[GRASS-SVN] r53070 - grass/branches/develbranch_6/gui/wxpython/lmgr
svn_grass at osgeo.org
Mon Sep 3 06:54:57 PDT 2012
Author: annakrat
Date: 2012-09-03 06:54:56 -0700 (Mon, 03 Sep 2012)
New Revision: 53070
grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
wxGUI/layertree: fix various issues (backport from trunk, r52913,r52932,r52933,r53064)
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-09-03 13:35:20 UTC (rev 53069)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-09-03 13:54:56 UTC (rev 53070)
@@ -124,6 +124,8 @@
self.flag = '' # flag for drag and drop hittest
self.rerender = False # layer change requires a rerendering if auto render
self.reorder = False # layer change requires a reordering
+ self.hitCheckbox = False # if cursor points at layer checkbox (to cancel selection changes)
+ self.forceCheck = False # force check layer if CheckItem is called
try:
ctstyle |= CT.TR_ALIGN_WINDOWS
@@ -227,13 +229,16 @@
self.Bind(wx.EVT_TREE_ITEM_COLLAPSED, self.OnCollapseNode)
self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnActivateLayer)
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnChangeSel)
+ self.Bind(wx.EVT_TREE_SEL_CHANGING, self.OnChangingSel)
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
+ self.Bind(CT.EVT_TREE_ITEM_CHECKING, self.OnLayerChecking)
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
self.Bind(wx.EVT_TREE_END_DRAG, self.OnEndDrag)
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnRenamed)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
def _setGradient(self, iType = None):
"""!Set gradient for items
@@ -250,6 +255,22 @@
self.SetFirstGradientColour(wx.Colour(100, 100, 100))
self.SetSecondGradientColour(wx.Colour(150, 150, 150))
+ def GetSelections(self):
+ """Returns a list of selected items.
+ This method is copied from customtreecontrol and overriden because
+ with some version wx (?) multiple selection doesn't work.
+ Probably it is caused by another GetSelections method in treemixin.DragAndDrop?
+ array = []
+ idRoot = self.GetRootItem()
+ if idRoot:
+ array = self.FillArray(idRoot, array)
+ #else: the tree is empty, so no selections
+ return array
def GetMap(self):
"""!Get map instace"""
return self.Map
@@ -448,8 +469,9 @@
self.popupMenu.Enable(self.popupID['univar'], False)
self.popupMenu.Enable(self.popupID['prof'], False)
self.popupMenu.Enable(self.popupID['meta'], False)
- self.popupMenu.Enable(self.popupID['nviz'], False)
self.popupMenu.Enable(self.popupID['export'], False)
+ if self.lmgr.IsPaneShown('toolbarNviz'):
+ self.popupMenu.Enable(self.popupID['nviz'], False)
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
@@ -792,6 +814,7 @@
else:
checked = True
+ self.forceCheck = True
self.CheckItem(layer, checked = checked)
# add text and icons for each layer ltype
@@ -1085,6 +1108,17 @@
event.Skip()
+ def OnLayerChecking(self, event):
+ """!Layer checkbox is being checked.
+ Continue only if mouse is above checkbox or layer was checked programatically.
+ if self.hitCheckbox or self.forceCheck:
+ event.Skip()
+ else:
+ event.Veto()
def OnLayerChecked(self, event):
"""!Enable/disable data layer"""
self.lmgr.WorkspaceChanged()
@@ -1098,6 +1132,7 @@
if self.GetPyData(item)[0]['type'] == 'group':
child, cookie = self.GetFirstChild(item)
while child:
self.CheckItem(child, checked)
mapLayer = self.GetPyData(child)[0]['maplayer']
if not digitToolbar or \
@@ -1112,8 +1147,6 @@
# ignore when map layer is edited
self.Map.ChangeLayerActive(mapLayer, checked)
- self.Unselect()
# update progress bar range (mapwindow statusbar)
self.mapdisplay.GetProgressBar().SetRange(len(self.Map.GetListOfLayers(l_active = True)))
@@ -1169,14 +1202,32 @@
event.Skip()
+ def OnMotion(self, event):
+ """!Mouse is moving.
+ Detects if mouse points at checkbox.
+ thisItem, flags = self.HitTest(event.GetPosition())
+ # workaround: in order not to check checkox when clicking outside
+ # we need flag TREE_HITTEST_ONITEMCHECKICON but not TREE_HITTEST_ONITEMLABEL
+ # this applies only for TR_FULL_ROW_HIGHLIGHT style
+ if (flags & CT.TREE_HITTEST_ONITEMCHECKICON) and not (flags & CT.TREE_HITTEST_ONITEMLABEL):
+ self.hitCheckbox = True
+ else:
+ event.Skip()
+ def OnChangingSel(self, event):
+ """!Selection is changing.
+ If the user is clicking on checkbox, selection change is vetoed.
+ if self.hitCheckbox:
+ event.Veto()
def OnChangeSel(self, event):
"""!Selection changed"""
- oldlayer = event.GetOldItem()
layer = event.GetItem()
- if layer == oldlayer:
- event.Veto()
- return
digitToolbar = self.mapdisplay.GetToolbar('vdigit')
if digitToolbar:
mapLayer = self.GetPyData(layer)[0]['maplayer']
@@ -1382,6 +1433,7 @@
else:
self.GetPyData(newItem)[0]['ctrl'] = None
self.CheckItem(newItem, checked = checked) # causes a new render
return newItem
