[GRASS-SVN] r53151 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Sep 10 03:40:46 PDT 2012
Author: huhabla
Date: 2012-09-10 03:40:45 -0700 (Mon, 10 Sep 2012)
New Revision: 53151
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Fixed bug in map granularity handling in case of gaps
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-09-10 10:27:55 UTC (rev 53150)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-09-10 10:40:45 UTC (rev 53151)
@@ -650,7 +650,7 @@
rows = self.get_registered_maps("id", where, "start_time", dbif)
- if rows is not None:
+ if rows is not None and len(rows) != 0:
if len(rows) > 1:
core.warning(_("More than one map found in a granule. "
"Temporal granularity seems to be invalid or"
@@ -660,7 +660,7 @@
maplist = []
for row in rows:
- # Take the first map
+ # Take the first map
map = self.get_new_map_instance(rows[0]["id"])
if self.is_time_absolute():
@@ -672,7 +672,21 @@
maplist.append(copy.copy(map))
obj_list.append(copy.copy(maplist))
+ else:
+ # Found a gap
+ map = self.get_new_map_instance(None)
+ if self.is_time_absolute():
+ map.set_absolute_time(start, next)
+ elif self.is_time_relative():
+ map.set_relative_time(start, next,
+ self.get_relative_time_unit())
+ maplist = []
+ maplist.append(copy.copy(map))
+ obj_list.append(copy.copy(maplist))
start = next
if connect:
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-09-10 10:27:55 UTC (rev 53150)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-09-10 10:40:45 UTC (rev 53151)
@@ -197,7 +197,6 @@
# Put the map into the database
if not map.is_in_db(dbif):
- print "Map not in db"
is_in_db = False
# Break in case no valid time is provided
if start == "" or start is None:
@@ -496,8 +495,6 @@
elif method == "gran":
maps = sp.get_registered_maps_as_objects_by_granularity(None)
- print "The maps object:", maps
if header:
string = ""
string += "%s%s" % ("id", separator)
@@ -509,6 +506,7 @@
string += "%s%s" % ("end_time", separator)
string += "%s%s" % ("interval_length", separator)
string += "%s" % ("distance_from_begin")
+ print string
if maps and len(maps) > 0:
@@ -527,7 +525,7 @@
if len(mymap) > 0:
map = mymap[0]
else:
- core.error(_("Empty entry in map list, continue to next entry"))
+ core.fatal(_("Empty entry in map list, this should not happen."))
else:
map = mymap
