[GRASS-SVN] r53136 - grass/trunk/vector/v.split
Sun Sep 9 02:42:11 PDT 2012
Author: mmetz
Date: 2012-09-09 02:42:10 -0700 (Sun, 09 Sep 2012)
New Revision: 53136
   grass/trunk/vector/v.split/main.c
v.split latlong bugfix
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c	2012-09-08 19:39:27 UTC (rev 53135)
+++ grass/trunk/vector/v.split/main.c	2012-09-09 09:42:10 UTC (rev 53136)
@@ -45,7 +45,7 @@
     double length = -1;
     int vertices = 0;
     double (*line_length) ();
-    int latlon = 0;
+    int geodesic = 0;
     G_gisinit(argv[0]);
@@ -114,8 +114,14 @@
 	    G_fatal_error(_("Unknown unit %s"), units_opt->answer);
 	/* set line length function */
-	if ((latlon = (G_projection() == PROJECTION_LL)) == 1)
-	    line_length = Vect_line_geodesic_length;
+	if (G_projection() == PROJECTION_LL) {
+	    if (strcmp(units_opt->answer, "map") == 0)
+		line_length = Vect_line_length;
+	    else {
+		line_length = Vect_line_geodesic_length;
+		geodesic = 1;
 	else {
 	    double factor;
@@ -129,7 +135,10 @@
 		length = length / factor;
-	G_verbose_message(_("length in %s: %g"), (latlon ? "meters" : "map units"), length);
+	    G_verbose_message(_("Length in map units: %g"), length);
+	else
+	    G_verbose_message(_("Length in meters: %g"), length);
     if (vertices_opt->answer) {
@@ -178,14 +187,18 @@
 		    Vect_write_line(&Out, ltype, Points, Cats);
 		else {
-		    int n, i;
+		    long n, i;
+		    G_debug(3, "l: %f, length: %f", l, length);
 		    n = ceil(l / length);
-		    if (latlon)
+		    if (geodesic)
 			l = Vect_line_length(Points);
 		    step = l / n;
 		    from = 0.;
+		    G_debug(3, "n: %ld, step: %f", n, step);
 		    for (i = 0; i < n; i++) {
 			int ret;
