[GRASS-SVN] r53076 - in grass/branches/releasebranch_6_4/gui/wxpython: core mapdisp nviz
Mon Sep 3 08:51:42 PDT 2012
Author: annakrat
Date: 2012-09-03 08:51:41 -0700 (Mon, 03 Sep 2012)
New Revision: 53076
   grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
   grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py
wxNviz: small changes in tooltips, default values suggested by Michael Barton (merge from trunk, r53074)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-09-03 15:51:17 UTC (rev 53075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-09-03 15:51:41 UTC (rev 53076)
@@ -600,7 +600,7 @@
                 'cplane' : {
                     'shading': 4,
                     'rotation':{
-                        'rot': 0,
+                        'rot': 180,
                         'tilt': 0
                     'position':{
Modified: grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py	2012-09-03 15:51:17 UTC (rev 53075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py	2012-09-03 15:51:41 UTC (rev 53076)
@@ -542,9 +542,9 @@
         """!Save map to image
         if self.IsPaneShown('3d'):
-            filetype = "PPM file (*.ppm)|*.ppm|TIF file (*.tif)|*.tif"
-            ltype = [{ 'ext' : 'ppm', 'type' : 'ppm' },
-                     { 'ext' : 'tif', 'type' : 'tif' }]
+            filetype = "TIF file (*.tif)|*.tif|PPM file (*.ppm)|*.ppm"
+            ltype = [{ 'ext' : 'tif', 'type' : 'tif' },
+                     { 'ext' : 'ppm', 'type' : 'ppm' }]
         else:
             img = self.MapWindow.img
             if not img:
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2012-09-03 15:51:17 UTC (rev 53075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2012-09-03 15:51:41 UTC (rev 53076)
@@ -170,7 +170,7 @@
         self.Bind(EVT_UPDATE_PROP,   self.UpdateMapObjProperties)
         self.Bind(EVT_UPDATE_VIEW,   self.OnUpdateView)
         self.Bind(EVT_UPDATE_LIGHT,  self.UpdateLight)
-        self.Bind(EVT_UPDATE_CPLANE, self.UpdateCPlane)
+        self.Bind(EVT_UPDATE_CPLANE, self.OnUpdateCPlane)
         self.Bind(wx.EVT_TIMER, self.OnTimerAnim, self.timerAnim)
         self.Bind(wx.EVT_TIMER, self.OnTimerFly, self.timerFly)
@@ -1561,19 +1561,22 @@
                 except IndexError:
                     pass
-    def UpdateCPlane(self, event):
+    def OnUpdateCPlane(self, event):
         """!Change cutting plane settings"""
-        current = event.current
-        for each in event.update:
+        self.UpdateCPlane(event.current, event.update)
+    def UpdateCPlane(self, index, changes):
+        """!Change cutting plane settings"""
+        for each in changes:
             if each == 'rotation':
-                self._display.SetCPlaneRotation(0, self.cplanes[current]['rotation']['tilt'],
-                                                   self.cplanes[current]['rotation']['rot'])
+                self._display.SetCPlaneRotation(0, self.cplanes[index]['rotation']['tilt'],
+                                                   self.cplanes[index]['rotation']['rot'])
             if each == 'position':
-                self._display.SetCPlaneTranslation(self.cplanes[current]['position']['x'],
-                                                   self.cplanes[current]['position']['y'],
-                                                   self.cplanes[current]['position']['z'])
+                self._display.SetCPlaneTranslation(self.cplanes[index]['position']['x'],
+                                                   self.cplanes[index]['position']['y'],
+                                                   self.cplanes[index]['position']['z'])
             if each == 'shading':
-                self._display.SetFenceColor(self.cplanes[current]['shading'])
+                self._display.SetFenceColor(self.cplanes[index]['shading'])
     def UnloadRaster(self, item):
         """!Unload 2d raster map
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py	2012-09-03 15:51:17 UTC (rev 53075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py	2012-09-03 15:51:41 UTC (rev 53076)
@@ -20,6 +20,7 @@
 import os
+import sys
 import copy
 import types
@@ -235,7 +236,7 @@
         # perspective
         # set initial defaults here (or perhaps in a default values file), not in user settings
         #todo: consider setting an absolute max at 360 instead of undefined. (leave the default max value at pi)
-        tooltip = _("Adjusts the viewer's angle of view")
+        tooltip = _("Adjusts the distance and angular perspective of the image viewpoint")
         self._createControl(panel, data = self.win['view'], name = 'persp',
                             tooltip = tooltip, range = (1, 120),
                             bind = (self.OnViewChange, self.OnViewChanged, self.OnViewChangedText))
@@ -248,25 +249,23 @@
                       flag = wx.ALIGN_CENTER)
         # twist
-        tooltip = _("Rotates the scene about the horizontal axis."
-                   " An angle of 0 is flat. The scene rotates between -90 and 90 degrees.")
+        tooltip = _("Tilts the plane of the surface from the horizontal")
         self._createControl(panel, data = self.win['view'], name = 'twist',
                             tooltip = tooltip, range = (-180,180),
-        gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Twist:")),
+        gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Tilt:")),
                       pos = (1, 1), flag = wx.ALIGN_CENTER)
         gridSizer.Add(item = self.FindWindowById(self.win['view']['twist']['slider']), pos = (2, 1))
         gridSizer.Add(item = self.FindWindowById(self.win['view']['twist']['text']), pos = (3, 1),
         # height + z-exag
-        tooltip = _("Adjusts the viewer's height above the scene")
+        tooltip = _("Adjusts the viewing height above the surface"
+                    " (angle of view automatically adjusts to maintain the same center of view)")
         self._createControl(panel, data = self.win['view'], name = 'height', sliderHor = False,
                             tooltip = tooltip, range = (0, 1),
-        tooltip = _("Adjusts the vertical exaggeration of the surface. "
-                    "As an example, if the easting and northing are in meters and the elevation in feet, "
-                    "a vertical exaggeration of .305 would produce a true (unexaggerated) surface. ")
+        tooltip = _("Adjusts the relative height of features above the plane of the surface")
         self._createControl(panel, data = self.win['view'], name = 'z-exag', sliderHor = False,
                             tooltip = tooltip, range = (0, 10), floatSlider = True,
@@ -483,7 +482,7 @@
                                                           key = 'animation', subkey = 'prefix'))
         prefixCtrl.SetToolTipString(_("Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."))
         fileTypeLabel = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("File format:"))
-        fileTypeCtrl = wx.Choice(parent = panel, id = wx.ID_ANY, choices = ["PPM", "TIF"])
+        fileTypeCtrl = wx.Choice(parent = panel, id = wx.ID_ANY, choices = ["TIF", "PPM"])
         save = wx.Button(parent = panel, id = wx.ID_ANY,
                          label = "Save")
@@ -873,7 +872,7 @@
         self.win['surface']['position']['reset'] = reset.GetId()
         self.win['surface']['position']['axis'] = axis.GetId()
-        axis.SetSelection(0)
+        axis.SetSelection(2)
         axis.Bind(wx.EVT_CHOICE, self.OnSurfaceAxis)
         pslide = self.FindWindowById(self.win['surface']['position']['slider'])
@@ -1010,8 +1009,8 @@
         self._createControl(panel, data = self.win['cplane']['rotation'], name = 'rot', size = 250,
                             range = (0, 360), sliderHor = True, tooltip = tooltip,
                             bind = (self.OnCPlaneChanging, self.OnCPlaneChangeDone, self.OnCPlaneChangeText))
-        self.FindWindowById(self.win['cplane']['rotation']['rot']['slider']).SetValue(0)
-        self.FindWindowById(self.win['cplane']['rotation']['rot']['text']).SetValue(0)
+        self.FindWindowById(self.win['cplane']['rotation']['rot']['slider']).SetValue(180)
+        self.FindWindowById(self.win['cplane']['rotation']['rot']['text']).SetValue(180)
         gridSizer.Add(item = self.FindWindowById(self.win['cplane']['rotation']['rot']['slider']),
                       pos = (2, 1),  flag = wx.EXPAND|wx.ALIGN_RIGHT)
         gridSizer.Add(item = self.FindWindowById(self.win['cplane']['rotation']['rot']['text']),
@@ -1604,7 +1603,7 @@
         self.win['volume']['position']['reset'] = reset.GetId()
         self.win['volume']['position']['axis'] = axis.GetId()
+        axis.SetSelection(2) # Z
         axis.Bind(wx.EVT_CHOICE, self.OnVolumeAxis)
         pslide = self.FindWindowById(self.win['volume']['position']['slider'])
@@ -2519,7 +2518,10 @@
         ne = wx.Button(panel, id = wx.ID_ANY, label = _("NE"))
         se = wx.Button(panel, id = wx.ID_ANY, label = _("SE"))
         sw = wx.Button(panel, id = wx.ID_ANY, label = _("SW"))
-        minWidth = sw.GetTextExtent(sw.GetLabel())[0] + 15
+        padding = 15
+        if sys.platform == 'darwin':
+            padding = 20
+        minWidth = sw.GetTextExtent(sw.GetLabel())[0] + padding
         for win, name in zip((w, n, s, e, nw, ne, se, sw),
                         ('w', 'n', 's', 'e', 'nw', 'ne', 'se', 'sw')):
             win.SetMinSize((minWidth, -1))
@@ -2774,7 +2776,7 @@
         for win in self.win['surface']['position'].itervalues():
             if win == self.win['surface']['position']['axis']:
-                self.FindWindowById(win).SetSelection(0)
+                self.FindWindowById(win).SetSelection(2) # Z
             elif win == self.win['surface']['position']['reset']:
                 continue
             else:
@@ -3949,7 +3951,7 @@
         """!Reset position of volume"""
         for win in self.win['volume']['position'].itervalues():
             if win == self.win['volume']['position']['axis']:
             elif win == self.win['volume']['position']['reset']:
                 continue
             else:
@@ -4071,6 +4073,9 @@
             planeIndex = -1
             self.EnablePage("cplane", enabled = False)
         self.mapWindow.SelectCPlane(planeIndex)
+        if planeIndex >= 0:
+            self.mapWindow.UpdateCPlane(planeIndex, changes = ['rotation', 'position', 'shading'])
         if self.mapDisplay.IsAutoRendered():
             self.mapWindow.Refresh(False)
         self.UpdateCPlanePage(planeIndex)
@@ -4137,8 +4142,10 @@
             planeIndex = int(plane.split()[-1]) - 1
         except:#TODO disabled page
             planeIndex = -1
         self.mapWindow.cplanes[planeIndex] = copy.deepcopy(UserSettings.Get(group = 'nviz',
        key = 'cplane'))
+        self.mapWindow.cplanes[planeIndex]['on'] = True
         event = wxUpdateCPlane(update = ('position','rotation','shading'), current = planeIndex)
         wx.PostEvent(self.mapWindow, event)
         self.OnCPlaneChangeDone(None)
@@ -4437,11 +4444,11 @@
         dim = self._display.GetLongDim()
         self.FindWindowById(self.win['surface']['position']['slider']).SetRange(-2 * dim, 2 * dim)
-        if 'x' in data['position']:
-            xval = data['position']['x']
-            self.FindWindowById(self.win['surface']['position']['axis']).SetSelection(0)
+        if 'z' in data['position']:
+            zval = data['position']['z']
+            self.FindWindowById(self.win['surface']['position']['axis']).SetSelection(2)
             for control in ('slider','text'):
-                    self.FindWindowById(self.win['surface']['position'][control]).SetValue(xval)
+                    self.FindWindowById(self.win['surface']['position'][control]).SetValue(zval)
         # enable/disable res widget + set draw mode
         self.OnSurfaceMode(event = None)
@@ -4636,11 +4643,11 @@
         # position
-            self.FindWindowById(self.win['volume']['position']['axis']).SetSelection(0)
+            self.FindWindowById(self.win['volume']['position']['axis']).SetSelection(2)
-                    self.FindWindowById(self.win['volume']['position'][control]).SetValue(xval)
+                    self.FindWindowById(self.win['volume']['position'][control]).SetValue(zval)
         # set topo range
         mapRange = self._get3dRange(name = layer.name)
         desc = self.FindWindowById(self.win['volume']['desc'])
@@ -4837,8 +4844,7 @@
     def __init__(self, parent, mapwindow, id = wx.ID_ANY,
                  **kwargs):
         PositionWindow.__init__(self, parent, mapwindow, id, **kwargs)
-        self.SetToolTipString(_("Adjusts the look direction (azimuth). "
-                                "Click and drag the puck to change the current eye position."))
+        self.SetToolTipString(_("Adjusts the distance and direction of the image viewpoint"))
         self.data = self.mapWindow.view
         self.PostDraw()
