -p
+r.grow.distance -m input=sea distance=dist_from_sea_geodetic metric=geodesic
+</pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_6_4/raster/r.grow.distance/main.c
--- grass/branches/releasebranch_6_4/raster/r.grow.distance/main.c	2012-09-02 00:09:18 UTC (rev 53053)
+++ grass/branches/releasebranch_6_4/raster/r.grow.distance/main.c	2012-09-02 12:49:21 UTC (rev 53054)
@@ -1,7 +1,7 @@
- * MODULE:       r.grow2
+ * MODULE:       r.grow.distance
  * AUTHOR(S):    Marjorie Larson - CERL
  *               Glynn Clements
@@ -9,7 +9,7 @@
  * PURPOSE:      Generates a raster map layer with contiguous areas
  *               grown by one cell.
- * COPYRIGHT:    (C) 2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006, 2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,6 +26,7 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+static struct Cell_head window;
 static int nrows, ncols;
 static DCELL *in_row;
 static CELL *old_x_row, *old_y_row;
@@ -52,6 +53,16 @@
     return abs(dx) + abs(dy);
+static double geodesic_distance(int x1, int y1, int x2, int y2)
+    double lat1 = G_row_to_northing(y1 + 0.5, &window);
+    double lat2 = G_row_to_northing(y2 + 0.5, &window);
+    double lon1 = G_col_to_easting(x1 + 0.5, &window);
+    double lon2 = G_col_to_easting(x2 + 0.5, &window);
+    return G_geodesic_distance(lon1, lat1, lon2, lat2);
 void swap_rows(void)
     CELL *temp;
@@ -69,7 +80,8 @@
     old_val_row = new_val_row;
     new_val_row = dtemp;
-static void check(int col, int dx, int dy)
+static void check(int row, int col, int dx, int dy)
     const CELL *xrow = dy ? old_x_row : new_x_row;
     const CELL *yrow = dy ? old_y_row : new_y_row;
@@ -92,7 +104,9 @@
     x = xrow[col + dx] + dx;
     y = yrow[col + dx] + dy;
     v = vrow[col + dx];
-    d = (*distance) (xres * x, yres * y);
+    d = distance
+	? (*distance) (xres * x, yres * y)
+	: geodesic_distance(col, row, col + x, row + y);
     if (!G_is_d_null_value(&dist_row[col]) && dist_row[col] < d)
 	return;
@@ -110,6 +124,10 @@
 	struct Option *in, *dist, *val, *met;
     } opt;
+    struct
+	struct Flag *m;
+    } flag;
     const char *in_name;
     const char *dist_name;
     const char *val_name;
@@ -122,7 +140,7 @@
     struct FPRange range;
     DCELL min, max;
     DCELL *out_row;
-    struct Cell_head window;
+    double scale = 1.0;
     G_gisinit(argv[0]);
@@ -148,9 +166,13 @@
     opt.met->type = TYPE_STRING;
     opt.met->required = NO;
     opt.met->description = _("Metric");
-    opt.met->options = "euclidean,squared,maximum,manhattan";
+    opt.met->options = "euclidean,squared,maximum,manhattan,geodesic";
     opt.met->answer = "euclidean";
+    flag.m = G_define_flag();
+    flag.m->key = 'm';
+    flag.m->description = _("Output distances in meters instead of map units");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -161,6 +183,8 @@
     if (!dist_name && !val_name)
 	G_fatal_error(_("At least one of distance= and value= must be given"));
+    G_get_window(&window);
     if (strcmp(opt.met->answer, "euclidean") == 0)
 	distance = &distance_euclidean_squared;
     else if (strcmp(opt.met->answer, "squared") == 0)
@@ -169,6 +193,14 @@
 	distance = &distance_maximum;
     else if (strcmp(opt.met->answer, "manhattan") == 0)
 	distance = &distance_manhattan;
+    else if (strcmp(opt.met->answer, "geodesic") == 0) {
+	double a, e2;
+	if (window.proj != PROJECTION_LL)
+	    G_fatal_error(_("metric=geodesic is only valid for lat/lon"));
+	distance = NULL;
+	G_get_ellipsoid_parameters(&a, &e2);
+	G_begin_geodesic_distance(a, e2);
     else
 	G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
@@ -176,6 +208,12 @@
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), in_name);
+    if (flag.m->answer) {
+	scale = G_database_units_to_meters_factor();
+	if (strcmp(opt.met->answer, "squared") == 0)
+	    scale *= scale;
     if (dist_name) {
 	dist_fd = G_open_raster_new(dist_name, DCELL_TYPE);
 	if (dist_fd < 0)
@@ -193,8 +231,6 @@
     if (temp_fd < 0)
 	G_fatal_error(_("Unable to create temporary file <%s>"), temp_name);
-    G_get_window(&window);
     nrows = window.rows;
     ncols = window.cols;
     xres = window.ew_res;
@@ -220,6 +256,7 @@
     G_set_c_null_value(old_x_row, ncols);
     G_set_c_null_value(old_y_row, ncols);
+    G_message(_("Reading raster map <%s>..."), opt.in->answer);
     for (row = 0; row < nrows; row++) {
 	int irow = nrows - 1 - row;
@@ -241,15 +278,15 @@
 	for (col = 0; col < ncols; col++)
-	    check(col, -1, 0);
+	    check(irow, col, -1, 0);
 	for (col = ncols - 1; col >= 0; col--)
-	    check(col, 1, 0);
+	    check(irow, col, 1, 0);
 	for (col = 0; col < ncols; col++) {
-	    check(col, -1, 1);
-	    check(col, 0, 1);
-	    check(col, 1, 1);
+	    check(irow, col, -1, 1);
+	    check(irow, col, 0, 1);
+	    check(irow, col, 1, 1);
 	write(temp_fd, new_x_row, ncols * sizeof(CELL));
@@ -267,6 +304,7 @@
+    G_message(_("Writing output raster maps..."), opt.in->answer);
 	off_t offset =
@@ -282,23 +320,27 @@
 	read(temp_fd, new_val_row, ncols * sizeof(DCELL));
-	    check(col, -1, -1);
-	    check(col, 0, -1);
-	    check(col, 1, -1);
+	    check(row, col, -1, -1);
+	    check(row, col, 0, -1);
+	    check(row, col, 1, -1);
+	    check(row, col, -1, 0);
-	    check(col, 1, 0);
+	    check(row, col, 1, 0);
 	if (dist_name) {
 	    if (out_row != dist_row)
 		    out_row[col] = sqrt(dist_row[col]);
-	    G_put_d_raster_row(dist_fd, out_row);
+	    if (scale != 1.0)
+		for (col = 0; col < ncols; col++)
+		    out_row[col] *= scale;
+	   G_put_d_raster_row(dist_fd, out_row);
 	if (val_name)
