[GRASS-SVN] r53062 - in grass-addons/grass7/general: . g.copyall
    svn_grass at osgeo.org
    Sun Sep  2 16:09:56 PDT 2012
Author: cmbarton
Date: 2012-09-02 16:09:55 -0700 (Sun, 02 Sep 2012)
New Revision: 53062
Added:
   grass-addons/grass7/general/g.copyall/
   grass-addons/grass7/general/g.copyall/Makefile
   grass-addons/grass7/general/g.copyall/g.copyall.html
   grass-addons/grass7/general/g.copyall/g.copyall.py
script to copy all or filtered set of maps from one mapset to another
Added: grass-addons/grass7/general/g.copyall/Makefile
--- grass-addons/grass7/general/g.copyall/Makefile	                        (rev 0)
+++ grass-addons/grass7/general/g.copyall/Makefile	2012-09-02 23:09:55 UTC (rev 53062)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=g.copyall
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/general/g.copyall/g.copyall.html
--- grass-addons/grass7/general/g.copyall/g.copyall.html	                        (rev 0)
+++ grass-addons/grass7/general/g.copyall/g.copyall.html	2012-09-02 23:09:55 UTC (rev 53062)
@@ -0,0 +1,34 @@
+<h2>DESCRIPTION</h2>
+<em><b>g.copyall</b></em> copies maps/files of a specified from a selected mapset
+to the current working mapset. All maps/files can be copied or a subset of
+maps/files specified by a wildcard pattern or regular expression. Optionally, a
+prefix can be added to all files copied and vector topology can be rebuilt to match
+currently running version of GRASS.
+<h2>EXAMPLES</h2>
+Copy all raster maps from mapset "test" to current mapset and prefix them
+with "fromtest":
+<div class="code"><pre>
+g.copyall mapset=test output_prefix=fromtest
+</pre></div>
+Copy all vector maps beginning with "s" from mapset "test" to current mapset:
+g.copyall mapset=test datatype=vect filter=s*
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.mlist">g.mlist</a>,
+<a href="g.copy">g.copy</a>,
+</em>
+<h2>AUTHOR</h2>
+Michael Barton (Arizona State University, USA)
+<p><i>Last changed: $Date: $</i>
Added: grass-addons/grass7/general/g.copyall/g.copyall.py
--- grass-addons/grass7/general/g.copyall/g.copyall.py	                        (rev 0)
+++ grass-addons/grass7/general/g.copyall/g.copyall.py	2012-09-02 23:09:55 UTC (rev 53062)
@@ -0,0 +1,115 @@
+#!/usr/bin/env python
+# MODULE:	    g.copyall
+# AUTHOR(S):    Michael Barton (ASU)
+# PURPOSE:	Copies all or a filtered subset of GRASS files of a selected type
+#           from another mapset to the current working mapset
+# COPYRIGHT:	(C) 2002-2012 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Copies all or a filtered subset of files of selected type from another mapset to the current working mapset
+#%  keywords: copy
+#%  keywords: general
+#%  overwrite: yes
+#%End
+#%option G_OPT_M_MAPSET
+#%  key: mapset
+#%  description: Mapset to copy files from
+#%  required: yes
+#%end
+#%option
+#%  key: datatype
+#%  type: string
+#%  description: Choose type of GRASS data to copy
+#%  options: rast,vect,labels,rast3d,region,group
+#%  answer: rast
+#%  required: yes
+#%end
+#%option
+#%  key: filter
+#%  type: string
+#%  description: Search pattern to filter data files to copy
+#%  required : no
+#%end
+#%option
+#%  key: filter_type
+#%  type: string
+#%  description: Type of search pattern to use
+#%  options: select all, wildcards,regular expressions,extended regular expressions
+#%  answer: select all
+#%  required : no
+#%end
+#%option
+#%  key: output_prefix
+#%  type: string
+#%  description: Optional prefix for output raster maps
+#%  required : no
+#%end
+#% Flag
+#% key: t
+#% description: Update vector topology to match current GRASS version
+#% End
+import grass.script as grass
+def main():
+    # define variables
+    overwrite   = False
+    mapset      = options['mapset'] # prefix for copied maps
+    datatype    = options['datatype'] # prefix for copied maps
+    filter      = options['filter'] # prefix for copied maps
+    filter_type = options['filter_type'] # prefix for copied maps
+    prefix      = options['output_prefix'] # prefix for copied maps
+    datalist    = [] #list of GRASS data files to copy
+    input       = ''
+    output      = ''
+    if grass.overwrite(): overwrite = True
+    if filter_type == 'select all': filter = '*'
+    filterflag = ''
+    if filter_type == 'regular expressions': filterflag = 'r'
+    if filter_type == 'extended regular expressions': filterflag = 'e'
+    # first run g.list to get list of maps to parse
+    l = grass.mlist_grouped(type=datatype, pattern=filter, check_search_path = True, flag=filterflag)
+    if mapset not in l:
+        grass.warning(_('You do not have access to mapset %s. Run g.mapsets (under settings menu) to change mapset access') % mapset)
+        return
+    datalist = l[mapset]
+    # then loop through the maps copying them with g.copy and optionally adding prefix
+    for input in datalist:
+        if prefix: output = '%s_%s' % (prefix, input)
+        else: output = input
+        params = {datatype: '%s@%s,%s' % (input, mapset, output)}
+        grass.run_command('g.copy', overwrite=overwrite, **params)
+        if datatype == 'vect' and flags['t']:
+            grass.run_command('v.build', map=output)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass-addons/grass7/general/g.copyall/g.copyall.py
___________________________________________________________________
Added: svn:executable
