[GRASS-SVN] r53079 - grass/trunk/lib/db/dbmi_client
Tue Sep 4 04:12:00 PDT 2012
Author: mmetz
Date: 2012-09-04 04:12:00 -0700 (Tue, 04 Sep 2012)
New Revision: 53079
   grass/trunk/lib/db/dbmi_client/select.c
db lib: use G_asprintf
Modified: grass/trunk/lib/db/dbmi_client/select.c
--- grass/trunk/lib/db/dbmi_client/select.c	2012-09-04 10:16:50 UTC (rev 53078)
+++ grass/trunk/lib/db/dbmi_client/select.c	2012-09-04 11:12:00 UTC (rev 53079)
@@ -105,7 +105,7 @@
     int type, more, alloc, count;
     int *val;
-    char buf[1024];
+    char *buf = NULL;
     const char *sval;
     dbString stmt;
     dbCursor cursor;
@@ -125,14 +125,15 @@
     val = (int *)G_malloc(alloc * sizeof(int));
     if (where == NULL || strlen(where) == 0)
-	G_snprintf(buf, 1023, "SELECT %s FROM %s", col, tab);
+	G_asprintf(&buf, "SELECT %s FROM %s", col, tab);
     else
-	G_snprintf(buf, 1023, "SELECT %s FROM %s WHERE %s", col, tab, where);
+	G_asprintf(&buf, "SELECT %s FROM %s WHERE %s", col, tab, where);
     G_debug(3, "  SQL: %s", buf);
     db_init_string(&stmt);
     db_set_string(&stmt, buf);
+    G_free(buf);
     if (db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
 	return (-1);
@@ -204,7 +205,7 @@
 		    int id, const char *col, dbValue * val)
     int more, count;
-    char buf[1024];
+    char *buf = NULL;
     dbString stmt;
     dbCursor cursor;
     dbColumn *column;
@@ -222,9 +223,10 @@
     G_zero(val, sizeof(dbValue));
-    sprintf(buf, "SELECT %s FROM %s WHERE %s = %d\n", col, tab, key, id);
+    G_asprintf(&buf, "SELECT %s FROM %s WHERE %s = %d", col, tab, key, id);
+    G_free(buf);
 	return (-1);
@@ -268,7 +270,7 @@
 			  dbCatValArray * cvarr)
     int i, type, more, nrows, ncols;
-    char buf[1024];
+    char *buf = NULL;
     dbString stmt;
     dbCursor cursor;
     dbColumn *column;
@@ -290,13 +292,14 @@
     if (strcmp(key, col) == 0) {
 	ncols = 1;
-	sprintf(buf, "SELECT %s FROM %s", key, tab);
+	G_asprintf(&buf, "SELECT %s FROM %s", key, tab);
     else {
 	ncols = 2;
-	sprintf(buf, "SELECT %s, %s FROM %s", key, col, tab);
+	G_asprintf(&buf, "SELECT %s, %s FROM %s", key, col, tab);
+    G_free(buf);
     if (where != NULL && strlen(where) > 0) {
 	db_append_string(&stmt, " WHERE ");
