[GRASS-SVN] r53139 - in grass/trunk: gui/wxpython/core gui/wxpython/dbmgr gui/wxpython/gui_core gui/wxpython/modules gui/wxpython/psmap gui/wxpython/wxplot lib/gis lib/python scripts/d.vect.thematic scripts/i.pansharpen scripts/m.proj scripts/r.out.xyz scripts/r.reclass.area scripts/r.tileset scripts/r3.in.xyz scripts/v.in.geonames scripts/v.in.gns scripts/v.in.lines scripts/v.rast.stats
svn_grass at osgeo.org
Sun Sep 9 04:01:25 PDT 2012
Author: mmetz
Date: 2012-09-09 04:01:24 -0700 (Sun, 09 Sep 2012)
New Revision: 53139
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/modules/colorrules.py
grass/trunk/gui/wxpython/psmap/instructions.py
grass/trunk/gui/wxpython/wxplot/histogram.py
grass/trunk/gui/wxpython/wxplot/scatter.py
grass/trunk/lib/gis/parser_standard_options.c
grass/trunk/lib/python/core.py
grass/trunk/lib/python/vector.py
grass/trunk/scripts/d.vect.thematic/d.vect.thematic
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
grass/trunk/scripts/r.tileset/r.tileset.py
grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.gns/v.in.gns.py
grass/trunk/scripts/v.in.lines/v.in.lines.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
revert fs back to sep(arator)
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/core/utils.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -255,7 +255,7 @@
read = True,
quiet = True,
flags = 'l',
- fs = 'newline')
+ sep = 'newline')
if ret:
mapsets = ret.splitlines()
@@ -268,7 +268,7 @@
read = True,
quiet = True,
flags = 'p',
- fs = 'newline')
+ sep = 'newline')
if ret:
if get == 'accessible':
@@ -302,7 +302,7 @@
read = True,
flags = 'g',
map = fullname,
- fs = ';')
+ sep = ';')
if ret != 0:
sys.stderr.write(_("Vector map <%(map)s>: %(msg)s\n") % { 'map' : fullname, 'msg' : msg })
return layers
@@ -570,7 +570,7 @@
input = '-',
proj_input = projIn,
proj_output = projOut,
- fs = ';',
+ sep = ';',
stdin = '%f;%f' % (coord[0], coord[1]),
read = True)
if coors:
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -177,7 +177,7 @@
quiet = True,
parent = self,
flags = 'c',
- fs = fs,
+ sep = fs,
sql = sql,
output = outFile.name)
else:
@@ -189,7 +189,7 @@
map = self.mapDBInfo.map,
layer = layer,
columns = ','.join(columns),
- fs = fs,
+ sep = fs,
where = where,
stdout = outFile)
else:
@@ -199,7 +199,7 @@
flags = 'c',
layer = layer,
- fs = fs,
+ sep = fs,
where = where,
stdout = outFile)
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -689,7 +689,7 @@
ret = RunCommand('v.db.connect',
read = True,
quiet = True,
- fs = '|',
+ sep = '|',
flags = 'g',
map = vector)
if ret:
@@ -954,7 +954,7 @@
if self.searchPath:
mlist = RunCommand('g.mapsets',
read = True, flags = 'p',
- fs = 'newline').splitlines()
+ sep = 'newline').splitlines()
else:
mlist = GetListOfMapsets(self.gisdbase, self.location,
selectable = False)
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/modules/colorrules.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -1369,7 +1369,7 @@
map = self.inmap,
layer = self.properties['layer'],
columns = columns,
- fs = sep,
+ sep = sep,
stdout = outFile)
else:
self.preview.EraseMap()
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/psmap/instructions.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -1396,7 +1396,7 @@
rows = ceil(maxim / cols )
else:
cat = grass.read_command('r.category', map = raster,
- fs = ':').strip().split('\n')
+ sep = ':').strip().split('\n')
rows = ceil(float(len(cat)) / cols )
Modified: grass/trunk/gui/wxpython/wxplot/histogram.py
--- grass/trunk/gui/wxpython/wxplot/histogram.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/wxplot/histogram.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -150,7 +150,7 @@
input = raster,
flags = freqflag,
nsteps = self.bins,
- fs = ',',
+ sep = ',',
quiet = True,
read = True)
Modified: grass/trunk/gui/wxpython/wxplot/scatter.py
--- grass/trunk/gui/wxpython/wxplot/scatter.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/gui/wxpython/wxplot/scatter.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -170,7 +170,7 @@
input = '%s,%s' % rpair,
flags = freqflag,
nsteps = self.bins,
- fs = ',',
+ sep = ',',
quiet = True,
read = True)
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/lib/gis/parser_standard_options.c 2012-09-09 11:01:24 UTC (rev 53139)
@@ -520,7 +520,7 @@
Opt->description = _("Name for output file");
break;
case G_OPT_F_SEP:
- Opt->key = "fs";
+ Opt->key = "separator";
Opt->type = TYPE_STRING;
Opt->key_desc = "character";
Opt->required = NO;
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/lib/python/core.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -1178,7 +1178,7 @@
flags = 'l'
mapsets = read_command('g.mapsets',
flags = flags,
- fs = 'newline',
+ sep = 'newline',
quiet = True)
if not mapsets:
fatal(_("Unable to list mapsets"))
Modified: grass/trunk/lib/python/vector.py
--- grass/trunk/lib/python/vector.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/lib/python/vector.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -47,7 +47,7 @@
@return dictionary
- s = read_command('v.db.connect', flags = 'g', map = map, fs = ';', **args)
+ s = read_command('v.db.connect', flags = 'g', map = map, sep = ';', **args)
result = {}
for l in s.splitlines():
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2012-09-09 11:01:24 UTC (rev 53139)
@@ -361,9 +361,9 @@
export GRASS_PNG_AUTO_WRITE
fi
-table=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
-database=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $4}'`
-driver=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $5}'`
+table=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
+database=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $4}'`
+driver=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $5}'`
if [ -z "$table" ]
then
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -356,7 +356,7 @@
for i in images:
# calculate number of cells for each grey value for for each image
- stats_out = grass.pipe_command('r.stats', flags='cin', input= i, fs=':')
+ stats_out = grass.pipe_command('r.stats', flags='cin', input= i, sep=':')
stats = stats_out.communicate()[0].split('\n')[:-1]
stats_dict = dict( s.split(':', 1) for s in stats)
total_cells = 0 # total non-null cells
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/m.proj/m.proj.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -112,7 +112,7 @@
def main():
input = options['input']
output = options['output']
- fs = options['fs']
+ fs = options['sep']
proj_in = options['proj_input']
proj_out = options['proj_output']
ll_in = flags['i']
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -37,7 +37,7 @@
# if no output filename, output to stdout
- ret = grass.run_command("r.stats", flags = "1gn", input = options['input'], fs = options['fs'], output = output)
+ ret = grass.run_command("r.stats", flags = "1gn", input = options['input'], fs = options['sep'], output = output)
sys.exit(ret)
if __name__ == "__main__":
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -101,7 +101,7 @@
flags = 'aln'
if grass.raster_info(infile)['datatype'] in ('FCELL', 'DCELL'):
flags += 'i'
- p1 = grass.pipe_command('r.stats', flags = flags, input = (clumpfile, infile), fs = '|')
+ p1 = grass.pipe_command('r.stats', flags = flags, input = (clumpfile, infile), sep = '|')
p2 = grass.feed_command('r.reclass', input = clumpfile, output = recfile, rules = '-')
rules = ''
for line in p1.stdout:
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/r.tileset/r.tileset.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -157,7 +157,7 @@
flags = 'd',
proj_in = source['proj'],
proj_out = dest['proj'],
- fs = ';,;',
+ sep = ';',
input = file)
if not ret:
@@ -372,7 +372,7 @@
(tile_bbox['w'], tile_bbox['s'], tile_bbox['e'], tile_bbox['n'],
tile_size_overlap[0], tile_size_overlap[1])
else:
print "%s%s%s%s%s%s%s%s%s%s%s" % \
(tile_bbox['w'], fs, tile_bbox['s'], fs, tile_bbox['e'], fs, tile_bbox['n'], fs,
tile_size_overlap[0], fs, tile_size_overlap[1])
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -74,7 +74,7 @@
#% answer: float
#%End
#%Option
-#% key: fs
+#% key: sep
#% type: string
#% required: no
#% multiple: no
@@ -190,7 +190,7 @@
method = options['method']
dtype = options['type']
x = options['x']
y = options['y']
z = options['z']
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -150,7 +150,7 @@
'timezone varchar(50)',
'modification date']
- grass.run_command('v.in.ascii', cat = 0, x = 6, y = 5, fs = '|',
+ grass.run_command('v.in.ascii', cat = 0, x = 6, y = 5, sep = '|',
input = tmpfile, output = outfile,
columns = columns)
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -135,7 +135,7 @@
columns = [desc[1] for desc in coldescs]
- grass.run_command('v.in.ascii', cat = 0, x = 5, y = 4, fs = ';',
+ grass.run_command('v.in.ascii', cat = 0, x = 5, y = 4, sep = ';',
input = tmpfile, output = filevect,
columns = columns)
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -44,7 +44,7 @@
def main():
global tmp
threeD = flags['z']
prog = 'v.in.lines'
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2012-09-09 10:54:45 UTC (rev 53138)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2012-09-09 11:01:24 UTC (rev 53139)
@@ -131,7 +131,7 @@
grass.fatal(_("An error occurred while converting vector to raster"))
# dump cats to file to avoid "too many argument" problem:
- p = grass.pipe_command('r.category', map = rastertmp, fs = ';', quiet = True)
+ p = grass.pipe_command('r.category', map = rastertmp, sep = ';', quiet = True)
cats = []
for line in p.stdout:
cats.append(line.rstrip('\r\n').split(';')[0])
@@ -219,7 +219,7 @@
# do the stats
p = grass.pipe_command('r.univar', flags = 't' + 'g' + extstat, map = raster,
- zones = rastertmp, percentile = percentile, fs = ';')
+ zones = rastertmp, percentile = percentile, sep = ';')
first_line = 1
