[GRASS-SVN] r53167 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Tue Sep 11 09:10:36 PDT 2012
Author: martinl
Date: 2012-09-11 09:10:34 -0700 (Tue, 11 Sep 2012)
New Revision: 53167
grass/trunk/vector/v.out.ascii/args.c
grass/trunk/vector/v.out.ascii/local_proto.h
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii: fix for layer names
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c 2012-09-11 15:20:15 UTC (rev 53166)
+++ grass/trunk/vector/v.out.ascii/args.c 2012-09-11 16:10:34 UTC (rev 53167)
@@ -10,13 +10,13 @@
void parse_args(int argc, char **argv,
char **input, char**output, int *format, int *dp, char **delim,
char **field, char ***columns, char **where, int *region,
- int *old_format, int *header, struct cat_list **clist, int *type)
+ int *old_format, int *header, char **cats, int *type)
struct Option *input_opt, *output_opt, *format_opt, *dp_opt, *delim_opt,
*field_opt, *column_opt, *where_opt, *cats_opt, *type_opt;
struct Flag *old_flag, *header_flag, *region_flag;
- char * desc;
+ char *desc;
input_opt = G_define_standard_option(G_OPT_V_INPUT);
@@ -130,23 +130,18 @@
(*columns)[i] = G_store(column_opt->answers[i]);
(*columns)[nopt - 1] = NULL;
*where = NULL;
if (where_opt->answer) {
*where = G_store(where_opt->answer);
- *clist = NULL;
+ *cats = NULL;
if (cats_opt->answer) {
- int ret;
- *clist = Vect_new_cat_list();
- (*clist)->field = atoi(field_opt->answer);
- if ((*clist)->field < 1)
- G_fatal_error(_("Option <%s> must be > 0"), field_opt->key);
- ret = Vect_str_to_cat_list(cats_opt->answer, *clist);
- if (ret > 0)
- G_fatal_error(_("%d errors in cat option"), ret);
+ *cats = G_store(cats_opt->answer);
- *region = region_flag->answer ? 1 : 0;
- *old_format = old_flag->answer ? 1 : 0;
- *header = header_flag->answer ? 1 : 0;
+ *region = region_flag->answer ? TRUE : FALSE;
+ *old_format = old_flag->answer ? TRUE : FALSE;
+ *header = header_flag->answer ? TRUE : FALSE;
Modified: grass/trunk/vector/v.out.ascii/local_proto.h
--- grass/trunk/vector/v.out.ascii/local_proto.h 2012-09-11 15:20:15 UTC (rev 53166)
+++ grass/trunk/vector/v.out.ascii/local_proto.h 2012-09-11 16:10:34 UTC (rev 53167)
@@ -2,4 +2,4 @@
void parse_args(int, char **,
char **, char**, int *, int *, char **,
char **, char ***, char **, int *, int *, int *,
- struct cat_list **, int *);
+ char **, int *);
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2012-09-11 15:20:15 UTC (rev 53166)
+++ grass/trunk/vector/v.out.ascii/main.c 2012-09-11 16:10:34 UTC (rev 53167)
@@ -33,12 +33,14 @@
struct Map_info Map;
FILE *ascii, *att;
- char *input, *output, *delim, **columns, *where, *field_name;
+ char *input, *output, *delim, **columns, *where, *field_name, *cats;
int format, dp, field, ret, region, old_format, header, type;
int ver, pnt;
struct cat_list *clist;
+ clist = NULL;
G_gisinit(argv[0]);
module = G_define_module();
@@ -50,7 +52,7 @@
parse_args(argc, argv, &input, &output, &format, &dp, &delim,
&field_name, &columns, &where, ®ion, &old_format, &header,
- &clist, &type);
+ &cats, &type);
if (format == GV_ASCII_FORMAT_STD && columns) {
G_warning(_("Parameter 'column' ignored in standard mode"));
@@ -92,7 +94,17 @@
field = Vect_get_field_number(&Map, field_name);
+ if (cats) {
+ clist = Vect_new_cat_list();
+ clist->field = field;
+ if (clist->field < 1)
+ G_fatal_error(_("Layer <%s> not found"), field_name);
+ ret = Vect_str_to_cat_list(cats, clist);
+ if (ret > 0)
+ G_fatal_error(_("%d errors in <%s> option"), ret, "cats");
if (strcmp(output, "-") != 0) {
if (ver == 4) {
ascii = G_fopen_new("dig_ascii", output);
@@ -150,5 +162,8 @@
Vect_close(&Map);
+ if (cats)
+ Vect_destroy_cat_list(clist);
exit(EXIT_SUCCESS);
