[GRASS-SVN] r53142 - in grass/trunk: db/db.select vector/v.db.select
svn_grass at osgeo.org
Sun Sep 9 09:08:14 PDT 2012
Author: mmetz
Date: 2012-09-09 09:08:13 -0700 (Sun, 09 Sep 2012)
New Revision: 53142
grass/trunk/db/db.select/main.c
grass/trunk/vector/v.db.select/main.c
(v.)db.select: fix duplicate option lables
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2012-09-09 11:20:37 UTC (rev 53141)
+++ grass/trunk/db/db.select/main.c 2012-09-09 16:08:13 UTC (rev 53142)
@@ -215,12 +215,11 @@
database->guisection = _("Connection");
fs = G_define_standard_option(G_OPT_F_SEP);
- fs->description = _("Output field separator");
fs->guisection = _("Format");
vs = G_define_standard_option(G_OPT_F_SEP);
vs->key = "vs";
- vs->description = _("Output vertical record separator");
+ vs->label = _("Output vertical record separator");
vs->answer = NULL;
vs->guisection = _("Format");
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2012-09-09 11:20:37 UTC (rev 53141)
+++ grass/trunk/vector/v.db.select/main.c 2012-09-09 16:08:13 UTC (rev 53142)
@@ -62,12 +62,11 @@
where_opt = G_define_standard_option(G_OPT_DB_WHERE);
fs_opt = G_define_standard_option(G_OPT_F_SEP);
- fs_opt->description = _("Output field separator");
fs_opt->guisection = _("Format");
vs_opt = G_define_standard_option(G_OPT_F_SEP);
vs_opt->key = "vs";
- vs_opt->description = _("Output vertical record separator");
+ vs_opt->label = _("Output vertical record separator");
vs_opt->answer = NULL;
vs_opt->guisection = _("Format");
