[GRASS-SVN] r53104 - grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing
svn_grass at osgeo.org
Thu Sep 6 01:21:33 PDT 2012
Author: neteler
Date: 2012-09-06 01:21:33 -0700 (Thu, 06 Sep 2012)
New Revision: 53104
grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/description.html
manual fix; HTML cosmetics
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/description.html
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/description.html 2012-09-06 08:15:22 UTC (rev 53103)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/description.html 2012-09-06 08:21:33 UTC (rev 53104)
@@ -20,7 +20,7 @@
<h2>NOTES</h2>
-The input data should be the output result of the <em>v.lidar.correction</em>
+The input data should be the output result of the <em>v.lidar.edgedetection</em>,
module. Otherwise, it goes to error! The output of this module will be
the input of <em>v.lidar.correction</em> module. The output will be a vector
map which points are pre-classified as:
@@ -48,17 +48,20 @@
</pre></div>
<h2>SEE ALSO</h2>
-<em><a HREF="v.lidar.edgedetection.html">v.lidar.edgedetection</a></em>,
-<em><a HREF="v.lidar.correction.html">v.lidar.correction</a></em>,
-<em><a HREF="v.surf.bspline.html">v.surf.bspline</a></em>
+<em>
+<a HREF="v.lidar.edgedetection.html">v.lidar.edgedetection</a>,
+<a HREF="v.lidar.correction.html">v.lidar.correction</a>,
+<a HREF="v.surf.bspline.html">v.surf.bspline</a>
+</em>
<h2>AUTHOR</h2>
Original version of program in GRASS 5.4:
-<BR>
+<br>
Maria Antonia Brovelli, Massimiliano Cannata, Ulisse Longoni and Mirko Reguzzoni
-<BR><BR>
+<p>
Update for GRASS 6.X:
-<BR>
+<br>
Roberto Antolin and Gonzalo Moreno
<h2>REFERENCES</h2>
@@ -66,30 +69,24 @@
Antolin, R. et al., 2006. Digital terrain models determination by LiDAR
technology: Po basin experimentation. Bolletino di Geodesia e Scienze
Affini, anno LXV, n. 2, pp. 69-89.
-<br>
-<br>
+<p>
Brovelli M. A., Cannata M., Longoni U.M., 2004. LIDAR Data Filtering and
DTM Interpolation Within GRASS, Transactions in GIS, April 2004, vol. 8,
iss. 2, pp. 155-174(20), Blackwell Publishing Ltd.
-<br>
-<br>
+<p>
Brovelli M. A., Cannata M., 2004. Digital Terrain model reconstruction in
urban areas from airborne laser scanning data: the method and an example
for Pavia (Northern Italy). Computers and Geosciences 30 (2004) pp.325-331
-<br>
-<br>
+<p>
Brovelli M. A. and Longoni U.M., 2003. Software per il filtraggio di dati
LIDAR, Rivista dell?Agenzia del Territorio, n. 3-2003, pp. 11-22 (ISSN 1593-2192).
-<br>
-<br>
+<p>
Brovelli M. A., Cannata M. and Longoni U.M., 2002. DTM LIDAR in area urbana,
Bollettino SIFET N.2, pp. 7-26.
-<br>
-<br>
+<p>
Performances of the filter can be seen in the
<a HREF="http://www.itc.nl/isprswgIII-3/filtertest/MainDoc.htm">ISPRS WG III/3 Comparison of Filters</a>
report by Sithole, G. and Vosselman, G., 2003.
-<br>
<p><i>Last changed: $Date$</i>
