[GRASS-SVN] r53173 - in grass/branches/releasebranch_6_4/vector/lidar: lidarlib v.lidar.correction v.lidar.edgedetection v.outlier v.surf.bspline
svn_grass at osgeo.org
Wed Sep 12 11:52:30 PDT 2012
Author: neteler
Date: 2012-09-12 11:52:29 -0700 (Wed, 12 Sep 2012)
New Revision: 53173
grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h
grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c
grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c
grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c
grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
calm down G_percent() in cross-validation mode
Modified: grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h
--- grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h 2012-09-12 18:52:29 UTC (rev 53173)
@@ -161,13 +161,13 @@
/*tcholBand */
-void tcholDec(double **N, double **T, int n, int BW);
-void tcholSolve(double **N, double *TN, double *parVect, int n, int BW);
+void tcholDec(double **N, double **T, int n, int BW, int CV);
+void tcholSolve(double **N, double *TN, double *parVect, int n, int BW, int CV);
void tcholSolve2(double **N, double *TN, double **T, double *parVect, int n,
int BW);
-void tcholInv(double **N, double *invNdiag, int n, int BW);
+void tcholInv(double **N, double *invNdiag, int n, int BW, int CV);
void tcholSolveInv(double **N, double *TN, double *invNdiag, double *parVect,
- int n, int BW);
+ int n, int BW, int CV);
/*interpSpline */
Modified: grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c
--- grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -5,9 +5,9 @@
#include <grass/PolimiFunct.h>
-/* Tcholetsky decomposition -> T= Lower Triangular Matrix */
+/* Cholesky decomposition -> T= Lower Triangular Matrix */
int i, j, k, end;
double somma;
@@ -15,7 +15,7 @@
G_debug(2, "tcholDec(): n=%d BW=%d", n, BW);
for (i = 0; i < n; i++) {
- G_percent(i, n, 2);
+ if (CV == 0) G_percent(i, n, 2);
for (j = 0; j < BW; j++) {
somma = N[i][j];
/* start = 1 */
@@ -33,14 +33,14 @@
return;
-/* Tcholetsky matrix solution */
+/* Cholesky matrix solution */
double **T;
@@ -50,7 +50,7 @@
T = G_alloc_matrix(n, BW);
- tcholDec(N, T, n, BW); /* T computation */
+ tcholDec(N, T, n, BW, CV); /* T computation */
/* Forward substitution */
parVect[0] = TN[0] / T[0][0];
@@ -83,7 +83,7 @@
-/* Soluzione con Tcholetsky -> la matrice T triangolare viene passata come paramtero e
+/* Soluzione con Cholesky -> la matrice T triangolare viene passata come paramtero e
non calcolata internamente alla procedura -> T = dmatrix (0, n-1, 0, BW-1) */
@@ -119,9 +119,9 @@
-/* Tcholetsky matrix invertion */
+/* Cholesky matrix inversion */
double **T = NULL;
double *vect = NULL;
@@ -133,7 +133,7 @@
vect = G_alloc_vector(n);
/* T computation */
/* T Diagonal invertion */
@@ -165,10 +165,10 @@
-/* Tcholetsky matrix solution and invertion */
+/* Cholesky matrix solution and inversion */
- int n, int BW)
double **T = NULL;
@@ -181,7 +181,7 @@
/* T computation */
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -406,7 +406,7 @@
elaboration_reg.south, nterrain, nparameters,
BW);
nCorrectGrad(N, lambda, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect, nparameters, BW);
+ tcholSolve(N, TN, parVect, nparameters, BW, 0);
G_free_matrix(N);
G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -420,7 +420,7 @@
elaboration_reg.south, npoints, nparameters,
BW);
nCorrectGrad(N, lambda_B, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect_bilin, nparameters, BW);
+ tcholSolve(N, TN, parVect_bilin, nparameters, BW, 0);
G_free_matrix(N);
for (tn = 0; tn < nparameters; tn++)
@@ -437,7 +437,7 @@
BW);
nCorrectLapl(N, lambda_F, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect_bicub, nparameters, BW);
+ tcholSolve(N, TN, parVect_bicub, nparameters, BW, 0);
G_free_matrix(N);
G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -396,7 +396,7 @@
BW);
G_free_matrix(N);
G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -257,7 +257,7 @@
if (bilin) interpolation (&interp, P_BILINEAR);
else interpolation (&interp, P_BICUBIC);
- tcholSolve(N, TN, parVect, nparam_spl, BW);
+ tcholSolve(N, TN, parVect, nparam_spl, BW, 1);
/* Estimation of j-point */
if (bilin)
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2012-09-12 13:23:46 UTC (rev 53172)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2012-09-12 18:52:29 UTC (rev 53173)
@@ -610,7 +610,7 @@
+ tcholSolve(N, TN, parVect, nparameters, BW, cross_corr_flag->answer);
G_free_matrix(N);
G_free_vector(TN);
