[GRASS-SVN] r53110 - grass/branches/releasebranch_6_4/lib/db/dbmi_client
svn_grass at osgeo.org
Thu Sep 6 11:48:36 PDT 2012
Author: mmetz
Date: 2012-09-06 11:48:35 -0700 (Thu, 06 Sep 2012)
New Revision: 53110
grass/branches/releasebranch_6_4/lib/db/dbmi_client/select.c
dbmi_client lib: backport r53079 from trunk
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_client/select.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_client/select.c 2012-09-06 18:47:36 UTC (rev 53109)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_client/select.c 2012-09-06 18:48:35 UTC (rev 53110)
@@ -105,7 +105,7 @@
int type, more, alloc, count;
int *val;
- char buf[1024];
+ char *buf = NULL;
const char *sval;
dbString stmt;
dbCursor cursor;
@@ -125,20 +125,24 @@
val = (int *)G_malloc(alloc * sizeof(int));
if (where == NULL || strlen(where) == 0)
- G_snprintf(buf, 1023, "SELECT %s FROM %s", col, tab);
+ G_asprintf(&buf, "SELECT %s FROM %s", col, tab);
else
- G_snprintf(buf, 1023, "SELECT %s FROM %s WHERE %s", col, tab, where);
+ G_asprintf(&buf, "SELECT %s FROM %s WHERE %s", col, tab, where);
G_debug(3, " SQL: %s", buf);
db_init_string(&stmt);
db_set_string(&stmt, buf);
+ G_free(buf);
if (db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
return (-1);
table = db_get_cursor_table(&cursor);
column = db_get_table_column(table, 0); /* first column */
+ if (column == NULL) {
+ return -1;
value = db_get_column_value(column);
type = db_get_column_sqltype(column);
type = db_sqltype_to_Ctype(type);
@@ -201,7 +205,7 @@
int id, const char *col, dbValue * val)
int more, count;
- char buf[1024];
+ char *buf = NULL;
dbString stmt;
dbCursor cursor;
dbColumn *column;
@@ -219,9 +223,10 @@
G_zero(val, sizeof(dbValue));
- sprintf(buf, "SELECT %s FROM %s WHERE %s = %d\n", col, tab, key, id);
+ G_asprintf(&buf, "SELECT %s FROM %s WHERE %s = %d", col, tab, key, id);
+ G_free(buf);
return (-1);
@@ -264,8 +269,8 @@
const char *col, const char *where,
dbCatValArray * cvarr)
- int i, type, more, nrows;
- char buf[1024];
+ int i, type, more, nrows, ncols;
+ char *buf = NULL;
dbString stmt;
dbCursor cursor;
dbColumn *column;
@@ -283,11 +288,18 @@
G_warning(_("Missing column name"));
return -1;
- sprintf(buf, "SELECT %s, %s FROM %s", key, col, tab);
+ if (strcmp(key, col) == 0) {
+ ncols = 1;
+ G_asprintf(&buf, "SELECT %s FROM %s", key, tab);
+ else {
+ ncols = 2;
+ G_asprintf(&buf, "SELECT %s, %s FROM %s", key, col, tab);
+ G_free(buf);
if (where != NULL && strlen(where) > 0) {
db_append_string(&stmt, " WHERE ");
@@ -301,8 +313,12 @@
nrows = db_get_num_rows(&cursor);
G_debug(3, " %d rows selected", nrows);
- if (nrows < 0)
- G_fatal_error(_("Unable select records from table <%s>"), tab);
+ if (nrows < 0) {
+ G_warning(_("Unable select records from table <%s>"), tab);
+ db_close_cursor(&cursor);
+ db_free_string(&stmt);
+ return -1;
db_CatValArray_alloc(cvarr, nrows);
@@ -314,19 +330,23 @@
G_debug(3, " key type = %d", type);
if (type != DB_C_TYPE_INT) {
- G_fatal_error("Key column type is not integer");
+ G_warning(_("Key column type is not integer"));
+ return -1;
- column = db_get_table_column(table, 1);
- type = db_sqltype_to_Ctype(db_get_column_sqltype(column));
- G_debug(3, " col type = %d", type);
+ if (ncols == 2) {
+ column = db_get_table_column(table, 1);
+ type = db_sqltype_to_Ctype(db_get_column_sqltype(column));
+ G_debug(3, " col type = %d", type);
- if ( type != DB_C_TYPE_INT && type != DB_C_TYPE_DOUBLE ) {
- G_fatal_error ( "Column type not supported by db_select_to_array()" );
+ if ( type != DB_C_TYPE_INT && type != DB_C_TYPE_DOUBLE ) {
+ G_fatal_error ( "Column type not supported by db_select_to_array()" );
cvarr->ctype = type;
/* fetch the data */
@@ -338,8 +358,10 @@
cvarr->value[i].cat = db_get_value_int(value);
- value = db_get_column_value(column);
+ if (ncols == 2) {
+ value = db_get_column_value(column);
cvarr->value[i].isNull = value->isNull;
switch (type) {
case (DB_C_TYPE_INT):
@@ -385,7 +407,7 @@
db_CatValArray_sort(cvarr);
- return (nrows);
+ return nrows;
