[GRASS-SVN] r53067 - grass-addons/grass6/raster/r.connectivity.corridors
svn_grass at osgeo.org
Mon Sep 3 05:54:52 PDT 2012
Author: sbl
Date: 2012-09-03 05:54:50 -0700 (Mon, 03 Sep 2012)
New Revision: 53067
grass-addons/grass6/raster/r.connectivity.corridors/description.html
Removed headers and footers from description.html
Modified: grass-addons/grass6/raster/r.connectivity.corridors/description.html
--- grass-addons/grass6/raster/r.connectivity.corridors/description.html 2012-09-03 12:49:09 UTC (rev 53066)
+++ grass-addons/grass6/raster/r.connectivity.corridors/description.html 2012-09-03 12:54:50 UTC (rev 53067)
@@ -1,66 +1,3 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>GRASS GIS manual: r.connectivity.corridors</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>r.connectivity.corridors</b></em> - Compute corridors between habitat patches for edges from r.connectivity.network based on (cost) distance raster maps from r.connectivity.distance
-<h2>KEYWORDS</h2>
-<dl>
-raster, vector, connectivity, network, corridor
-</dl>
-<h2>SYNOPSIS</h2>
-<b>r.connectivity.corridors</b><br>
-<b>r.connectivity.corridors help</b><br>
-<b>r.connectivity.corridors</b> [-<b>sdr</b>] <b>folder</b>=<em>string</em> <b>suffix</b>=<em>string</em> [<b>corridor_tolerance</b>=<em>float</em>] [<b>where</b>=<em>where (SQL statement)</em>] [<b>weights</b>=<em>Column names</em>[,<i>Column names</i>,...]] [<b>cores</b>=<em>integer</em>] [--<b>verbose</b>] [--<b>quiet</b>]
-<h3>Flags:</h3>
-<dl>
-<dt><b>-s</b></dt>
-<dd>Show edges selected by WHERE-clause and exit</dd>
-<dt><b>-d</b></dt>
-<dd>Assign distance values to corridors instead of connection IDs and weights</dd>
-<dt><b>-r</b></dt>
-<dd>Recalculate already computed corridors (default is only weight and summarize already existing corridor maps)</dd>
-<dt><b>--verbose</b></dt>
-<dd>Verbose module output</dd>
-<dt><b>--quiet</b></dt>
-<dd>Quiet module output</dd>
-</dl>
-<h3>Parameters:</h3>
-<dl>
-<dt><b>folder</b>=<em>string</em></dt>
-<dd>Folder where all (non map) output data from r.connectivity.* is stored (input)</dd>
-<dt><b>suffix</b>=<em>string</em></dt>
-<dd>Suffix for specifying corridor summary result</dd>
-<dt><b>corridor_tolerance</b>=<em>float</em></dt>
-<dd>Tolerance for deviation of corridors from (cost) distance between a pair of vertices (in % of the undirected (cost) distance of the edge)</dd>
-<dd>Default: <em>0.0</em></dd>
-<dt><b>where</b>=<em>string (SQL where statement)</em></dt>
-<dd>WHERE conditions of SQL statement without 'where' keyword. (example: cf_mst_ud = 1 or cf_eb_ud > 100)</dd>
-<dt><b>weights</b>=<em>string (Column name[,<i>Column name</i>,...])</em></dt>
-<dd>Column names for weights which should be assigned to the corridors separated by comma (multiple)</dd>
-<dt><b>cores</b>=<em>integer</em></dt>
-<dd>Number of cores to be used for multithreading (1 means no multithreading)</dd>
-<dd>Default: <em>1</em></dd>
-</dl>
<h2>DESCRIPTION</h2>
<dl>
Recently, graph-theory has been characterised as an efficient and useful tool for conservation planning (e.g. Bunn et al. 2000, Calabrese & Fagan 2004, Minor & Urban 2008, Zetterberg et. al. 2010). As a part of the r.connectivity.* tool-chain, r.connectivity.corridors is intended to make graph-theory more easily available to conservation planning.
@@ -78,12 +15,12 @@
</dl>
<h2>SEE ALSO</h2>
-<a href="r.connectivity.distance">r.connectivity.distance</a>, <a href="r.connectivity.network">r.connectivity.network</a><br>
+<em><a href="r.connectivity.distance">r.connectivity.distance</a>,
+<a href="r.connectivity.network">r.connectivity.network</a>
+</em>
+<br>
<h2>AUTHOR</h2>
Stefan Blumentrath, Norwegian Institute for Nature Research (NINA)
<br><br>
-<i>Last changed: $Date$</i>
-</body>
-</html>
+<p><i>Last changed: $Date$</i>
