[GRASS-SVN] r53157 - grass/trunk/scripts/r.plane
svn_grass at osgeo.org
Mon Sep 10 16:19:06 PDT 2012
Author: hamish
Date: 2012-09-10 16:19:06 -0700 (Mon, 10 Sep 2012)
New Revision: 53157
grass/trunk/scripts/r.plane/r.plane.py
CELL,FCELL,DCELL instead of int,float,double for raster map type
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py 2012-09-10 21:07:57 UTC (rev 53156)
+++ grass/trunk/scripts/r.plane/r.plane.py 2012-09-10 23:19:06 UTC (rev 53157)
@@ -8,7 +8,7 @@
# Modified to produce floating and double values maps
# Converted to Python by Glynn Clements
# PURPOSE: Creates a raster plane map from user specified inclination and azimuth
-# COPYRIGHT: (C) 2004,2008 by the GRASS Development Team
+# COPYRIGHT: (C) 2004-2012 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -60,9 +60,9 @@
#%option
#% key: type
#% type: string
-#% options: int,float,double
-#% description: Type of the raster map to be created
-#% required : yes
+#% options: CELL,FCELL,DCELL
+#% description: Type of raster map to be created
+#% answer: FCELL
#%end
import sys
@@ -101,14 +101,20 @@
ky = cosaz * tandip
kz = el - ea * sinaz * tandip - no * cosaz * tandip
- if type == "int":
+ if type == "CELL":
round = "round"
+ dtype = "int"
+ elif type == "FCELL":
+ round = ""
+ dtype = "float"
else:
round = ""
+ dtype = "double"
grass.mapcalc("$name = $type($round(x() * $kx + y() * $ky + $kz))",
- name = name, type = type, round = round, kx = kx, ky = ky, kz = kz)
+ name = name, type = dtype, round = round, kx = kx, ky = ky, kz = kz)
+ grass.run_command('r.support', map = name, history = '')
grass.raster_history(name)
grass.message(_("Done."))
